June 10th, 2013, 11:42 AM | #1 |
Join Date: Sep 2010 Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty Posts: A lot.
MPG curiosity
Best fuel economy on my '10 250r = 62 mpg. Best on my 750ss = 64 mpg.
Even taking into consideration the Ninjette has a carburetor and the Duck is FI, does anyone else find this surprising? |
June 10th, 2013, 11:49 AM | #2 |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
I'd ask what driving u did as 75 on the interstate at a hi rpm will use more fuel
Hey Unregistered never go faster than your brakes can be applied... |
June 10th, 2013, 11:54 AM | #3 |
June 10th, 2013, 11:59 AM | #4 |
try another test in town I think the 250 will do better.
June 10th, 2013, 01:37 PM | #5 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
my 09 250 got 50mpg and so did my 07 zx6r. My current ride, an r6r gets 35mpg...
June 10th, 2013, 01:50 PM | #6 |
June 10th, 2013, 02:41 PM | #7 |
Jigglin' your Jiglets
MOTM - Apr '13
My k1300s gets better mileage than my 250 and I drive them similar. I never need to go over 5k rpms on the bmw while I never need to go over 13k rpms on the ninjette.
June 10th, 2013, 03:40 PM | #8 |
Join Date: May 2011 Motorcycle(s): 2005 Yamaha FZ6 Posts: 169
My FZ6 returns 55 when babied on the highway, and 45 when driven hard with a mix of city and highway. My old '03 250 got about 60 highway and mid-high 40's mixed, so not much different.
June 10th, 2013, 04:34 PM | #9 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
If you're anything like me, you can't help but wring the heck out of your Ninjette even when you're trying to be economical, which is obviously disastrous (relative term) for the fuel economy
June 10th, 2013, 05:05 PM | #10 |
MOTM - Apr '13
The nice thing is though that its nearly impossible to get less than 40mpg
June 11th, 2013, 07:30 AM | #11 | |
Things that favor the Ducati 750 SS, regarding economy: -Fuel injection = Less restriction to air intake -Engine's V configuration = Less aerodynamic resistance -Two valves per cylinder = Less cam effort + slower mix flow -Air cooling = No water pump or fast-circulating coolant or radiator facing the airstream -Lower max torque / power rpms' (~6K / ~8.3K) = Less mechanical internal friction and parts' accelerations Things that favor the Ninjette, regarding economy: -Higher compression ratio (11.6:1 vs 9.0:1) (possible due to liquid cooling) = Higher thermal efficiency "The compression ratio of an internal-combustion engine or external combustion engine is a value that represents the ratio of the volume of its combustion chamber from its largest capacity to its smallest capacity. ......... A high compression ratio is desirable because it allows an engine to extract more mechanical energy from a given mass of air-fuel mixture due to its higher thermal efficiency. This occurs because internal combustion engines are heat engines, and higher efficiency is created because higher compression ratios permit the same combustion temperature to be reached with less fuel, while giving a longer expansion cycle, creating more mechanical power output and lowering the exhaust temperature." http://en.wikipedia.org/wiki/Compression_ratio
June 11th, 2013, 08:41 AM | #12 | |
June 11th, 2013, 12:44 PM | #13 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
I'm glad we have Motofool here to be all smart and stuff.
Haha on my 500 the lowest I ever got it to by riding hard was 47mpg and I really had to try, usually 50-53 mixed commuting year round and 65+ on the highway, my highest being 68. That's with average speeds around 80mph not tucked in or anything. On my F4i my highest was 42mpg doing the same ride that gets me 65 on the ninja, lowest so far has been 35 and I rarely ever get above 40. It really sucks because it's so much nicer to ride than my ninja and I've put nearly 2k miles on it since I got it, and only about 80 miles on the ninja since then..... |
MPG | Xsavior | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 20th, 2012 07:02 PM |
exhaust curiosity | spawned4562 | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 7th, 2012 06:18 AM |
I thought curiosity killed the ketteh... | 250rr | Off-Topic | 3 | August 7th, 2012 11:23 PM |
Just out of curiosity, was she wearing riding footwear? | Heed | General Motorcycling Discussion | 22 | September 8th, 2011 05:32 AM |
[topix.net] - Morbid Curiosity: A Final Farewell to Those Who... | Ninjette Newsbot | Motorcycling News | 0 | July 1st, 2011 04:00 PM |
