January 26th, 2012, 05:26 PM | #201 |
Join Date: Nov 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2006 Suzuki Hayabusa GSX1300R, 2004 Kawasaki ZRX1200R, 1985 Kawasaki 750 Turbo Posts: 118
March 21st, 2012, 08:31 PM | #202 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
Bogging vs. Stuttering
YEAR:2011
INTAKE MODIFICATIONS: Stock EXHAUST MODIFICATIONS: Area P 18" Quiet Core (carbon) JET KIT OR STOCK? Jet Kit BRAND OF JET KIT? Dynojet MAIN JET: keihin #98 NEEDLE AND CLIP POSITION: 98 needle, clip on third notch MIXTURE SCREW SETTINGS: 2.75 turns out ELEVATION: 0-100 I'm having a problem diagnosing the signs my bike is giving me. I don't know the difference between bogging and stuttering. I cannot start it the first time without the choke, but if I persist one or two more times after the initial try, I can get it (without the choke). Needless to say starting up with the choke is no problem. It doesn't pull hard, and it doesn't rev past 10,000 RPMS on the freeway however, it pulls quite evenly across the powerband. Does this mean my bike is lean? How do I know my bike is stuttering and not bogging? |
March 21st, 2012, 10:01 PM | #203 |
There's nothing wrong with needing choke at startup. Leave the choke on while you ride. Notice how it bogs when you take off after it's all warmed up? turn it off. no more bog.
That shows that the needs of a bike change from cold to warm. The choke is there for a reason. It wouldn't be there if it wasn't needed. Needing choke to start isn't a bad thing. Buuuuuut, if it makes you feel better, back the mix screws out 1/8 turn, and see how the bike feels when warm. Better? keep it. worse? go back. No difference at all? you'll be fine to keep it, and start up will be a little bit easier. only test idle mix when warm. the choke is there for starting. use it. |
March 22nd, 2012, 08:38 AM | #204 |
I'll give that a shot. What I don't understand is that the bike performs worse with my new exhaust and jet settings than stock. Acceleration is gradual and top speed is 15km/h less than before... rpms in 6th gear max out at 10,000.
March 22nd, 2012, 08:40 AM | #205 |
If it's not pulling as hard at the top end, then try the next size larger jet
March 25th, 2012, 06:31 PM | #206 |
Fiddled with it again...
YEAR:2011 INTAKE MODIFICATIONS: Stock EXHAUST MODIFICATIONS: Area P 18" Quiet Core (carbon) JET KIT OR STOCK? Jet Kit BRAND OF JET KIT? Dynojet MAIN JET: #100 NEEDLE AND CLIP POSITION: Dynojet needle, clip on 3rd notch MIXTURE SCREW SETTINGS: 3.5 turns out ELEVATION: 0-100 ft. So I made sure the diaphragms weren't pinched or damaged before changing the jets. I upped the jets from a size 98 dyno to a 100 dyno, and changed the idle mixture screws to 3.5 turns out from 2.75. It pulls MUCH harder all the way through the powerband. I haven't been able to test its top speed because I only have city freeways at my disposal and my license is my livelihood and I'd like to keep it The only thing I've noticed is that when I blip the throttle it hangs a bit before returning to the 1500 rpm mark, which is what I set it to. The tachometer needle also bounces around a bit when its idling. It doesn't bounce around much, but its more than before I re-jetted it. According to what I've found on this site, my bike is showing signs of being lean. Instead of changing to a larger jet, should I put the clip one notch lower on the needle to the 4th position? |
March 25th, 2012, 06:58 PM | #207 |
Hey great @Slono glad it worked for you!
if it's hanging a little before returning to idle when warmed up, try backing the mix screws out 1/4 turn EDIT: is it only showing lean signs when you blip? also, if you're getting tach fluctuations, try syncing the carbs. |
March 25th, 2012, 07:13 PM | #208 | |
The screws are already backed out 3.5 turns. Backing it out another 1/4 of a turn will make it 3.75 turns out. Is that too far out? I *think* those are the only lean signs I'm getting. There's no stuttering and for the most part the throttle seems a tad more sensitive than when it was stock. Actually now that I think of it, when I roll on the throttle before releasing it hangs a bit before returning to 1500 rpms. But if I blip, the rpms dip before returning to the preset idle speed. I'm confused now, does this mean its rich? I haven't had any bogging problems... |
March 25th, 2012, 07:20 PM | #209 |
ok. the idle mix is adjusted based on how it feels when you blip it after it's warmed up. If it's dipping below idle, then turn them in 1/4 turn. 3.5 turns seems a little far out for stock intake when the idle mix screws come at 2.5 turns out stock.
Give it a try both ways and see which one feels better. |
March 25th, 2012, 07:22 PM | #210 | |
March 27th, 2012, 09:28 AM | #211 |
What's the difference between shimming your needles and increasing the jet size?
March 27th, 2012, 09:36 AM | #212 |
As there is more air going through your carbs, the slides move up. This increases volume and keeps the velocity of the air constant. Hence Constant Velocity carbs.
Your needles are attached to your slides. As the slides raise, the needles move up as well. As the needles move up and down, they move in and out of the main jet. At, WOT, the needles are completely out of the main jet. If you need more gas at WOT, you can raise the needles as much as you want, but it won't do a thing. The main jets are the only thing in charge of how much fuel is delivered at WOT. The needles are in charge of how much fuel is delivered in the mid-range of the throttle because that is where the slides are moving up and down. Make sense? |
March 27th, 2012, 10:53 AM | #213 |
Yes that makes complete sense. Thank you for that explanation! The reason why I was asking was because I was wondering if I would be able to shim my needles instead of increasing jet size since my idle seems to hang when I roll on the throttle and abruptly release. It's also still giving me conflicting readings though, I would hang, but also sag below normal idle if I blipped.
March 27th, 2012, 11:53 AM | #214 |
That sounds like an issues of the pilot jets, not the main jets.
have your carbs gotten dirty at all? try cleaning the idle passages really well with compressed air and and aerosal can of carb cleaner |
March 27th, 2012, 03:11 PM | #215 |
Do I take the idle screws completely out before cleaning?
March 27th, 2012, 03:13 PM | #216 |
March 27th, 2012, 04:54 PM | #217 | |
The throttle response is better too... I'll post a video and hopefully you can tell me if it's respOnding the way it's supposed to. |
March 27th, 2012, 05:02 PM | #218 |
WOOT!!! I thought 3.5 turns out with lean symptoms sounded odd
have fun riding |
March 28th, 2012, 06:19 AM | #219 | |
Now all I need to do is turn the idle mixtures back to stock and readjust from there. Are the dynojet and factory pro jets better than the stock by a lot or is the difference negligible? If I pull my air box I'll have to order another dynojet kit and that would cost me much more than if I ordered individual jets from jets r us. |
March 28th, 2012, 06:42 AM | #220 |
No worries. I can't ride except in the summer since I'm at school, so I might as well bum around on ninjette
The difference is negligible. If you're going to pull the airbox and replace it with a pod filter, get a pair of 108, 110, and 112 main jets. You'll likely want to get the next size up on pilot jet as well, but I'm not sure what size jet that is for a newgen. There's a link to the right kind of jet from jetsrus on the first post in this thread I believe. If you're going to delete the airbox and rejet, you should replace the screws on the bowls and caps of your carbs as well. The more jetting changes you make, inevitably you're going to strip some. They take m4x16 screws. I replaced all 16 on mine with stainless m4x16 hex head screws. |
March 30th, 2012, 02:32 PM | #221 |
Join Date: Aug 2011 Motorcycle(s): 05 Ninja 250 Posts: 68
Jetting help!
I have an 08 250 which is stock apart from a Hotbodies slip on. (No DB killer)
It runs like a pig until you clean it out above around 5K RPM. I know these things are clod blooded but this is ridiculous! Took the carbs off, cleaned them, added some sea foam to the gas all to no avail. I had a similar issue with a DRZ125 I had some time ago and went up on the pilot jet. Anyone have any suggested base line carb settings (main jet, pilot jet and air screw) for me to use as a base line? Thanks!! |
March 30th, 2012, 02:45 PM | #222 |
@expat, raise the needles by adding washers in 1 washer increments. That should richen your mid-range back up. With just a slip-on, you should be fine on the stock 98 main jets.
start with one washer. test ride. add a 2nd washer. test ride. add a third washer. test ride. add a 4th washer. test ride. go back to/stick with the number of washers that felt best and was the smoothest throughout the entire mid-range. |
March 30th, 2012, 04:20 PM | #223 |
Thanks!
I can try that but it feels more pilot circuit starvation... Will start with 2 washers tomorrow but anyone with a baseline other than washers, please post up! |
March 31st, 2012, 02:40 PM | #224 |
3 washers... running like a charm!!
Cheers for the advice! |
March 31st, 2012, 02:42 PM | #225 |
You're welcome. Glad to help
April 6th, 2012, 07:57 AM | #226 |
Join Date: Nov 2011 Motorcycle(s): Many Two Wheels .. Posts: 611
Can someone tell me what Factory Pro # does Dynojet # correspond to. A rough idea would help. (The size comparison is only available for Keihin, Mikuni, Dynojet)
[ex-AFM #828 | SMUSA #828 | Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers + OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com |
April 6th, 2012, 08:26 AM | #227 |
Join Date: May 2011 Motorcycle(s): 2002 ZZR 250 Posts: 127
Just thought I should inform everyone I found a really cheap place to buy screws for the float bowls! In us and canada! I was looking all over so I figured id save you guys some time.
http://www.fastenal.com/web/products...S2530014A20000 Sure beats OEM Price at my dealer... They want 4 bucks a screw.. 20 cents seems way better for a hex head |
April 6th, 2012, 08:57 AM | #228 | ||
THe DynoJet numbering varies slightly as you can see from the chart below. Quote:
April 8th, 2012, 02:49 AM | #229 |
Join Date: Feb 2012 Motorcycle(s): '10 Ninja 250 Racer Posts: 95
Does anyone know what the sportisi jet kit numbers correspond to?
#77 |
May 8th, 2012, 12:28 AM | #230 |
Join Date: Mar 2012 Motorcycle(s): 2009 NINJA 250R Posts: 40
May 8th, 2012, 07:49 AM | #231 |
Yep. If you don't believe me you can call factory pro to confirm.
May 8th, 2012, 09:38 AM | #232 |
YEAR: 2008
INTAKE MODIFICATIONS: air box removed. K&N R-0990 Filter EXHAUST MODIFICATIONS:Jardine RT-5 full system, Kleen air system removed JET KIT OR STOCK? Jet Kit BRAND OF JET KIT? Factory Pro Stage 2 MAIN JET: 115 NEEDLE AND CLIP POSITION: 4 (no shims) MIXTURE SCREW SETTINGS: 2-1/2 turns out from bottom, initially ELEVATION: 177 ft MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: Seems to be running good. In low gear pulls hard from the start all the way to redline. Higher gears it pulls real well from 6k to redline (at appropriate speeds vs gear). At start when cold needs a little choke to stay running, 2 minutes later no choke needed. Once I get the money I will take it to get dyno'd. |
May 24th, 2012, 01:41 PM | #233 |
Join Date: May 2012 Motorcycle(s): 2008 Ninja 250R Posts: 148
What jets do i need
YEAR: 2008 Ninja 250r
INTAKE MODIFICATIONS: K&N P/N "R-0990" EXHAUST MODIFICATIONS: MGP Growler Slip-on JET KIT OR STOCK? Stock I think BRAND OF JET KIT? Unknown MAIN JET: Stock I think NEEDLE AND CLIP POSITION: Stock I think MIXTURE SCREW SETTINGS: Stock I think ELEVATION: Around 700 ft MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP:
May 24th, 2012, 02:17 PM | #234 | |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
Not to be a jerk but this post is pretty useless...
If you're using the KN pods you really really should rejet the carb. You might be running lean which could harm your engine in the long run. Quote:
CVMA #55 |
May 24th, 2012, 11:20 PM | #235 |
I totally agree. If he was able to install the pods, he could have just cracked opened the carbs and took a look to see what was inside. Lol. He was just right there already!
May 29th, 2012, 11:06 AM | #236 |
Join Date: Mar 2012 Motorcycle(s): 2011 Ninjer 250, 2002 TL1000R, 2009 Concourse14, 2009 ZX6, 2006 SV650 Posts: 19
^ I think that bike must have been jetted (probably bought the bike already setup) I tried to ride mine for the heck of it with the K&N990 but not jetted yet...Didnt get anywhere, wouldnt rev at all.
May 30th, 2012, 08:05 AM | #237 |
Fighting Texas Aggie '05
Trying to put my bike back together after an off at the track and pulled the airbox during the tear down and a full exhaust is going on as well. I was debating on a jet kit or just buying individual jets. Any reason I can't just buy a set of 110s or 112s and 40 pilots to start with and use the stock needles? I have access to free stainless allen/hex screws so no benefit there.
May 30th, 2012, 08:26 AM | #238 | |
Join Date: Mar 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r Posts: 217
A jet kit should give a much better baseline to start with, make the process easier, and generally give better results. But, the DIY approach should be close enough for my street use.
June 1st, 2012, 06:55 PM | #239 |
Join Date: Mar 2012 Motorcycle(s): <2008 250R> Past Bikes:06 GSXR600 89 CBR1000 78 Hawk 400 86 Ninja 600R 86 & 87 FZ600 81 GPZ550 71 CB360T Posts: 228
Any body have any suggestion?
Here is my setup:
YEAR: 2008 INTAKE MODIFICATIONS: air box removed. K&N R-0990 Filter EXHAUST MODIFICATIONS: DanMoto GP Titanium slip-on, Catalytic converter removed from header, header shortened 4 inches, Clean air system removed JET KIT OR STOCK? Jet Kit BRAND OF JET KIT? 6 Sigma Racing MAIN JET: 117.5 PILOT JET: 40 VACUUM SLIDE: Additional hole with #59 drill bit VACUUM SLIDE SPRING: 1 loop cut off (1/8 inch) NEEDLE AND CLIP POSITION: 2 Shims per needle MIXTURE SCREW SETTINGS: 2-1/2 turns out from bottom ELEVATION: 0 to 500 feet MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: Bike seems to start and idle good, choke for a couple minutes, but then once warm and off choke it seems to have a very slight stumble or hesitation. So I'm trying to figure out my first move toward dealing with the lean issue. I will say that after the bike is fully warm and I'm at a steady RPM, say 8k or 9k, and bring the choke on 1/2 to 3/4 the stumble/hesitation goes away. Thanks for any help!
Have you ever read the King James Bible? To say speed kills is akin to saying guns kill, neither of which is true. |
June 9th, 2012, 11:56 PM | #240 |
so should i do DynoJet or Factory Pro ?
the dyno jet kit i saw according to the reviews has a 100 main jet do you guys know which ones it comes with and if the 2011 and 2011 ones would be the same or different? |
Jetting Database | kkim | 2008 - 2012 Ninja 250R Tech Talk | 166 | June 26th, 2023 03:36 AM |
Fuel Injection Map Database - Discussion Thread | Sonofswin | 2008 - 2012 Ninja 250R Tech Talk | 63 | May 20th, 2017 05:38 AM |
Where's the Factory Pro jetting database for pregens? | mr2peak | 1986 - 2007 Ninja 250R Tech Talk | 3 | May 5th, 2014 09:02 AM |
When is the iPhone 5 coming out? (Discussion Thread) | Jiggles | Off-Topic | 95 | November 6th, 2011 10:40 AM |
Ninjette.org Logo Discussion Thread | Alex | Forum Information | 89 | February 16th, 2009 04:06 PM |
