March 15th, 2013, 12:46 PM | #1 |
MOTM - Sep '18, Feb '16
Racer X turbo build
With Ecotron Fuel injection and the new turbo system coming out for the 250 and 300. I want to showcase it all in one place. and set some records along the way. I am starting a new project. '
I need a name for it. I will take suggestions then have a pole. . This bike should be ready for 2014 season. specs.. 2001 frame. front section. Custom fabricated rear half. 2008 swing arm 2001 fork 17 inch wheels aerodynamic 1.5 gallon tank 265cc turbocharged engine making 60 hp Wizards of nitrous system adding 40 hp The build will go in short bursts. I have to finish out this season before I can spend a dime.
March 15th, 2013, 12:59 PM | #2 |
dirty boy
MOTM - Apr '14
Looks good already. So you said 265cc engine, does this mean you will no be competing for the fastest 250?
Name suggestion Sleipnir, the Name of Odin's horse. I just seems fitting. Sorry can't help with pronunciation From wikipedia - (In Norse mythology, Sleipnir (Old Norse "slippy"[1] or "the slipper"[2]) is an eight-legged horse. Sleipnir is attested in the Poetic Edda, compiled in the 13th century from earlier traditional sources, and the Prose Edda, written in the 13th century by Snorri Sturluson. In both sources, Sleipnir is Odin's steed, is the child of Loki and Svašilfari, is described as the best of all horses, and is sometimes ridden to the location of Hel. The Prose Edda contains extended information regarding the circumstances of Sleipnir's birth, and details that he is grey in color.) HOLY BIG PICTURE BATMAN!! lol sorry i just linked it |
March 15th, 2013, 01:04 PM | #3 |
Have you decided on a paint color?
March 15th, 2013, 01:27 PM | #5 |
Subscribed!! Finally someone who knows what they're doing is going to get into the fuel injection retrofit and attempt the turbo.
Be warned: the efi conversion parts are not the highest quality. They're meant to fit a price point. They work just fine for an average joe like myself, but they might be below your standards. Look into importing the EU-spec EFI parts if you can. Shadowwolf1117 did that with his race bike and got some great numbers out of it because he could use a Power Commander and adjust the timing for high octane race fuel and get a good fuel curve from dyno time. You might want to contact him and see if he can help you out. I'm not sure if all the EU-spec parts will work on an 88-07 engine (looks like that's what you're going to use?), but you should at least pick his brain since he successfully imported all the parts to do his OEM retrofit. |
March 15th, 2013, 03:51 PM | #6 |
No paint . This is a Bonniville Bike. Raw aluminum and black spray paint.
I will be replacing some of the hardware to meet m needs and race spec . I need the software. Same with the turbo. It's the oil feed and pipe fab that cost time and money to get right. I just want to assemble the pieces and make it all work.
March 15th, 2013, 04:10 PM | #7 |
Okay good. Just making sure.
You should talk to Matt (ecotrons guy) and see what he can do to get you the parts/files/stuff you need. The software is the best part of the kit really. You can adjust everything. |
March 15th, 2013, 06:43 PM | #8 |
I agree the easy tuning is the best part of the kit.
The runner up is the quick starts.
March 15th, 2013, 07:56 PM | #9 | |
For the last four years I have been working on a 250 engine. When it is finished I will convert my current bike( The Dark Horse Special) back to a 250 and compete with it. This new bike will not have a fairing. And being 265cc and turbo with nitrous and E85. It will be classed as modified blown fuel 350-4.
March 16th, 2013, 07:19 AM | #10 |
I installed a 2009 swing arm on the bike. The frame is 2001. It all bolted in no problem. Except I don't have any hardware to mount the wheel. That's OK because I want to extend the rear wheel three inches. I plan to do this with Aluminum plug in pieces and the rear wheel and brake assembly from a zx6r.
March 16th, 2013, 08:03 AM | #11 |
former ninja 250'er
Join Date: Jan 2013 Motorcycle(s): Aprilia 1000R, CRF450, CBR600RR tracktoy, Ninja 250 -- GONE!!!!! Posts: 153
March 16th, 2013, 08:52 AM | #12 |
haha
No I think it will hold. At Bonneville I have to go full throttle 60 hp and 115-125 mph for two miles . Then hold the nitrous full power full speed through a measured mile. Then turn around and do it again. I cant use just nitrous for the full run. Because of bottle size. So I need a turbo to get up to speed. I will spend this year testing and pushing this two motors I have. I got a good strong 50 hp system now. I just need to take it to the next level. This is the 09 swing arm in the 01 frame. With the 16 inch wheel and brake I will be replacing with a 17. I need to move the foot pegs back to the area of the jack stand. 11 inches back!
March 16th, 2013, 09:16 AM | #13 |
Join Date: Mar 2011 Motorcycle(s): 2011 Kawi 250 SE Posts: 105
This is gonna be awesome. I'm excited to see the progress.
March 16th, 2013, 09:39 AM | #14 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
How would a turbo'd bike be on the track?
March 16th, 2013, 10:12 AM | #15 |
It will go fine agenced another 250. Otherwise it is about able to hang with a 500. But a 600 will kill it.
March 16th, 2013, 10:40 AM | #17 | |
March 16th, 2013, 10:57 AM | #18 |
Join Date: Dec 2008 Motorcycle(s): 1975 Kawasaki KZ400D (Sold), 1989 Kawasaki Ninja 250 (sold), 1997 Yamaha XJ600s Seca II Posts: 231
I'd like to know how well this turboing would work in a street bike. Sounds like it could be fun and/or expensive, probably a little of both...
Tony
1997 Yamaha Seca II - mostly stock, Racetech upgraded forks, FZ6R rear shock, Oxford Heated Grips, Barkbusters Blizzard Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page. |
March 16th, 2013, 12:49 PM | #19 |
No street, No corners. Just five miles of open salt.Or one mile concrete or 1/4 mile asphalt.
A little photo shop of the rear wheel position and rear fairing shape.
March 16th, 2013, 09:39 PM | #20 |
Freedom for Germany
For sure not as easy to ride as w/o turbo, before boost there's less power and with boost u have all the power within a second (maybe just in the wrong moment) and don't forget that turbo needs fuel as they are thirsty.
For what Eric is doing the idea to go with turbo in my opinion is the best way, but for normal or to say street use, I think turbo is not easy and look for the history when the Japanese companies went with turbo engines (1982) after five years they'd stop them again for the known reasons. |
March 16th, 2013, 10:07 PM | #21 |
The first thing I need to do is get the bike rolling. I need to move the rear wheel back. That involves extending the 2009 swingarm. Or having a custom made swingarm. I need a large rear tire. 17inch rim and a 180 or 190 tire. Because of the gearing inside the engine. I need a very tall rear wheel. Going 150 mph and turning 12000 rpm is going to be trickey to gear.
March 17th, 2013, 01:26 AM | #22 | |
March 17th, 2013, 01:28 AM | #23 |
Looks good bro... Good luck
March 17th, 2013, 03:35 AM | #24 |
In 1982 the fuel injection was not able to make a turbo work. With modern fuel injection the turbo 300 with 40 hp turbo will ride great on the street or on the track
Top speed 123.369mph. Ohio mile Worlds fastest 250 ninja Last futzed with by Racer x; March 17th, 2013 at 06:33 AM. |
March 17th, 2013, 07:40 AM | #25 |
I was looking around and found this.
http://www.ninjette.org/forums/showt...light=Swingarm. It has a swingarm from an 08 gaxr. I can get one of those for 70 bucks with shock. Anyone know if the swingarm will fit?
March 17th, 2013, 03:05 PM | #26 |
Another option for a forward seating position
March 17th, 2013, 03:31 PM | #27 | |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 771
March 17th, 2013, 06:11 PM | #28 |
You would think. But I have managed to hold them off.
The only 350 compitition I have is 350 Hondas and they are air cooled and go a little over 100 mph. Racing at Bonneville I have to compete agenced to stroke motorcycles. The 250 two strokes came from moto GP. They have about 90 hp. The two stroke 350 s are street bikes and have about 70 hp. The record I want is 138 mph and was set in 1979
Top speed 123.369mph. Ohio mile Worlds fastest 250 ninja Last futzed with by Racer x; March 17th, 2013 at 08:03 PM. |
March 17th, 2013, 08:57 PM | #29 | |
Freedom for Germany
It came build from factory for just that purpose and I would say that the ecu from today is not made for the use with a turbo although it should work with it. The whole system was complete unit, with also the cr for the use with a turbo. What dynamic cr will you get when you use a cr 12.5 to 1 with 0.6 bar boost? Good luck and protect your knees. |
March 17th, 2013, 09:23 PM | #30 |
As I recall factory turbo bikes had bad lag problems and ran poorly.So they did not sell. But they might have been carb turbo.
The dynamic ratio of 12.5 with .5 bar is very high. To much for the fuel. Adding nitrous would be to much. I would not run 12.5 to 1 with .5 bar. I would run 10.5 to 1 with 1 bar and pull timing as the boost increased and adding nitrous from the mid range. The nitrous should act as an intercooler. And the turbo should keep things going in one direction. And yes watch my knees.
March 18th, 2013, 07:02 AM | #31 | |
Mr. 988
I'm in.
Jeff
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix Cancer |
March 18th, 2013, 08:19 AM | #32 |
Not this year. Maybe as crew. But I will spend this year working out the engine using my current bike. And build this bike a little at a time. I need to make it a rolling chassis first,then I will put my motor in it and spend money.
The plan is BUB 2014. But that depends on a lot of stuff. I will at least test run it in Ohio by then. Can you came to Ohio in April. First real nitrous run.
March 18th, 2013, 09:11 AM | #33 |
Mr. 988
Sorry but I would not be able to make it to Ohio. I think I'll be at BUB this year just to check it out (maybe take a run too!). If you go I'll have to make meet up and introduce myself.
Jeff
March 18th, 2013, 04:16 PM | #34 |
It's still early in the year. I hope I can go to BUB again this year. The people are awesome.
This is a better seating position. Hiding from the wind more, The clip on bars are under the lower clamp. And I made a set of adapters that move my rear sets back and down. I am going to try to go to the motorcycle salvage yard this week. I hope I can find an aluminum swing arm. One that will fit without much work. I will get it and then buy swing arm extensions. But I need the swing arm, wheel and break caliper . Plus bolts and stuff. I am sure there are plenty of rear ends from sport bikes in the junk yard.
March 19th, 2013, 05:46 AM | #35 |
I have a 2009 frame that took a really good hit in the front. I cut it up to use some of the parts. I mounted the tank and have the rear section to help center the frame.
The seating position is coming together. I am still trying to come up with a name, I like the four legged horse. But I cant pronounce it. Plus I am a city boy. I am afraid of horses. They are shaped like a dog and weigh a ton. And I am no Oden.
March 19th, 2013, 07:47 AM | #36 |
MOTM - Sep '14
looks like "slip near"
Dondalk speek maybe "sipner" |
March 20th, 2013, 06:56 AM | #37 |
At this stage it is just a parts pile. Just starting to mock up. I have some 1/2 inch steel tubing. I held it together with tape just so I can start locating components.
To ride a bike with four times its normal engine output for three miles wide open. I need a cooling system able to handle the heat. I plan to use the nitrous as an inter cooler. And the Fuel system will keep the whole thing from going lean. BUT there is still a huge blow torch going around the exhaust valves and through the exhaust ports. Dissipating the engine hear is critical to running safely. I am using a larger radiator and mounting it behind the rear seat. I will replace it eventually with a thicker aluminum one as needed. And I am going to use an electric water pump to flow a LOT more than the stock one.
March 20th, 2013, 07:26 AM | #38 |
Doh!
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250r Posts: 286
Its always a party around here isn't it?
I wish I had at least half the skills that you have... I'm gonna go cry myself to sleep now... btw, sick project mate, I love the way it looks naked... Hey for the name, how about "Machine X or X Machine" just like your name?.. unless you want something really intimidating like, "Wilson" or ...."Tim" |
March 20th, 2013, 08:23 AM | #39 |
I like it thanks. X machine. Or The X machine. I have cat that lives in my shop named Tim. My best friend the basket ball is named Wilson.
March 20th, 2013, 11:50 AM | #40 |
Doh!
lol, that must be one bad@$$ cat!
Hey you could also put some X's on the side like kill counts... |
Turbo250.com - My Turbo Build Blog | garth285 | 2008 - 2012 Ninja 250R Tech Talk | 319 | June 19th, 2015 08:04 AM |
My 07 250 cafe racer build | elephantman78 | 1986 - 2007 Ninja 250R Farkles | 12 | December 25th, 2014 07:09 AM |
My Cafe Racer Build | girlracer | 1986 - 2007 Ninja 250R Farkles | 17 | December 2nd, 2014 08:14 AM |
Racer X engine build thread | Racer x | 2008 - 2012 Ninja 250R Tech Talk | 189 | June 12th, 2013 07:34 AM |
I want to buy or build an 08+ 250R racer. | Seanslides | Ninjettes At Speed | 20 | March 1st, 2010 07:34 AM |
