May 10th, 2013, 09:50 AM | #1 |
Don’t wait until yours snaps: when to replace that chain?
"The toughness of a chain is often expressed in terms of tensile strength. But tensile strength is really only one component of a much more important characteristic—fatigue resistance."
http://www.motorcyclistonline.com/ho...ace_the_chain/ "If the sealing ring breaks, the grease leaks out and that particular joint heats up, dries out, and becomes contaminated with water and rust, elongating the pin-to-bushing fit (Chains don’t actually stretch; their internal clearances just get bigger). This puts more load on the adjacent joints, and on the sprocket teeth. Sealing rings rarely break, but if they do, you should consider your chain toast; it’s time for a new one. The grease behind the sealing ring is meant to last the life of the chain, but you still need to lubricate the chain rollers, which contact the sprocket teeth, and the sealing rings themselves, which can otherwise dry out and crack. Apply lube into the tiny gap on either side of the roller so it penetrates into the space between the roller and the outside of the bushing, then hit the sealing rings on either side of the chain. Do this when the chain is warm so the lube penetrates under the rollers thoroughly and spreads over the sealing rings. Wipe off the excess lube to keep dirt and grit from sticking to the chain. The chain should feel slightly oily to the touch, but not wet." http://www.motorcyclistonline.com/ho...n_maintenance/
May 10th, 2013, 10:29 PM | #2 |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
Nice article. Chains are relatively cheap, so replacing early is never a bad option. The BEST option is just do your chain maintenance often and correctly. It pains me to see so many rusted chains around my area...
Also, I recently got a GreaseNinja. It's pretty cool and does a great job lubing the correct sections of the chain. I'll still go and manually add a bead here and there, but well worth the $10 I paid.
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
May 11th, 2013, 07:59 AM | #3 |
Very ingenious device !!!
I do something similar, but only use ATF.
May 11th, 2013, 08:16 AM | #5 | |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
May 11th, 2013, 11:12 AM | #6 | |
May 11th, 2013, 12:59 PM | #7 |
Join Date: Oct 2012 Motorcycle(s): 2012 red 250 ninja Posts: 740
May 11th, 2013, 07:37 PM | #8 | |
http://www.motorcycle.com/products/a...ains-3524.html "The only reason for chain wear is the loss of lubricant...............Chain grease is not so efficient. It cannot get into the tight clearances between moving parts and the most good it can ever do is keep the chain's side plates from rusting in the winter." http://www.motorcyclistonline.com/ho...le_chain_lube/ http://www.advrider.com/forums/showthread.php?t=795246 The main advantage is that dirt does not stick to it (hence, no abrasive effect on the sprockets) and it flows nicely around the O-rings and underneath the roller while the chain is warm, staying there for over 250 miles. http://en.wikipedia.org/wiki/Abrasive The chain remains clean and the O-rings look moist at all times. I mix any ATF with 10% of heavy gear oil, as I ride in the rain frequently. After the first trip, I easily wipe any excess that has landed on the left side of the rear tire. Applying that mix after each tank fill up, I have put 20K miles on that chain and it has not stretched a fraction of a mm yet. Sprockets look new as well.
Motofool .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; May 11th, 2013 at 09:39 PM. Reason: Link added (not to the chain but to the post) :) |
May 12th, 2013, 03:47 AM | #9 | |
B-Town Ninja
@Motofool I've heard that ATF stanks in the heat. Confirm or deny?
The local shop in my town sells them for $10 when you purchase some degreaser or chain lube.
May 12th, 2013, 05:49 AM | #10 |
Bass Master General
No, with the scottoiler you don't have to do anything, the oil is low tack, meaning it isn't sticky, so any debris doesn't collect but rather gets flung off the chain under the forces, when it rains that will also take away all the debris off the chain, my chain looks shiney and new 100% of the time, it's a well tried and tested proven product.
TLDR: The chain doesn't get dirty, you need to do nothing but top the reservoir up every 1000 miles or so. |
May 12th, 2013, 09:57 AM | #11 | |
Heat doesn't have any influence on the automatic transmission fluid staying on the O-rings; strong rain, however, tends to wash it off (not completely), reason for which I mix it with some gear lubricant SAE 80W-90 (~10% before applying it to each O-ring and roller), having had good results. In summary, never a problem with heat. As a matter of fact, a moist and clean (ATF has a high detergent capability) chain stays cooler (transmission of HPs' always generate heat that needs to be carried away (via oil-air) from metal parts like clutch, tranny, bearings, chain and sprockets). Regular and persistent application of a lubricant, which is fluid enough to go and stay flexible between the O-rings and the side of the plates, is the key for longevity and performance (212 dry O-rings quickly rotating against dry steel can lose the sealing effect and eat some HPs'). Right after or during a long trip (while the chain is warm) I apply the ATF+gear lubricant mix to the O-rings and rollers with a dropper (more precise but labor intense), with a spray bottle or with a dental brush; however, I try to re-apply never after 200~250 miles. I am probably wrong since I have not tried any, but my problem with automatic lubers is their inherent inaccuracy regarding the points of application and supplied volume (too little may quickly trash the chain - too much may trash your bike with a quick low side).
May 12th, 2013, 02:26 PM | #12 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Scottoilers are kind of spendy too. I mean, you could buy a looot of chain lube with that money, or just pat yourself on the back for saving $130+ and not be a lazy ass.
May 12th, 2013, 02:30 PM | #13 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Coupled with the fact that you have to use their proprietary chain lube, this is why I don't own one. I don't doubt their usefulness, though. Just not my thing.
May 12th, 2013, 03:47 PM | #14 | |
I don't want one right now, but if I was still doing 750 miles a week, yeah, I'd be buying one right now to put on with the new chain and sprocket set. |
May 12th, 2013, 09:10 PM | #15 | ||
B-Town Ninja
I'd like one for the simplicity of them, but (and I know it's silly) I'm not sure I can trust it not to accidentally dump too much lube before a big turn and cause a low-slide due to lube on the wheels. I just know that there is 0% of this happening when I do it myself. I think it would always be in the back of my mind. Quote:
May 13th, 2013, 06:29 AM | #16 | |
When my chain gets really dirty with road mud, I use a vinyl glove+rag soaked with ATF to clean the entire chain before a new application (always rotate the wheel backwards since that rear sprocket likes biting fingers = no good at all !!!). A couple of times, at the time of servicing the swingarm (when I can remove the chain from the frame), I have used kerosene and a tooth brush for deep cleaning, but that can get messy. You are welcome
May 13th, 2013, 01:23 PM | #17 | |
June 25th, 2014, 05:39 PM | #18 | |
June 5th, 2016, 06:50 PM | #19 |
June 5th, 2016, 11:30 PM | #20 |
Certified looney toon
MOTM Jul '13, Jul '14
I've now had the "joy" of experiencing a sudden loss of my chain. On the Honda vs the Ninja, but still.
It was a dirt bike chain, so non o-ring. We lubed it up upon installation and again when I got home 200 miles later. However, after 400 miles total of interstate speeds (200 miles non stop legs each), the chain threw the master link and was spit out the back of the bike. My friend who was behind me descibes it as a "sparking snake suddenly coming after me". No damage to the bike, a guide on the inside of the front sprocket cover kept the chain away from the engine and helped it exit the rear, and bonus no damage to me. I had pulled out onto the highway and was just getting into four or fifth gear when my revs just spiked and I started slowing down. I heard the "pop" just before the revs jumped so knew something was wrong. Coasted to a stop just off the road and discovered the problem.
June 6th, 2016, 07:33 AM | #21 |
Vintage Screwball
MOTM - Mar '16
An old trick for clip style master links is to use RTV silicone on them after install. Thoroughly clean with Brakleen or other solvent, dry, and apply!
Goin' fast on slow bikes! |
June 6th, 2016, 09:58 AM | #22 |
Are you still running a non o-ring on the bike? I understand that you like to go off the beaten path, but a non o-ring chain on a long-distance bike seems like it might have some unintended consequences.
June 6th, 2016, 10:08 AM | #23 | |
I hate clips, they always fall off for me (and I'm too lazy to bother safety wiring them.)
June 6th, 2016, 11:28 AM | #24 |
fyi, that will no longer pass tech at some tracks for A group. Great quick fix, but fading out.
[motorcyclistonline] - How To Replace A Motorcycle Chain | MC GARAGE | Ninjette Newsbot | Motorcycling News | 0 | November 26th, 2014 06:10 PM |
DIY - How to Replace Your Chain | g21-30 | 2008 - 2012 Ninja 250R Tech Talk | 23 | August 20th, 2014 09:23 AM |
Can I wait to replace my tires? | Alpen10 | 1986 - 2007 Ninja 250R Tech Talk | 7 | July 1st, 2014 05:47 PM |
Can I need to cut/break my chain to replace the sprockets | Twisthem488 | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 4th, 2013 10:35 AM |
Time to replace stock chain? | Lurkable | 1986 - 2007 Ninja 250R Tech Talk | 19 | March 18th, 2011 11:05 PM |
