Old February 14th, 2013, 11:38 PM   #1
skilletmo
InfoWhore
skilletmo's Avatar
Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC
Rear brake wont activate brake light-HELP
Ok so after installing my new speed cable, as some of you may know from the incident the other day, i noticed my rear brake wont activate my brake light but my front wire does when doing a thorough inspection of my bike. I read on some other forums and got some ideas, so i checked the spring for the rear brake and it activates it when i pull on it, so what is happening is that it looks like the spring that is attached to the brake on one end and brake wire on the other is to loose... Any one know how to solve or have experience with this problem?
Thanks
Everyone, go buy a dirtbike hurry
skilletmo is offline   Reply With Quote
Old February 14th, 2013, 11:57 PM   #2
cuong-nutz
cuong-nutz's Avatar
Rear brake switch is threaded, so get yourself some pliers or opened end wrench and loose the nut which will pull the switch farther away so when you press on the brake the light works.
HalfFast Racing Team
Old February 15th, 2013, 08:21 AM   #3
Yes, the switch position is adjustable, so you can select at what position of the pedal the switch clicks and closes the circuit feeding the stop light.
The reason for the spring is to make a flexible link, so the switch reaches the on position and stops and the brake pedal can still move more.
Old February 15th, 2013, 04:47 PM   #4
skilletmo
InfoWhore
skilletmo's Avatar
Problem fixed very easily. Thanks
Old March 9th, 2013, 12:29 AM   #5
coelgrim
coelgrim's Avatar
could u put a picture which one to loosen and thighten ? @_@ i dont really understand
I've failed over, and over, and over, and over again in my life..
and That is why I succeed
coelgrim is offline   Reply With Quote
Old March 9th, 2013, 10:02 AM   #6
DaBlue1
DaBlue1's Avatar
The brake switch spring should be attached to the bottom of the rear brake light switch, the other end hooks into the hook part of the (fat) pedal spring. The brake light switch should be adjusted so that there is about and 1/2 in of thread showing just above the bracket.
Old March 9th, 2013, 10:09 AM   #7
skilletmo
InfoWhore
skilletmo's Avatar
I cant show you know becuase im not home but thats a great explanation and picture motofool is showing. You can also locate it by pressing the rear brake in and out and looking at your rest sets on the right and see a cable moving. That will be what you need to adjust with the hex nut its attached too, like on the pic.
Old March 9th, 2013, 10:48 AM   #8
skilletmo
InfoWhore
skilletmo's Avatar
I mean blue* not motofool!
Old March 9th, 2013, 11:09 AM   #9
Front Brake Lever Wont Activate Brake Light DmbShn41 2008 - 2012 Ninja 250R Tech Talk 6 May 10th, 2014 11:56 AM
Rear caliper wont fit on disk with new brake pads Twisthem488 2008 - 2012 Ninja 250R Tech Talk 8 March 14th, 2014 12:39 AM
My rear brake lights wont light up itslocfoo 1986 - 2007 Ninja 250R Tech Talk 2 December 22nd, 2013 06:24 PM
Front brake wont activate tail light radi4fun 2008 - 2012 Ninja 250R Tech Talk 2 April 24th, 2013 06:37 AM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
