Go Back   ninjette.org > General > Pictures
Old October 29th, 2012, 08:20 PM   #1
Cool Zx coil over plugs
They work great
Old November 6th, 2012, 10:31 PM   #2
Snazzy.
Old November 6th, 2012, 10:57 PM   #3
KELPHYN
KELPHYN's Avatar
Notice any difference performance wise?
Old November 15th, 2012, 06:20 PM   #4
none what-so-ever; as it should be. the difference is merely in how much space the coils take up... this way, they dont take up any extra space. it's kinda more of a farkle for engineers i guess... not really any benefit outside of saving a few ounces and the space (and how it looks)
although i did blow up my engine at the track a few weeks after putting them in, so maybe it was related :P :P
Old November 15th, 2012, 07:09 PM   #5
I think they look sick. I like your valve cover too. I want to paint mine black next time it's off in the spring. Plain old high temp paint? Any surface prep?
Old November 15th, 2012, 09:23 PM   #6
KELPHYN
KELPHYN's Avatar
Just thought they might help with top-end if they had a higher output.
Old February 7th, 2013, 10:49 AM   #7
cuong-nutz
cuong-nutz's Avatar
What year ZX10r plugs did you use? Are the ZX6r plugs the same? Does different redlines of the two bikes affect characteristic of the plugs?
HalfFast Racing Team
Old February 7th, 2013, 11:41 AM   #8
its from an 05 06 zx636. it is from a CDI ecu which is a requirement for that type of coil (the 250 is also CDI, not TCI or others which will NOT work with a cdi ignition system)
the gains from this type of coil comes from the lowered resistance going from the collapsing field into the output coil and into the plug... if you look up joules law you'll see as you lower that resistance, you get higher inductance joules going through the plug for the same amount of charge current (from cdi) which means the spark is hotter and will last slightly longer. just make sure the coils are suited for the type of plugs you use otherwise you could melt a plug. (the 05 kawi 636 uses the same plugs as the 250)
Old February 7th, 2013, 12:44 PM   #9
Alex, post 8 was great. Thanks for the explanation.
Hotter spark that lasts longer means longer burn or more consistent burn or...? Sorry, I'm still figuring out that part.
Old February 7th, 2013, 12:59 PM   #10
well so if you have a weak spark, you are only igniting a part of the fuel, and then that fuel ignites the rest. if you put more joules through the plug (joules is basically heat... factor of power over time) then the spark contributes to igniting more of the fuel. if you are running very high RPM with high compression (lots of other circumstances but these effect it the most) then its possible to complete the burn cycle while still having unburnt fuel. having a hotter spark can start the combustion faster, which means you are able to get a more complete burn. more fuel burnt, more power output.
Old February 7th, 2013, 01:10 PM   #11
Again, thanks. That helped.
Is the difference noticeable at the top end or is it fairly minimal? I assume these aren't too pricey.
Old February 7th, 2013, 01:46 PM   #12
for a stock setup, the difference shouldn't be obvious as the stock coils are "good enough". but when you get into higher performance stuff like changing timing and compression, you can get larger changes. racerx has takai coils (better than zx coils) and is running much higher compression and agressive cam and ignition timing and will be doing a dyno with them at the end of the month so follow his thread for the results.
Old August 27th, 2014, 09:28 PM   #13
cuong-nutz
cuong-nutz's Avatar
Was searching up aftermarket ignition coils: http://motor.otomotifnet.com/read/20...i-Ninja-250-F1
Old August 28th, 2014, 10:38 AM   #14
micoulisninja
modaholic junkie
Alex do you believe it would make a difference on the FI models too ??
Old August 28th, 2014, 11:37 AM   #15
i think it makes very little difference in either unless you are running very aggressive timing. also, my understanding of the way the system works when i wrote that was slightly naive. i believe the most important aspect is how quickly the field is able to collapse into meaningful heat, and stay in a range that the plug is designed for. and how reliable the size of the field is so you don't over-charge the field and burn electrodes. (ie- what other influences are having an effect on the field near the coils, as well as the charge going into the coils before they collapse... so cdi is another big part of it as well as proper voltage regulation)
Old August 29th, 2014, 07:55 AM   #16
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
I like it, one less thing in the way lol.
Old April 6th, 2015, 02:21 PM   #17
cuong-nutz
cuong-nutz's Avatar
Found this info on the line and decided to dump this here for reference.
Just a quick FYI,
Thanks to original poster on ZXROA.
The coils that work for the mod must be 5 in. long and have aprox.
resistance of 1.3-1.5 ohms ea., here's some info I got, will update.
These are the p/n's and years that work, any other may not work.
Suzuki GSXR: 1000 (01-07), 750 (01-05), 600 (01-03)
oem p/n 33410-35F10/35F00 (Denso p/n 129700-4400/4150)
4400/1.5 ohms, 4150/1.3 ohms
new aprox. $69
Kawasaki: ZX10/14 (04-07) oem p/n 21171-0005/1.5 ohms
ZX9 (99-03) + ZX12 (03-05) oem p/n 21171-1265/1286
Z1000 (03-07) + Z750 (05-06) 21171-1286
Z1000 denso p/n 129700-4580/1.5 ohms
ZX6 oem p/n 21171-1282/mitsubishi#F6T560
ZX9 denso p/n 129700-3630/1.3 ohms
ZX10 mitsu.#F6T549/560
ZG14/08(Concours) # F6T560
Old April 6th, 2015, 06:53 PM   #18
Ghostt
Ghostt's Avatar
interesting I may have to put this on my list of things to do. I like the idea of eliminating the plug wire, as one less thing to go wrong
So from what I'm understanding it's a Plug-N-Play install?
violente et ignorantia
ZX-2R BLOG
Old April 6th, 2015, 09:07 PM   #19
the connectors for the stock ninja 250 coils are those old school crimp on connectors. the zx style plugs use a little two wire connector thing... so its hard to connect the coilovers without the right connectors.
Old April 7th, 2015, 09:04 AM   #20
Ghostt
Ghostt's Avatar
Okay thanks, seen some on eBay, that also includes the wiring harness,
ZX-2R BLOG
Old April 7th, 2015, 10:46 AM   #21
garth285
KAWASAKI GURU
garth285's Avatar
I am using the ninja 300 coils on my turbo 250, they fit very nice as well.
Old April 7th, 2015, 11:41 AM   #22
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Are those compatible with the pregen/negen ignition? also what type electrical plugs do they use?
My Cafe Racer Build
My intro post
Old April 7th, 2015, 03:58 PM   #23
garth285
KAWASAKI GURU
garth285's Avatar
Not 100% they are basically the same as the zx6 coils though so I'd imagine so.
Old April 7th, 2015, 05:30 PM   #24
crazymadbastard
<3
My Cafe Racer Build
My intro post
Old October 30th, 2015, 04:26 PM   #25
Ghostt
Ghostt's Avatar
I've done this modification, and a write-up on the subject,
https://www.ninjette.org/forums/blog.php?b=8379
ZX-2R BLOG
Ground to coil? nickadolph 2008 - 2012 Ninja 250R Tech Talk 16 June 7th, 2013 05:28 PM
Coil Wiring indr 2008 - 2012 Ninja 250R Tech Talk 13 June 5th, 2013 09:23 AM
coil question MaliZ 1986 - 2007 Ninja 250R Tech Talk 3 March 19th, 2013 03:09 PM
Coil wiring? expat 2008 - 2012 Ninja 250R Tech Talk 2 February 26th, 2012 07:57 PM
