June 17th, 2013, 03:06 PM | #1 |
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja 250R - Kawi Green Posts: 138
Fuel set to PRI?
Finally got all the fairings and front/headlights out.. Just looking over everything, I noticed fuel is set to prime and has been for at least the year I've owned it and probably as long as the last guy owned it. Should I change this to ON or leave it? Will I have any issues setting it to on that may cause me to have to remove fairings on the side of the road to switch back?
June 17th, 2013, 03:18 PM | #3 |
June 17th, 2013, 04:48 PM | #4 |
if it dies and wont start from lack of gas when the petcock is switched to "on" but works fine in "prime" then it means the vacuum line running to your petcock has a leak or is not connected or the petcock is damaged.
June 17th, 2013, 06:02 PM | #5 |
Looks like its OK so far. Started up no issue, idled for a minute or too and revved past 6k several times... Can't tell for sure but sounds like the buzzing sound I was hearing had disappeared with all the fairings off...sweet.
June 17th, 2013, 06:56 PM | #6 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
I wondered the same thing. When I bought both bikes , I never checked.
I noticed mine was set to PRI and the other was set to ON I switched both to ON My bike seems to start up just as quick as the other bike now. Maybe it's just a coinsidence.
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
June 24th, 2013, 06:03 PM | #7 | |
What do you suggest? |
June 24th, 2013, 06:10 PM | #8 | |
Join Date: Jan 2013 Motorcycle(s): Ninja 300R Posts: 181
0 out of 2 members found this post helpful. |
June 24th, 2013, 07:56 PM | #9 |
3 days is not an extended period of time.
old petcocks and floats get grimy and if you leave them sit for a little while the gas dries up a bit and it gets a little cricky. if you want a problem to fix you could rebuild the petcock and carb bowls. or just say "that was an oddly cold start for only 3 days" and carry on normally.
June 24th, 2013, 08:25 PM | #10 | ||
Problem is, I couldn't get it to start without having to switch back to PRI - that would be very inconvenient in the middle of a parking lot or something if I had to remove the fairing and switch it.. |
June 25th, 2013, 08:28 AM | #11 |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
I never change the position of my petcock in the new gens.
June 25th, 2013, 08:40 AM | #12 |
Certified looney toon
MOTM Jul '13, Jul '14
Just to give you an idea... I've never changed mine from ON since I bought the bike, which includes the 3 months it sat up on a stand while I was repairing it. Yeah, I'd run it once every few weeks for a bit but that was mostly since I was testing lights and didn't want to kill the battery.
You shouldn't have to be switching it back and forth, especially after only a few days. Unfortunately, I have no suggestions to offer.
June 25th, 2013, 09:49 AM | #13 | |
June 25th, 2013, 09:50 AM | #14 | |
The petcock is designed to be in the ON position at all times except when there is a need to get fuel back into the carb bowls after doing maintenance on the carbs. The petcock is vacuum operated. It should have two hoses attached to it. (1) large fuel line attaching to a larger nipple and (1) a smaller vacuum line attached to a smaller nipple. When the engine is running with the petcock in the ON position, the vacuum opens up the diaphragm to allow fuel to flow. When the engine stops the vacuum closes the the petcock off. In the PRI position fuel is flowing all the time. You don't want this. When you leave the petcock in the PRI position you are solely relying on the float valves to stop the carbs from overflowing with fuel and possibly leaking past the piston rings into your oil. If your bike only runs in the PRI position, your petcock is either bad or the vacuum line is not attached properly or has a leak. To fix it, you need to either see if the vacuum line is attached correctly or replace the petcock. A petcock can be purchased either used or new, and replacement is pretty simple. You will need to remove the fuel tank with the petcock in the ON Position. Once the tank is off, you drain the tank by turning the petcock to the PRI position. After the tank is completely drained replace the petcock then reinstall the tank. Look in the Directory of all 250R DIY threads to find out how to do it. |
June 26th, 2013, 08:31 AM | #15 | |
Thanks for the detailed reply. Would the gas leaking into oil cause very dirty/dark oil? I just did the oil change it was very dark brown... Not sludgy or anything just extremely dark. |
June 26th, 2013, 08:57 AM | #16 |
No. It may be milky caramel colored, thin in viscosity, and smell heavily of gas.
Dark colored oil can be normal. Black oil can be a sign that the oil has not been changed in a very long time or excessive carbon build up. |
2008 Ignition, Fuel Tank, and Trunk Lock Set | garth285 | Motorcycle-related | 7 | December 17th, 2016 06:40 PM |
[motorcyclenews.com - sport] - Dunlop set for BMW factory machine at Ulster Grand Pri | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2014 09:50 AM |
Fuel Mixture Question - Shim or Jet for this set-up? | folky15 | 2008 - 2012 Ninja 250R Tech Talk | 20 | April 23rd, 2012 06:21 PM |
[visordown.com] - Fuel prices set to soar to record levels | Ninjette Newsbot | Motorcycling News | 0 | October 20th, 2010 04:22 AM |
Motorcycle driveable only on PRI setting | chokne | 1986 - 2007 Ninja 250R Tech Talk | 4 | June 15th, 2010 12:51 PM |
