August 21st, 2012, 09:23 PM | #1 |
Join Date: Sep 2011 Motorcycle(s): '09 Ninja 250R, '06 636 Posts: 89
Bags-Connection Blaze Sport Saddlebag System
I'd seen these used before by a couple of people at my job(I work at a conference facility and the Maryland Motorcycle Dealer's Association is one of our clients) and decided to go ahead and purchase them and review them for myself. This isn't a DIY, but there is some assembly required for the support system. It's pretty straight forward with a key code for the bolts in the instructions. I purchased them from twistedthrottle.com
The box: Bags: Content: Assembly: Mounted: And girlfriend approved: It took about an hour with crappy picture taking along the way to put everything together. I'll have my first commute with them tomorrow. Initial impressions are that they are of pretty high quality and fit well. Some adjustment required to secure them, but once in place, they aren't going anywhere, in any direction. They are compact and storage space when expanded is decent. Not huge storage capacity, but enough for my work clothes, shoes and aforementioned beverages. And they go on as easily as they come off. Overall, I'm impressed, but only time will tell if they were worth the money. Last futzed with by mholme; August 22nd, 2012 at 04:38 PM. Reason: Bad link |
August 22nd, 2012, 04:44 AM | #2 |
Nice! I look forward to some additional feed-back.
August 22nd, 2012, 07:59 AM | #3 |
Join Date: Aug 2011 Motorcycle(s): Honda Elite 110 (deceased), Green 2012 Ninja 250 (sold on Pi day); Grey/Green 2019 Ninja 400 ABS Posts: 238
I actually ordered these first, but TT were backordered, so I adjusted my order to the Alu-Rack and Coocase.
I'm happy to have helmet storage but the Alu-Rack was definitely more work to put together! |
August 22nd, 2012, 08:23 AM | #4 |
I must say... This is a pretty nice system!
August 22nd, 2012, 09:04 AM | #5 |
Join Date: Dec 2009 Motorcycle(s): 2009 Ninja 250R Black - Sold / 2011 Honda CB1000R Posts: 176
I looked at these myself for awhile but I just cannot justify them especially for the cost. They recently just raised all there prices nearly $50.00 as well. Really, over $300 for soft saddle bags which offer no security?
I can also steal those in about 5 seconds and it even has a clever handle so I don't drop them as I run away. In my opinion there is only (1) option to motorcycle luggage. Go hard or go home. Locks or bust. Unless you like taking that **** off every time you leave the bike! It might work for some people but not I. Plus, I don't care how non-scratch the underside of the lay over strap is. It is going to scratch. Luggage should never touch the body of the bike. I'm sure they'll include those clear 3M protective stickers but still.....ugh...
2009 Black 250R - Stock and staying that way. No matter what you do it's still a 250 at the end of the day! Save your money for gear, riding lessons, & a 600cc |
August 22nd, 2012, 09:50 AM | #6 |
All good points you make when considering this system. And yes they did include protective backing.
For me, I bought them strictly for commuting to work, so there is zero chance they are getting stolen. Unless someone breaks into my office. I have no intention or desire for a fixed hard luggage system. The great thing about these is that they do go on and off in seconds. Like you said, not ideal for everybody, but this is a much better alternative for someone like me who has been commuting with a back pack. Posted via Mobile Device |
August 22nd, 2012, 09:57 AM | #7 | |
Join Date: Jul 2012 Motorcycle(s): Ninja250r(2012PR) Posts: 86
Personally I live in a small town, you're usually pretty safe leaving your helmet and whatnot on your bike. When I move maybe I'll change my luggage priorities but right now, these are exactly what I'm after. Plus like it or not, soft luggage is easy while most hard luggage options either change the size of the bike in a way you'd have to seriously think about or require more than a wee bit o the wrench.
Turn around at half a tank |
August 22nd, 2012, 10:46 AM | #8 | |
August 24th, 2012, 10:07 PM | #9 |
R.I.P. to Dereck at twistedthrottle. I went to post some positive feedback at the site yesterday and saw that he had passed. I'll add more info from my experience with the bags soon, although I will say that nothing much has changed from my initial impressions.
March 4th, 2013, 09:52 PM | #10 |
Java Junkie
Join Date: Nov 2011 Motorcycle(s): 2011 Ninja 250R and 2012 Suzuki DL650 V-Strom Posts: 47
I have these same bags and would like to make a few pro and con comments about them.
Pros: First off, these bags go on and come off in seconds. Really slick! I also like that everything except the quick release bracket can be removed making the bike appear stock. The hardware is excellent quality. Can be used with a passenger. These saddlebags match well with my Nelson-Rigg tail bag. Cons: The reflective piping isn't very bright. The protective rubberized material on the exterior side that touches the bike isn't very durable and wears out easily due to rubbing/friction. The bags will damage the plastic seat assembly due to rubbing. (I place some thin foam rubber in between the bags and the bike to prevent this damage.) The outside zippered pockets hold very little. The "waterproof" removable pouches are not designed to cover the outside of the bag but are made to keep your items inside your bags dry. A bad design IMO because the bags get wet and dirty and need cleaning and drying out if riding in inclement weather. It would be much easier to clean a slip on outer cover and keep your bags dry rather than using an interior pouch. Last, but not least, this system is expensive! |
Blaze Sport Saddlebag System for 300 (side brackets?) | LittleRedNinjette | Items Wanted | 0 | November 17th, 2014 01:58 PM |
SW-MOTECH Bags-Connection Blaze Sport Saddlebag System | gogoKawi | Motorcycle-related | 8 | May 30th, 2014 04:09 PM |
[twisted throttle] - Aero Sidecase System from Bags-Connection | Ninjette Newsbot | Motorcycling News | 0 | January 9th, 2012 11:00 AM |
[motorcyclistonline] - SW-Motech Bags-Connection Blaze Saddlebags | MC Tested | Ninjette Newsbot | Motorcycling News | 0 | December 29th, 2011 08:00 AM |
[webbikeworld.com] - Bags-Connection Sport Panniers | Ninjette Newsbot | Motorcycling News | 0 | February 19th, 2011 06:40 AM |
