May 5th, 2012, 01:11 PM | #1 |
Stupid electronics!
'90 ex250.
Turn signals don't work (didn't when I bought it) nor does my horn. I took a multimeter and it seems like all the connections are there. I hear the relay click once when I flip the turn signal switch but nothing happens. So I pulled the relay apart and it looks brand spanking new inside and I can't find any broken connections. Also the relay shows a full connection. Fuses are all good. In fact the fuse/junction box I have Doesn't have a turn signal fuse. Hell it only has 4 fuses versus what all the wiring schematics keep showing. =/ Maybe there is something I'm missing? |
May 5th, 2012, 04:25 PM | #2 | |
May 5th, 2012, 08:35 PM | #3 |
Noted. Guess I'll Try and pick up a new one. =/
Question still remains though... My horn doesn't work either. =/ |
May 6th, 2012, 05:31 AM | #4 |
You've checked the fuses, how about the bulbs themselves?
There are diodes for the turn signals near the rear of the bike. Check all the bulbs as well as simply replacing the relay. Make sure the battery is fully charged as well. As for the horn it is either the ignition switch or horn button itself. A horn upgrade wouldn't be bad either. |
May 6th, 2012, 07:06 AM | #5 | |
Why would it be the ignition? Wish there were pictures. I'm so lost =/ |
May 6th, 2012, 09:06 AM | #6 |
Bulbs burn out. In 12 years anything is possible. The horn doesn't blow unless the ignition switch is working properly.
May 7th, 2012, 04:30 PM | #7 |
I think you mean 22 years - not 12 - if you were referring to the age of the bike that is.
You should have seven 10Amp fuses plus a 30A in a separate box. If you are missing them, that is probably your problem.
May 7th, 2012, 07:17 PM | #8 |
May 7th, 2012, 11:47 PM | #9 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
You checked the fuses, four are missing, and you're still wondering why several electronics aren't functioning?
Posted via Mobile Device |
May 8th, 2012, 01:34 AM | #10 |
If he only knows that there are supposed to be more based on a wiring diagram that doesn't match what he sees, then he's probably saying that there are no empty sockets in his fuse box and that there are only four sockets total.
May 8th, 2012, 02:20 AM | #11 |
Milkshake Drinker
You think someone put an aftermarket junction box on his bike? That could definately explain why some electronics don't work. Can you post a pic of your junction (fuse) box? I know some 80s boxes were different, but don't recall ever seeing one with no turn signal fuse.
May 8th, 2012, 03:18 AM | #12 |
I'll take the actual pic of it after work today.... Here's one I found on google though...
May 8th, 2012, 04:57 AM | #13 |
Milkshake Drinker
If you've got a different model junction box from an 86 or something, that could explain your problems. I've heard the plugs fit the same but the wiring is different. That's all from memory though, so I can't be sure of anything...
May 8th, 2012, 06:51 AM | #14 |
It should look more like this:
The relay looking thing next to it is the flasher. There are 9 fuses, but the two on the bottom are spares and aren't hooked to anything. Looks like the previous owner really screwed things up. You might be better off buying a whole new harness and fuse box off ebay. Here is a new fuse box for $10 and free shipping. They have wiring harnesses there too for about $15 delivered, but if you get one, its important to know that the wiring on the early pregens was different from later pregens. Look up the correct part number for your year on RonAyers and then make sure what you are buying matches.
May 8th, 2012, 03:56 PM | #15 |
Hmmm I thought it seemed kinda weird... Thought maybe mine was year specific or something. I'll pick up a new fusebox and see if that works. Looks pretty much plug'n'play. I'd rather not re-wire the bike though. I hate messing with wiring so much. =/
The flasher looks exactly the same as the one you showed but I went ahead and picked up another one just in case. |
May 8th, 2012, 04:21 PM | #16 |
I see you bought that fusebox, I hope you have the original bracket to mate with it because the one in the listing didn't come with the bracket. Its not the end of the world if you don't, but it makes things a lot nicer if you do. Sorry I didn't think to mention that before.
The only reason I suggested getting the new harness is that it sounds like the previous owner cobbled your wiring. As such, the original fusebox connectors may be missing or wired incorrectly.
May 8th, 2012, 04:30 PM | #17 |
Oh, I just just noticed something. The ebay fuse box has incorrect fuse values in the slots. They should ALL be 10 amps. The only exception is the main fuse which is 30A, but it's external in the single slot fuse holder next to the starter relay.
I've attached a wiring diagram for the pregen Ninja 250 that might help you.
May 9th, 2012, 02:53 AM | #18 | ||
Nothing on the bike wire wise has been touched/spliced so I'm not too worried about it right now... Quote:
May 12th, 2012, 02:54 PM | #19 |
Got my parts today. Swapped the turn signal relay - they work now. Swapped the fuse box - nothing changed. I finally tracked down that it was the horn button itself though and apparently only needed a cleaning. So now my horn works....
But like how everything usually works something else does not work now... Headlight bulb went out and now I gotta figure out how to get that out without breaking something else and my fuel filter snapped in half when I was trying to disconnect the hose... It's like, seriously? There has to be a better way to connect it. |
May 12th, 2012, 05:16 PM | #20 |
Fuel filter? You mean that plastic thing on the carb inlet?
May 12th, 2012, 08:26 PM | #21 |
May 12th, 2012, 10:06 PM | #22 |
The one in the photo is aftermarket. Are you saying that it broke in two? The OEM filter is just a little screen at the fuel inlet to the carb.
May 13th, 2012, 08:40 AM | #23 |
Yea I put an aftermarket one in (a much smaller one) and the ends snapped off almost like the plastic melted or something... So I gotta go get another one. =/
May 13th, 2012, 09:41 AM | #24 |
Be careful putting on a smaller inline filter. Some can inhibit fuel flow. The Ninja actually has an inline filter on the carb as well.
May 13th, 2012, 10:27 AM | #25 | |
Mine doesn't have that screen one. All the tubing had been replaced by the previous owner. |
May 13th, 2012, 02:16 PM | #26 |
May 13th, 2012, 02:31 PM | #27 |
Pregens built before 2000 didn't come with the inline filter. you need 1 that's made to work with gravity feed. I got mine at a lawn mower shop. The inlet and outlet are approximately 1 quarter inch.
May 13th, 2012, 06:27 PM | #28 |
I gotcha. I had this one and it seemed to work fine. Til it seems like the nipples melted. Cheap for sure.
http://www.cyclegear.com/eng/product...ter/web1007465 I'm gonna go back to the one the previous owner had that I thought was screwing up the bike. It's bigger (5/16") but we'll see. I'll find out tomorrow. Also I can't seem to figure out the headlight thing. I ran a multi meter to everything connected to the headlight and there is a connection and power, the bulbs I used are brand new and it previously worked but it seemed hit or miss. Ideas on that? |
May 13th, 2012, 06:39 PM | #29 | |
May 13th, 2012, 06:56 PM | #30 |
Good to know. Thank you for confirming that. Now I just need to find a way to orient the tubing so it doesn't screw with the flow.
May 14th, 2012, 05:47 AM | #31 |
The one I got at the hardware store works really good. It looks a lot like this one:
I can't swear they are the same, but the one I got was in True Value hardware in a plain plastic bag for about $6. The one on Amazon is a 60 micron, but I have never had a problem with flow.
May 14th, 2012, 05:49 AM | #32 | |
PS - I cut my original preformed stock tubing and left a gap for the filter. A friend used new tubing, but it kinked at the first 90 degree bend and restricted flow.
May 14th, 2012, 01:18 PM | #33 |
Well let me see how you have your's because that kink is what I was trying to avoid and the previous owner had but I can't think of a very good way to get it to work without kinking.
May 14th, 2012, 01:44 PM | #34 | |
You might get some polyurethane gas tubing that is more flexible. Might even be better, but you might have to step up to 5/16" tubing or something.
May 14th, 2012, 04:44 PM | #35 |
I ended up using 1/4" ID clear fuel hose, it's a really snug fit (had trouble pulling them off with 2 hands) so I'm gonna for-go the clamps for now. But it works and runs fine. It does have a minor kink but I figure the amount of vacuum in it will make up for it. If not then I'll be back to square one then.
On another note, still can't figure out the headlight problem. =/ |
May 14th, 2012, 05:27 PM | #36 | |
Attached is a schematic that might help you figure out the problem.
May 14th, 2012, 05:48 PM | #38 |
Yes I checked it today. It doesn't come on with the bike running. =/ It was working before. =/
May 15th, 2012, 03:54 PM | #39 |
Fixed the headlight issue... Apparently the pre-91 models had an older style 4 fuse system and the "newer" fuse box for some reason just doesn't work. Put the old one back on and everything works like a charm. Now to get it registered and actually ride it. >_< Thanks for the help guys.
1:43:35 of whole lot of stupid! | Nemesis | Videos | 34 | January 10th, 2014 01:35 PM |
Stupid Schematic | HKr1 | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 18th, 2013 04:19 PM |
stupid stupid video | toua70 | General Motorcycling Discussion | 24 | September 28th, 2012 04:32 PM |
[superbikeplanet.com] - It's The Electronics, Stupid | Ninjette Newsbot | Motorcycling News | 0 | November 18th, 2011 01:20 PM |
