Old March 27th, 2013, 09:39 PM   #41
Dragonracer76
Dragonracer76's Avatar
I know it's legal in Cali. Still pretty dangerous.
Beards make everything better. ATGATT
Dragonracer76 is offline   Reply With Quote
Old March 27th, 2013, 10:22 PM   #42
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
My parents aren't legally responsible for me anymore, but I still wouldn't want them to see me lane-splitting because they'd probably freak out. Being legal doesn't make it any less dangerous.
Old April 8th, 2013, 07:29 PM   #43
mjegan
Motorcycle(s): 1999 Ninja 250
I've recently purchased a Trail Tech Vapor an am curious about the positioning of the magnet for the speed sensor. Did you replace one of the brake disc mounting bolts or did you attach a magnet directly to the disc itself?
mjegan is offline   Reply With Quote
Old April 8th, 2013, 07:44 PM   #44
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Magnet bolt, with a matching nut, bolted through one of the brake disk slots. You can also glue a
rare earth magnet to the disk, or just rely on it's magnetism to keep it there.
Last futzed with by Chicagobob; April 15th, 2013 at 09:14 AM.
Chicagobob is offline   Reply With Quote
Old April 8th, 2013, 10:12 PM   #45
UnshavenCanuck
UnshavenCanuck's Avatar
Motorcycle(s): 2005 Ninja 250
Look into getting some magnets that koso kits come with. I recently installed the rx-1n on my 05 and it came with 6 tiny magnets that fit right in the 5mm Allen holes in the disc bolts. Just make sure you put them the right way (north out). Now if only the tach wasn't so jumpy
UnshavenCanuck is offline   Reply With Quote
Old April 9th, 2013, 05:30 AM   #46
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Did you ground the gauge straight back to the battery? If not, give that a try and see if it helps with the jumpy tach. I had to do this on my Hawk with a Koso gauge.
k-os is offline   Reply With Quote
Old April 9th, 2013, 02:26 PM   #47
UnshavenCanuck
Yes I grounded straight to the battery, thanks though. My best result to reduce jumpiness was solder a 100k resistor in line of the tach. It gave me a pretty accurate idle rpm of around 1200 but it's still jumpy at higher rpm. Not too big a deal I have faith in my ears, speed and mileage was what I was concerned with
Old April 9th, 2013, 02:35 PM   #48
Chicagobob
Chicagobob's Avatar
Trail Tech recommends a 600K .25W resistor, and they sell a tach lead with one installed. I use one, and my tach isn't jumpy at all. I wired the red resistor wire to the bike's black tach wire and the black ground wire to the bike's accessory ground wire. All this is inside my headlight bucket.
Last futzed with by Chicagobob; April 15th, 2013 at 07:05 AM.
Old April 9th, 2013, 03:16 PM   #49
alley
Motorcycle(s): 1999 ex 250
What tail light is that? Where did you get it? How is the light output?
alley is offline   Reply With Quote
Old April 9th, 2013, 06:17 PM   #50
Chicagobob
Chicagobob's Avatar
It's just a Chinese light I found on Amazon. Pretty bright, and weighs next to nothing. Search "LED motorcycle taillight."
Mine was:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Last futzed with by Chicagobob; April 10th, 2013 at 04:47 AM.
Old May 8th, 2013, 04:56 PM   #51
mjegan
The bolt that came with my kit slides right through the brake disc slots. We must've got different parts.
Old May 8th, 2013, 08:29 PM   #52
Chicagobob
Chicagobob's Avatar
Yes, you are right. I just looked at my brake, and I remembered it wrong. In this photo, you can see the bolt on the brake disk, near the bottom.
Last futzed with by Chicagobob; May 9th, 2013 at 07:39 AM.
Old August 12th, 2013, 08:57 AM   #53
Chicagobob
Chicagobob's Avatar
Pics of pregen Trail Tech Vapor mount
Some folks have asked for details of how we mounted the Trail Tech Vapor to the steering lock housing, so here they are:
We trimmed the lower tab of the Trail Tech mount, ground it thinner, and slipped it under the shroud. You can bend the mount to get the viewing angle you want:
Then we drilled through the whole thing and screwed in a couple of small bolts (which really aren't the right type, but they were the only small stainless bolts we had at the time):
You can see that the gauge is very close to the headlight (so much so that the air temp usually reads high from the headlight's heat), and that it could have been mounted directly to the headlight bucket with spacers.
Hope this helps.
Last futzed with by Chicagobob; August 15th, 2013 at 06:55 AM.
Old August 12th, 2013, 09:34 AM   #54
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
looks great! i LOVE that plate you made for the seat. LOVE IT!
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
7oxSin is offline   Reply With Quote
Old August 14th, 2013, 11:27 PM   #55
Nice work!
Old September 30th, 2013, 04:53 PM   #56
Obje0110
Motorcycle(s): 2004 Kawasaki Ninja ex250
my name
Originally Posted by StephenA View Post
this bike is beautiful
Last futzed with by Obje0110; October 5th, 2013 at 11:57 AM.
Obje0110 is offline   Reply With Quote
Old October 5th, 2013, 11:56 AM   #57
Obje0110
tach readings
hey,
how did you wire your tach?
my indicator lights keep flashing as soon as I start the bike.
i followed @skilletmo write up to a T and Im wondering if with his bike being newer i did it in correctly.
Old October 5th, 2013, 03:20 PM   #58
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Originally Posted by Obje0110 View Post
hey,
I took the tach wire and inserted it into the left coil input. I think a 600k ohm resistor keeps the signal less jumpy. If you didn't get that with your wire you can either make one or ask them to send you one. If you need help making it yourself let me know.
Mods: Offset clutch pressure plate
Old October 5th, 2013, 08:14 PM   #59
infinitewhiskey
meh
Motorcycle(s): 2002 EX250F Cafe/Streetfighter Project
+1 on this. But my tachs perfect.
The resistor cable part number is part 7000-1004 I believe. You'll have to call them and pay for it and for shipping. ~$10 USD, give or take.
SoCal 626/951
instagram | youtube | modifications
infinitewhiskey is offline   Reply With Quote
Old October 28th, 2013, 07:41 AM   #60
Chicagobob
Chicagobob's Avatar
New handlebar for the ultralight pregen
You may remember our lightened 2006 Ninja 250. We removed most of the bodywork, detabbed the rear subframe, and replaced the lights and gauges with aftermarket items. All this reduced the bike's weight by about 30 lbs.
We've long wanted to switch to a tubular handlebar for this bike, so we could lower the front end a little, and take advantage of all the different 7/8" bars that are available. Also, we wanted wider bars than stock.
We had a Renthal ultra-low handlebar in the shop, and a pair of Outlaw Racing bar mounts, so after a lot of measuring, we drilled the triple clamp and got to work. There's not much to work with on the pregen triple, unless you are able to fab something to translate the stock mounting holes to 7/8" bar mounts, so we decided to just drill two holes in the center section and mount the risers there. We placed a couple of nylon buttons under the mounts, and rubber spacers under the nuts that secure the risers under the triple clamp.
Seems to have come out well, and I like the feel and look (my daughter hasn't tried it yet, but she thought the clipons were "a little reachy," as she put it. If we decide to switch back to clip-ons, we can plug the new holes with plastic covers.
The Renthal bar is lightweight and has good vibration-absorbing properties, so the absence of bar-end weights doesn't seem to be an issue. The width feels good. The bike is probably too sensitive to rider inputs with the front this low, especially with wider bars, so we'll probably raise the front 1" to 1.5" from what is shown in the pics. We wanted to see the maximum before making final adjustments.
Last futzed with by Chicagobob; October 31st, 2013 at 12:27 PM.
Old October 28th, 2013, 09:41 AM   #61
MaxxVE
Motorcycle(s): 2006 Ninja 250
Wow.. Great looking bike! Well done.
MaxxVE is offline   Reply With Quote
Old October 29th, 2013, 08:08 PM   #62
Still looks great.
Old February 21st, 2014, 09:10 PM   #63
bhalv
Motorcycle(s): 93 ninja 250
what did you do as far as eliminating the stock speedo cable?
bhalv is offline   Reply With Quote
Old February 21st, 2014, 09:22 PM   #64
Chicagobob
Chicagobob's Avatar
Just left the speedo drive in place on the wheel, with a plastic hardware store cap on the cable outlet.
Old February 21st, 2014, 09:49 PM   #65
Josh_kcco
Josh_kcco's Avatar
Motorcycle(s): '04 Ninja 250R
Awesome!!!!!!
Josh_kcco is offline   Reply With Quote
Old February 21st, 2014, 10:11 PM   #66
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Wow, this is one of the best looking pregens that doesn't belong to choneofakind (who owns the best all around pregen that I know of) beautiful build, well done. I especially love the addition of the renthal bars, it's so easy to just throw a pair of clip-ons on there but that's not really comfortable for daily riding or riding when you aren't being really agressive. The renthal bars solve the problem of the stock bars not looking quite right and make it more useable at the same time
Old May 11th, 2014, 07:28 PM   #67
dukeswift
dukeswift's Avatar
Motorcycle(s): 02 Aprilia RS70 97 Ninja 250
Nice!
dukeswift is offline   Reply With Quote
Old May 16th, 2014, 01:01 PM   #68
Lllewis87
Motorcycle(s): 04 ninja 250
I really like your build. I have started mine and I hope it comes out as nice as yours. The only major difference with mine is I am going to try and retain the stock gauges. Thanks for the inspiration. Great looking bike!
Lllewis87 is offline   Reply With Quote
Old May 17th, 2014, 12:54 AM   #69
Tenacity10
Motorcycle(s): 1986 Kawasaki Ninja 250r
All the fast ones switch to a lighter, sexier, full system
Tenacity10 is offline   Reply With Quote
Old May 19th, 2014, 09:26 PM   #70
mehendrak
Nice looking bike! I like the style and color! Mind telling me which model headlight/turning light you got, and where did you purchased it? Thanks!
mehendrak is offline   Reply With Quote
Old May 20th, 2014, 08:30 AM   #71
Chicagobob
Chicagobob's Avatar
It was from Speedmotoco.com, but the same light is available all over the internet. It uses a standard 7" reflector with an H4 bulb, and has a steel bucket. Build quality is good, and it provides a very good beam.
Old June 5th, 2014, 05:35 PM   #72
Chicagobob
Chicagobob's Avatar
Did 90 mph on some farm road
Daughter reports seeing 90 mph on some farm road this afternoon riding with wealthy friend with Yamaha R1. Couldn't believe it until I checked the Trail Tech telltale. I'm glad she was able to do it, and safely(?), but told her I wouldn't recommend it (although I did the same on bike with far inferior tires and brakes in the late '70s - 130 on a GS1000G on the North Dallas Tollway at 2 am).
Old June 5th, 2014, 05:41 PM   #73
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Daughter reports seeing 90 mph on some farm road this afternoon riding with wealthy friend with Yamaha R1. Couldn't believe it until I checked the Trail Tech telltale. I'm glad she was able to do it, and safely(?), but told her I wouldn't recommend it (although I did the same on bike with far inferior tires and brakes in the late '70s).
a lot of farm roads are long straights so this makes sense, that said it should have a bit more than that left in it with a light rider. I'll do a top speed run w/gps on my 250 once I've got it street legal this fall
Old June 5th, 2014, 08:57 PM   #74
UnshavenCanuck
My first run this year I hit 97mph with the recent weight drop on the bike and myself. I figure I've shaved about 60 lbs from last year. 30 off each and I'm still hovering around 200lbs. Had her dyno tested for fun when a buddy was gettin his Harley tuned. 30 horsepower runnin rich. Got some input to raise the needles one clip and drop a few jet sizes, now for a long country road to hit the ton lol
Old June 10th, 2014, 03:13 PM   #75
ds650rida
Motorcycle(s): 636 250r
This build gave me a lot of inspiration for mine. What brackets are you using for the headlight?
ds650rida is offline   Reply With Quote
Old June 10th, 2014, 03:32 PM   #76
mehendrak
Im doing the same build as Chicagobob, Im not sure what the fork width is, but I used this bracket to mount my headlight.
Old June 10th, 2014, 03:47 PM   #77
ds650rida
The ones I used were from ebay and look about the same as those. They hardly have anything holding them together where the clamp meets the slot. And I had to bend them to make them work. Very crappy quality. Thats why I asked.
Old June 10th, 2014, 04:04 PM   #78
mehendrak
Yea I agree its not the best quality but they do the trick. I didnt have to bend it my bracket.
Old December 2nd, 2014, 08:21 AM   #79
Jetfoi
Jetfoi's Avatar
Motorcycle(s): 2013 zx6r and 1995 250r
Nice and clean good job!
Jetfoi is offline   Reply With Quote
Old December 4th, 2014, 09:33 AM   #80
Jetfoi
Jetfoi's Avatar
@Chicagobob did you cut the side fairings to make them shorter?
spend all the spare time on two wheels
Lightening her up Chicagobob 1986 - 2007 Ninja 250R Tech Talk 57 October 7th, 2014 10:55 AM
[RoadRUNNER] - The Lightening LS-218 the Electric Superbike Ninjette Newsbot Motorcycling News 0 May 26th, 2014 03:01 AM
[motorcyclistonline] - VIR Cancels Suzuki White Lightening Nationals, AMA Pro Road Ra Ninjette Newsbot Motorcycling News 0 July 11th, 2011 07:30 PM
[superbikeplanet.com] - VIR Decides No DMG: "White Lightening" Indeed Ninjette Newsbot Motorcycling News 0 July 11th, 2011 04:30 PM
[superbikeplanet.com] - MotoGP: Thunder & Lightening On The Grid Ninjette Newsbot Motorcycling News 0 March 16th, 2010 09:50 AM
