May 21st, 2013, 05:33 PM | #1 |
Join Date: Dec 2012 Motorcycle(s): 2009 SE Kawasaki Ninja 250r Posts: 2
Engine ticking sound
I'm pretty much a newb to bikes and this forum. I have a 2008 Ninja 250r with 5.5k miles and I've just recently started hearing a ticking sound when the bike is turned on. I've read that it could be the CCT or need a valve adjustment, however, what are other common possibilities this could be happening? Should I be expecting a valve adjustment at only 5.5k miles?
Thanks |
May 21st, 2013, 05:44 PM | #2 | |
Join Date: May 2013 Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F Posts: 125
May 21st, 2013, 06:07 PM | #3 |
Thanks for the response, I'll try that tonight. Any tips when removing the CCT?
May 21st, 2013, 06:24 PM | #4 | |
http://www.youtube.com/watch?v=E4eH0d2E73g In the video at the end he left a little gap before loosening the top screw to spring the tensioner rod back down, someone said not to do leave any gap so it's up to you... |
May 21st, 2013, 07:57 PM | #5 |
Welcome to our site, Jason !!!
No gap. Camshaft Chain Tensioner Removal: CAUTION This is a non-return type camshaft chain tensioner. The push rod does not return to its original position once it moves out to take up camshaft chain slack. Observe all the rules listed below: When removing the tensioner, do not take out the mounting bolts only halfway. Re-tightening the mounting bolts from this position could damage the tensioner and the camshaft chain. Once the bolts are loosened, the tensioner must be removed and reset. Do not turn over the crankshaft while the tensioner is removed. This could upset the camshaft chain timing and damage the valves. •Remove the right lower fairing (see Lower Fairing Removal in the Frame chapter). •Loosen the cap bolt •Remove the tensioner mounting bolts, and remove the chain tensioner body. •Replace the chain tensioner gasket with a new one. •Tighten: Torque - Chain Tensioner Mounting Bolts: 9.8 N·m (1.0 kgf·m, 87 in·lb) •Take out the holder plate. •Install the O-ring and tighten the cap bolt. Torque - Chain Tensioner Cap Bolt: 5.0 N·m (0.5 kgf·m, 44 in·lb) Camshaft Chain Tensioner Installation: •Remove the tensioner cap bolt and O-ring. •While compressing the push rod, turn it clockwise with a suitable screwdriver until the rod stopped. CAUTION Do not turn the rod counterclockwise at installation. This could detach the rod and the tensioner cannot be reinstalled. •While holding the rod in position with a suitable push rod holder plate install the tensioner on the cylinder block.
2009 ninja 250r engine ticking & knocking noise | ubxssangz | 2008 - 2012 Ninja 250R Tech Talk | 47 | January 26th, 2017 12:15 PM |
engine tapping sound | bandit_fosky | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 17th, 2013 07:59 AM |
Can thinner oil cause engine ticking?? | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 11th, 2012 11:25 PM |
Engine ticking at idle? | JMcDonald | 2008 - 2012 Ninja 250R Tech Talk | 14 | December 17th, 2010 10:11 AM |
Does my engine sound normal? | Betlog | 2008 - 2012 Ninja 250R Tech Talk | 12 | February 5th, 2010 10:53 PM |
