Old March 30th, 2013, 07:57 AM   #1
abhisaxe
Motorcycle(s): Ninja 250R
Strange Vibrations on 5G at 7K RPM
Dear Friends,
After replacing my CAM chain tension’er recently, I am observing a strange "Humm" and “vibration” coming from the front of my bike in 5th Gear at 7k RPM. The vibration is also felt in the left foot peg only. This ‘Humm’ and ‘vibration’ is sequential in timing and disappears once I cross 8k rpm and are not metallic and seems tht it comes from engine, I suppose. Also, I have noticed this same ‘vibration’ and ‘Humm’ at a smaller scale in 4&3 rd gear at 5K rpm. During bike test on Dyno, this problem didn’t come but driving the bike on road reveals this issue. Mechanic wasn’t able to identify the problem so I am asking you all here if anybody have faced this similar problem, if so then kindly share your experience.
I have tightened my CAM chain still the problem exists. What more should I check for its rectification.
Regards,
Abhishek
abhisaxe is offline   Reply With Quote
Old March 30th, 2013, 08:23 AM   #2
What year is your Ninja 250 and why did you replace that part?
Welcome to the site, Abhishek !!!
Old March 30th, 2013, 08:28 AM   #3
abhisaxe
Hello Hernan,
Mine is a 2011 model and the need for the replacement is because I was getting a high tickling noise on idling, and sometimes on the run too. So the cam chain tensioner was replaced. Since then only i am having this problem, this isnt a metallic vibration.
Old March 30th, 2013, 09:13 AM   #4
I would check the final drive's chain for excessive slack or wear, as well as the small sprocket.
I would also check the proper torque of the bolts anchoring the engine to the frame.
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Strange Noise at ~6000 RPM forevertwowheels 2008 - 2012 Ninja 250R Tech Talk 20 August 20th, 2012 06:15 AM
7k+ rpm makes strange noise Graugaard 2008 - 2012 Ninja 250R Tech Talk 14 June 11th, 2012 03:30 PM
Got handlebar vibrations? sofo General Motorcycling Discussion 15 August 18th, 2010 09:14 PM
HELP: Heavy vibrations! sixstring 2008 - 2012 Ninja 250R Tech Talk 16 April 16th, 2010 03:10 PM
