Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old June 14th, 2013, 07:33 PM   #1
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Clean ways to 'seal' the windscreen
I don't know if this has impacted anyone else, but my 300's screen has somewhere around half a cm of empty space between it and my front fairing. Since I sometimes put small items in that space (e.g. parking passes for some garages) I've had some frustration more than once. Has anyone come up with a clean solution to close up this gap reliably? I could just put some foam along the seam but I don't think I could make it look great.
Old June 14th, 2013, 07:52 PM   #2
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
If you turn it black you be able to use foam.
Old June 15th, 2013, 09:42 AM   #3
allanoue
allanoue's Avatar
MOTM - Sep '14
Clear screen looks best with white IMO
Old June 15th, 2013, 11:45 AM   #4
lgk
they did that gap thing to match the 600s.
you could try silicone caulking, or a combination of caulking and weather stripping.
the hardware store usually has it near the window section, it comes white or black.
Old June 18th, 2013, 04:35 PM   #5
Aurodox
Motorcycle(s): -
The gap is supposed to help with aerodynamics
Aurodox is offline   Reply With Quote
Old June 18th, 2013, 04:41 PM   #6
Joshorilla
Bass Master General
Joshorilla's Avatar
I'd affix a plastic wallet or a clear tupperware tub with 3M sticky pack foam pads like the contour cameras use, so you can keep your stuff in that and it would be easily reversable.
Old June 18th, 2013, 04:48 PM   #7
lgk
while looking for tupperware containers i found this
http://www.amazon.com/InterDesign-Su...sxp_grid_i_2_2
here i am in the 20 century using a soap dish, i had no idea these existed!!!
Old June 18th, 2013, 04:51 PM   #8
Joshorilla
Bass Master General
Joshorilla's Avatar
Oh man, wait to you learn about "liquid" soap, it'll blow your mind!
Old June 19th, 2013, 05:08 AM   #9
Dark
Simple kind of man
Dark's Avatar
Remove the windscreen, tape off the lower portion (you can even tape it off on a 'V' shape to match the lower fairing) and then paint the lower portion (spray paint or plasti-dip will work). Once it has dried you can use some weather stripping foam which has a sticky side and stick it to the windscreen within the painted area. Make sure to get the stripping that is tall enough to properly fill the gap with a little extra pressure to hold anything that might slide down.
Reinstall the windscreen and you're good to go.
Here's an example of the painted portion:
Dark is offline   Reply With Quote
Old June 19th, 2013, 06:32 AM   #10
Brother Michigan
Just for the record, this is referred to as a "floating windscreen."
Old June 19th, 2013, 06:43 AM   #11
allanoue
allanoue's Avatar
MOTM - Sep '14
I like this
Old June 19th, 2013, 06:01 PM   #12
himynameisjoe
himynameisjoe's Avatar
Motorcycle(s): 2012 Ninja 250(Totaled)
You made my day. Thank you ever so much!
"I am a creationist, I believe man created god."
himynameisjoe is offline   Reply With Quote
Old June 19th, 2013, 06:53 PM   #13
lgk
Originally Posted by allanoue View Post
I like this
Thats pretty nice, but i'm kinda afraid it might pinch my ape hands.
Old June 19th, 2013, 07:00 PM   #14
lgk
You should have been there, haha.
I says "What kind of sorcery is this?"
Old June 19th, 2013, 08:30 PM   #15
himynameisjoe
@lgk that's fantastic!
As to the OP question. Leave it alone... Please? If you must, use one of these non-permanent solutions!
Old June 19th, 2013, 09:48 PM   #16
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Why leave it alone? Just curious
Old June 19th, 2013, 09:57 PM   #17
himynameisjoe
lol the thought of using silicone caulk on a bike, in a place that may be noticeable just scares me haha
I also have a good friend who fixes his (much older, mind you) bikes with things like duct/gorilla tape, cardboard, PVC pipe and really any other spare parts. So you could say I'm scarred of DIY cheap fix bike work. That being said, the man is an absolute genius and I have yet to see one of his fixes fail instantly!
Old June 19th, 2013, 10:06 PM   #18
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Ah, no worries -- I'm not about to do anything that would look cheap; too much perfectionist in me
Old June 19th, 2013, 10:19 PM   #19
himynameisjoe
Old June 27th, 2013, 03:07 PM   #20
uKER
Motorcycle(s): Kymco Quannon, Ninja 300
God, there's a reason that is like that.
The air flow from the fairing creates a rising current behind the windscreen that makes air coming off the top edge of the windscreen go up at a higher angle so that not so much of it hits your body.
Do yourself a favor and leave it alone.
Using it as a pocket for your papers is akin to using your computer's optical drive as a cup holder.
uKER is offline   Reply With Quote
Old June 28th, 2013, 01:28 AM   #21
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
I've recently been riding without the screen at all and the wind doesn't bug me a bit; so that purpose of the screen is really not there for me (for what it's worth, the 300 looks quite nice without it). I'm not talking about storing papers up there permanently, but most parking garages I use require you "put your ticket in the windscreen" and so this is the closest I can do on a bike; sorry if you don't like the idea?
Old June 29th, 2013, 07:30 PM   #22
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I oddly carry one of the black paper clips with the two little metal thingies on it, and clamp my parking tickets to the window...
Last futzed with by JohnnyBravo; June 29th, 2013 at 07:33 PM. Reason: My post made futzing necessary
Old June 29th, 2013, 11:15 PM   #23
ChickenRun
ChickenRun's Avatar
Motorcycle(s): 2010 250r SE (without stupid tribal decals)
Genius!
ChickenRun is offline   Reply With Quote
Old June 30th, 2013, 06:55 AM   #24
JohnnyBravo
Originally Posted by ChickenRun View Post
Genius!
What part of jax you in?
Old June 30th, 2013, 07:20 AM   #25
algs26
Motorcycle(s): ex300, gave up looking for a 250
That doesn't seem very secure. Couldn't someone steal (or swap if they're being nice) the ticket to save some hours?
algs26 is offline   Reply With Quote
Old June 30th, 2013, 07:45 AM   #26
allanoue
allanoue's Avatar
MOTM - Sep '14
If you are required to display the ticket, that can not be avoided.
Otherwise you could just pocket it.
Old June 30th, 2013, 08:15 AM   #27
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
I agree, genius idea. I may do this, definitely easier than trying to rig up a seal.
Old June 30th, 2013, 09:44 AM   #28
JohnnyBravo
I have yet to notice a missing or replaced ticket, but then again I just pay the dollar or two I'm asked for at the gate. Someone could possibly take it, but if you pay at the debit/ credit card place you have proof you had it, or take a phone pic of you and the ticket for proof, or whatever you deem necassary, or just drive a cage and hope nobody smashes your window
The question was how to keep it from slipping out from under the windscreen, to keep someone from stealing it I'd get a 25k+ safe with bulletproof glass and insert the bike and simply tape the ticket to the glass, but as that's impractical I'll just answer the question with how I keep my lil parking slips on my windscreen. I doubt there is a safe and fool proof way, if you find it the stealing person would probly just steal your bike for foiling their grand plan of saving a dollar in parking fees
Old June 30th, 2013, 12:28 PM   #29
ChickenRun
ChickenRun's Avatar
I actually live in Fleming Island now, and am moving to Orlando next month.
On topic: I wouldn't worry too much about ticket stealing. I don't think most people would be that desperate.
Old June 30th, 2013, 12:31 PM   #30
JohnnyBravo
Boo..I know to many folks around Orlando, not many in this hole. I don't think folks would steal them, but heck there is a chance of anything.
Old August 7th, 2013, 05:05 PM   #31
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
I've always affixed my tix with snot....
Old August 12th, 2013, 09:26 AM   #32
TheMachinr
So this thread has got me thinking...
I am considering making my own "windscreen" (basically fiber glassing a sold piece that I can swap with my actual windscreen)
I will let you guys know what happens if I decide to start this project.
TheMachinr is offline   Reply With Quote
Old August 24th, 2013, 08:21 PM   #33
Elayex
Motorcycle(s): Ninja 300
There are a few easy ways to stuff a parking pass without modding your bike.
Sorry for the crappy pics, but here are three spots where I used an old business card for demo purposes.
The first spot is where I normally put it. Wedged in between the windscreen and the fairing. It's not going anywhere on it's own.
The second and third spots work as well, but are not as secure as the first if you have to wind through a large parking lot/structure.
Filling that gap is an extreme an unnecessary step, IMO, but its your bike.
Elayex is offline   Reply With Quote
shift shaft seal BukkShot Items Wanted 4 March 21st, 2015 10:35 PM
Leak on right fork seal AmyF 1986 - 2007 Ninja 250R Tech Talk 17 July 11th, 2014 09:29 AM
Fork Seal is Stuck eddyble 2008 - 2012 Ninja 250R Tech Talk 7 October 21st, 2013 04:14 AM
OEM Brand New Fork Oil Seal, Dust Seal (08-12) capriccio Motorcycle-related 3 June 9th, 2013 05:11 AM
Leaking fork seal? EthioKnight 2008 - 2012 Ninja 250R Tech Talk 12 March 6th, 2012 09:20 PM
