Old December 13th, 2012, 12:31 PM   #1
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
Bazzaz for 300
OK, just got word Bazzaz finished the tuning for the 300, looks like it improved the low and mid-range power a bit, I'm anxious to feel the difference, but bike is still in bent pieces and its pouring down rain.
A few have asked to see the Dyno, so here it is:
Jason @ Bazzaz said they're still going to develop a quickshifter and TC for the 300 as well. . . .
JBinSD is offline   Reply With Quote
Old December 13th, 2012, 12:44 PM   #2
old3
Am I reading that wrong or is there really no big difference there? Is that with a totally stock bike?
old3 is offline   Reply With Quote
Old December 13th, 2012, 12:45 PM   #3
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
So, Bazzaz tuned your bike to produce 32HP??? No other mods? Or was this a ICU upgrade?
I'z confused.
Don't they already produce 32HP at the wheels (stock)?
Old December 13th, 2012, 12:59 PM   #4
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
unrelated - how's the frame on the 300? Is everything that's smashed easily replacable? Forks okay?
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old December 13th, 2012, 01:40 PM   #5
tuan3742
tuan3742's Avatar
Motorcycle(s): 13' zx-6r 636
stock tune on the 300 was said to be tight already. although there is no top hp gain, there's a 1hp gain between 7-10k rpm
Yes, I'm a squid. But it's okay, I love squid, so can you
tuan3742 is offline   Reply With Quote
Old December 13th, 2012, 03:20 PM   #6
lgk
the HP might be similar but the bike could behave differently in terms of throttle sensitivity, response, or other factors.
you'll have to ride and see how it goes.
being a stock bike i didn't think you could get much power with a similar AFR.
i think there would be more difference in a rich map.
Old December 13th, 2012, 03:33 PM   #7
JBinSD
Yeah, didn't really give it as much as I hoped for, but smoothed out the powerband a bit in low and mid ranges, and yes, it only had a Yosh slip on, so a full system should help a bit too.
Old December 13th, 2012, 03:53 PM   #8
lgk
well it is hard to beat physics, lol.
the good thing is that the bike will be smoother and more responsive.
if you do get an intake/exhaust you can get it tuned easy.
Old December 13th, 2012, 05:45 PM   #9
The Bazzaz guys must have done that fuel map with a completely oem bike.
Here's Area P's results for reference:
http://www.ninjette.org/forums/showp...&postcount=144
Looks like the closest thing they did to a stock bike with fuel tuning was snorkel delete and drop-in filter in place.
Old December 13th, 2012, 06:13 PM   #10
JBinSD
yeah, those graphs are hard to read, but it seems with a snorkel delete and K&N filter, you can get 4 more horses and an extra lb with just fuel mapping.
Since there's no SS for the 300 @ Chuck, kinda makes a guy wonder why he would suffocate his ride. . . .
Old December 13th, 2012, 06:24 PM   #11
Look at it this way: there's already a solid map sorted out for the airbox with snorkel. Take the snorkel out and get a new map made. Then if the guys in charge of the racing ruled decide you need a snorkel, it will take 5 minutes to put the snorkel back in and load the map required for a snorkel on the airbox.
That's the biggest benefit of FI.
Old December 14th, 2012, 09:37 AM   #12
Ryephile
Ryephile's Avatar
Motorcycle(s): '13 Ninja 300 :: Pearl White
A bit strange, I can't say I'm terribly impressed. Why did they settle on losing power from 11k to redline? They probably over-adjusted the AFR and were too stubborn/lazy to dial it in better. At least they picked up a LbFt in the midrange, but that's also where the stock mapping is richest [low hanging fruit].
Did they also tune the ignition, or just fuel?
Ryephile is offline   Reply With Quote
Old December 14th, 2012, 02:39 PM   #13
bdavison
Wartown, USA
bdavison's Avatar
That map is what I would consider to be just a tolerance +/- map of the test equipment....in other words not enough appreciable gain to even show that anything happened.
Old January 22nd, 2013, 01:39 AM   #14
cory jordan
Motorcycle(s): 2012 kawi 250r
from what i read, they stray away from ignition tuning, as they feel its not something a regular bike needs, and they try to focus on the a/f to produce a better powerful bike.
*clearly they go hand in hand.*
Originally Posted by Peanut_EOD View Post
I didn't say throw it on the ground. I said drop it. I suggested neglect not abuse!
cory jordan is offline   Reply With Quote
Bazzaz Z-Fi Tiane 2008 - 2012 Ninja 250R Tech Talk 13 May 13th, 2013 05:01 AM
[motorcyclistonline] - Bazzaz Z-Fi-TC | MC Tested Ninjette Newsbot Motorcycling News 0 January 20th, 2012 07:50 PM
[motorcycle.com] - Bazzaz Z-Fi MX for Suzuki RMX450 Ninjette Newsbot Motorcycling News 0 July 30th, 2010 08:30 PM
