January 11th, 2013, 01:46 PM | #1 |
Jigglin' your Jiglets
MOTM - Apr '13
Suspension Issue: Bike Stands Up In Turn
Sure wish there was some general tech section to put this that wasn't limited to 250s hint hint wink hint wink
I was just going to pm Jason to help me on this but I figure I'll post it in case some other stupid idiot can learn from it. And hey, maybe one of you stupid idiots will have some insight as well! N E weigh The Issue When I'm in a turn with my ninja 1000 the bike wants to stand back up, i.e. the front wheel is trying to turn into the turn and bring the bike back up. I have to maintain a constant pressure on the inside bar in order to hold the line. If I try to be weightless on the bars the bike will right itself back up. Another interesting aspect is that this is more noticeable on left turns than on right turns. Left turns require more pressure to stay turning. Observations This happens at any speed and on any radius turn, even very mild bends. The more I lean the more severe it is and the more pressure is required to hold the line. I should also note that initiating a turn on this bike is extremely easy, even easier than on the 250. I attribute this phenomenon to the higher bars and much steeper rake (the rake is steeper than even the zx10 ) If I accelerate hard in a turn then the pressure required becomes less severe. My 250 doesn't do this, I can remove pressure from the bars and it will hold its line without any input. Solutions Here's what I've tried so far. Keep in mind the issue isn't fixed, just less severe with each modification.
Bike Setup Front Preload: 12/15 Rear Preload: 8/10 Front Tire: 120/70 Rear Tire: 190/55 At this point I'd like to ask @rojoracing53 to ride my n1k and hopefully through his myriad of complaints "I hate kawis, the shifter sucks, the brakes suck, its too heavy, its too fat, the slipper clutch is crap ", hopefully, I can figure out the problem. Maybe its supposed to behave this way? Maybe I'm imagining the left feeling different from the right? Maybe a new front? Maybe maybe maybe, who knows but maybe he can help The goal is to get the bike to require no steering input while turning If anyone else has suggestions I'd be happy to hear them. However, if all you've ever ridden is a 250 then you are useless and should feel terrible about yourself.
January 11th, 2013, 01:56 PM | #2 |
hmmm.... this sounds strangely familiar.
Possibilities: Front brake dragging Warped rotor Heavy throttle hand maybe
January 11th, 2013, 02:03 PM | #3 |
MOTM - Apr '13
Heavy throttle hand nah, bike has 2000 mi think it could have a warped rotor already? How would I tell if the front brake is dragging?
January 11th, 2013, 02:07 PM | #4 | |
What it sometimes comes down to is tire profile. How rounded it is, whether it is smoothly rounded or more sharply angled, has a large effect on steering feel and front end behavior when leaned over. Different bikes respond differently to different tire setups, and different riders prefer different profiles even on the same bike. Michelin makes different front tires with the same compound to deal with things like this, some more rounded and some called V profile (which as may be guessed, is more pointed rather than rounded). What front tire is on it now, the OEM? Which 190/55 did you put on the back?
January 11th, 2013, 02:12 PM | #5 |
MOTM - Apr '13
I got an S20 for the back, the front is still OEM (bt016 I believe) though they did try talking me into another s20 for the front, saying that it would help things even more (I wasn't so sure about that so passed it up for now)
As they explained it to me, the reason the 55 series felt much better is because it raised the rear. I was also told thats why increasing the rear preload to 8 made it feel better and even though the sag is correct right now, raising the preload to 10 and thus raising the rear some more should make it feel better. Although now I'm wondering, is this working towards fixing the problem or simply countering the symptoms of the problem.
January 11th, 2013, 02:29 PM | #6 |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
Ive read raising the front 5mm helps a lot too, i dont push the bike hard yet so i dont pay enough attention to the settings. Its def not as easy to handle as the 250, and im not gonna switch tires until the stockers are done, im too poor to throw away a good set.
January 11th, 2013, 02:30 PM | #7 | |
I have run both your every day street tires with a more round profile and the cups (V profile). My bike (R6) holds it's line with either tire. Just throwing that out there for comparison.
January 11th, 2013, 02:31 PM | #8 | |
MOTM - Apr '13
I've heard its a common problem on the n1k though it is usually remedied by a 55 rear. My problem got better but still persists
January 11th, 2013, 02:33 PM | #9 | |
Fast-Guy wannabe
MOTM - Jan '13
I'm off work now but still at the shop for the next few hours finishing up my front brake mod. So I didn't read the whole post yet but I will later. Bring it on over and ill ride your ***** like I stole her |
January 11th, 2013, 02:34 PM | #10 | |
MOTM - Apr '13
Talking to the ex-AMA guy, he said stuff like I'm experiencing tended to be more common with people on 1000s who came from 600s. I think he was talking more about racing though whereas this happens on the smallest street curves
January 11th, 2013, 02:37 PM | #11 | |
MOTM - Apr '13
January 11th, 2013, 02:37 PM | #12 |
Bigger, heavier bikes with wider tires require a little more steering input at slower speeds (bike geometry also plays a roll), so your observation is correct ("If I accelerate hard in a turn then the pressure required becomes less severe.") What you are trying to achieve is neutral steering, which requires ZERO steering input to maintain a turn once it has started. Suspension inputs can effect this to a small degree, but speed will affect it more.
Here is a good piece of info on Neutral Steering. |
January 11th, 2013, 02:40 PM | #13 |
Fast-Guy wannabe
MOTM - Jan '13
You need this
January 11th, 2013, 02:44 PM | #14 | |
MOTM - Apr '13
I see what you mean on the neutral steering, what I really mean is that I want the bike to take a minuscule amount of force to maintain the turn. Like you know how when you ride the street and initiate turns, you really don't feel like you are making steering inputs even though you really are. I want it to that degree, whereas now its like damn, I'm really pushing on this bar hard just to stay turning
January 11th, 2013, 02:45 PM | #15 |
what is "correct" when it comes to this kind of steering? what makes a bike stand up in a turn? if you have correctly set trail and wheelbase the bike should be neutral steering. if however something changes the trail or wheelbase, the way the bike steers will be effected. nonstandard tire sizes/profiles? stretched swingarm? low tire pressure? with a big bike, throttle effects suspension considerably. what is the throttle position of the bike when it is trying to stand up? are you slowing or accelerating?
if a wheel is dragging for one of a variety of reasons (rolling resistance caused by low tire pressure, wheel bearings, chain drag, improper use of throttle/engine brake, etc) the geometry of the bike will again be effected (forks compress, rake decreases, etc) and the bike will again no longer be neutral steering. i would try putting a few pounds in your front tire and see how it is effected. try spinning the wheels while its on the stand... dragging? bearing noise? anything messed up? check your geometry and that the frame is straight... simple string true up should be good
January 11th, 2013, 02:48 PM | #16 | |
MOTM - Apr '13
January 11th, 2013, 02:50 PM | #17 |
constant speed through a turn should require slight pressure... accelerating smartly should be neutral steering. see suggestions in previous post
January 11th, 2013, 02:52 PM | #18 | |
January 11th, 2013, 02:55 PM | #19 | |
MOTM - Apr '13
The front tire is already at the max. Increasing it to the max made the problem less severe. I'll try spinning on the stand when I get a chance (likely tomorrow) and the suspension guy already confirmed the wheels are aligned (bar method)
January 11th, 2013, 02:58 PM | #20 | |
And just because the wheels seem to be in line with each other doesn't mean the front wheel is "straight". Ever hit any bumps hard? Maybe hard enough to tweak the front wheel? Have Jason check the front wheel for straightness, since you have it in the air.
January 11th, 2013, 03:04 PM | #21 |
if the front end was twisted it would be hard one way, but dangerously easy the other way. it would always try to tip that direction just a bit even when going straight.
if you want to cover up the issue without really knowing the underlying cause, you can raise the forks in the clamps to get a steeper rake... will make turning the bike easier but the bike will be more unstable (trys to stand up less)
January 11th, 2013, 03:12 PM | #22 | |
Imma do a vid of the straightness of my front and rear wheels on my R6. I will do the street set of wheels. They are untrue as they come and she still cuts like a laser and holds it until the most gentle of push either way. The white ones in my avatar... yep, even rode them on the track. Ignore this until I get the vid, as it's apple to oranges comparison anyway but should still be interesting none the less.
January 11th, 2013, 03:13 PM | #23 |
not sure about the wheels being true i just mean the axis of rotation twisted in relation to the triples. if the wheels weren't true, they would wobble back and forth as they rotate so it shouldn't effect steering that much (outside of the annoying vibration/wobble)
January 11th, 2013, 03:15 PM | #24 |
Yea, that is what I mean, the wobble.
January 11th, 2013, 05:45 PM | #25 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Maybe one of the forks is twisted within the clamps. That doesn't usually happen unless the bike has gone down, but it is probably worth the 10 minutes to undo and redo all the top fork clamp bolts and then the bottom fork clamp bolts.
January 11th, 2013, 07:08 PM | #27 |
MOTM - Apr '13
Yea that's thing, haven't crashed at all...
January 11th, 2013, 07:10 PM | #28 | ||
Both Alex's have explained the problem correctly, IMHO. The suspension has nothing to do with this problem. It is related to subtle changes in steering geometry and tire characteristics. Jiggle's bike is now under-steering: Read pages 111, 112 and 317: http://books.google.com/books?id=rJT...page&q&f=false "Tires have a large influence over bike handling, especially on motorcycles. Tires influence bike dynamics in two distinct ways: finite crown radius and force generation. Increase the crown radius of the front tire has been shown to decrease the size or eliminate self stability. Increasing the crown radius of the rear tire has the opposite effect, but to a lesser degree. Tire inflation pressures have also been found to be important variables in the behavior of a motorcycle at high speeds. Because the front and rear tires can have different slip angles due to weight distribution, tire properties, etc., bikes can experience understeer or oversteer. Of the two, understeer, in which the front wheel slides more than the rear wheel, is more dangerous since front wheel steering is critical for maintaining balance. When understeering, the steering angle must be greater, and when oversteering, the steering angle must be less than it would be if the slip angles were equal to maintain a given turn radius."
Motofool .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; January 11th, 2013 at 09:12 PM. |
January 11th, 2013, 10:04 PM | #29 |
Fast-Guy wannabe
MOTM - Jan '13
Holy **** I check back 5 hours later and we're 30 posts deep and I still haven't read the first one
I'll look this over and let you know what I think in the morning since I'm going cross eye as I type. Also I cant make that ride tomorrow so I'll catch you another time. Be safe out and have fun with the BARF group tomorrow. |
January 11th, 2013, 10:17 PM | #30 | |
Fast-Guy wannabe
MOTM - Jan '13
January 11th, 2013, 10:24 PM | #31 |
Jigs i can say i do feel i need to try a little more in the turns, but i still have the stock 50 series tire and havent messed with suspension. I also havent really been pushing the bike through the curves, only straights. I bought the bike a week before Xmas, so most of the riding ive been doing is near freezing or freezing temps. So im not pushing it too hard
January 11th, 2013, 10:24 PM | #32 |
InfoWhore
Join Date: Oct 2012 Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC Posts: 628
Solution: Ride the 250. GG
Everyone, go buy a dirtbike hurry |
January 11th, 2013, 10:41 PM | #33 |
MOTM - Apr '13
My 250 puts down 31 steroid enhanced ponies, I think I can handle it
January 11th, 2013, 10:54 PM | #34 |
Present. Somewhat.
Join Date: Sep 2012 Motorcycle(s): 2012 KTM Duke 200, 2011 Ninja 250r, 2011 Ducati Monster 796, 2014 Kawasaki ZX10r Posts: 227
The monster did the same thing after my dad crashed it, it didn't like to turn right. left was fine, in comparison.
The guys at the dealership said it was because the rebound on the front forks was different, or something
Highest speed on two wheels- 230 km/h Beat that. Last futzed with by TheDementedDrummer; January 11th, 2013 at 10:54 PM. Reason: Spelling. |
January 11th, 2013, 11:58 PM | #35 |
MOTM - Apr '13
Maybe it was crashed before I bought it!?!?
January 12th, 2013, 01:07 AM | #36 | |
Join Date: Apr 2011 Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold) Posts: 479
From http://www.motorcycledaily.com/2011/...test-part-two/
When I was seriously considering a Ninja 1000, I saw multiple reviews and forum topics that mentioned a 180 tire on the press bike prior to launch. At launch they changed to a 190 rear. Are you rotating the bars on the same axis as the rotation, or or are you literally pushing down on the bars? Quote:
January 12th, 2013, 01:12 AM | #37 |
MOTM - Apr '13
What do you mean? I rotate the bars normal
January 12th, 2013, 01:29 AM | #38 |
January 12th, 2013, 01:34 AM | #39 |
This vs...
January 12th, 2013, 01:35 AM | #40 |
This.
Bike stands for $100 | Hero Danny | General Motorcycling Discussion | 2 | July 22nd, 2014 06:15 PM |
Electrical Issue - Turn signals turn to emergency blinkers. | tgoff | 1986 - 2007 Ninja 250R Farkles | 6 | July 6th, 2012 09:07 AM |
bike lift vs stands? | mz_twee | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 13th, 2012 12:23 AM |
Have a lean issue with my bike, issue with coasting enricher. | twiggy2cents | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 24th, 2010 06:54 PM |
[2fiddy.com] - Bike Stands | Ninjette Newsbot | Motorcycling News | 0 | September 8th, 2008 03:51 PM |
