June 13th, 2013, 01:44 PM | #1 |
Engine torque specs
What are the correct torque specs for the head bolts and the bolts that hold down the cam(rockers?) For an ex250 2001? Once again I can find no info online for it.
June 13th, 2013, 02:10 PM | #2 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
Head bolts 25 N-m, 18 ft-lb
Cam retainer bolts 12 N-m, 104 in-lb |
June 13th, 2013, 03:36 PM | #3 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
June 13th, 2013, 03:52 PM | #4 |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
Isn't there a sequence that they are suppose to be torqued ?
CVMA #55 |
June 13th, 2013, 04:46 PM | #5 |
Yes there is, it is all in the manual.
June 13th, 2013, 08:09 PM | #6 |
What is the sequence? Start in the center and work your way out?
June 14th, 2013, 04:40 AM | #7 |
The order for the cam caps is:
Cylinder 2 Bolt closest to radiator, then 3rd bolt back (of 4) Then 2nd bolt closest to radiator, then last bolt back Then do the same for cylinder 1 Then do the bolt closest to the radiator at the right of cylinder 2 Then two back, then 2nd bolt closest to radiator, and then last bolt. The cam chain cover is not part of the sequence. |
torque | skip | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 22nd, 2014 02:55 PM |
clutch lever pivot bolt/nut torque specs | Confuzshuz | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 25th, 2012 05:11 AM |
suspension torque specs | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 18th, 2011 12:03 PM |
Errr...can we torque ? | eddiekay | 2008 - 2012 Ninja 250R Tech Talk | 9 | January 21st, 2010 07:49 PM |
Fastener Torque Specs | Finder | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 28th, 2009 07:58 PM |
