June 21st, 2013, 02:21 AM | #1 |
Join Date: Dec 2010 Motorcycle(s): 1965 Honda S90 , 2010 Ninja 250,2012 Vespa LX 150(Yes,a vespa!) Posts: 177
Electrical problems
After actually seeing my bike from behind at night,i recognized how invisible i really was with the LED under tail & blinkers so decided to install a Yoshimura fender eliminator & utilize the stock blinkers,should have been an easy fix.
In my last post a lot of things were clarified that using front flush LEDS & rear stock blinkers,there would be no need for the diode install. Upon removal of the undertail & rear LEDs i found that the shop had twist wired 2 additional sockets with bulbs wrapped in tape,these would lash the same as the rear LEDS,only hidden under the seat. I assume these were installed as a makeshift "diode mod" ( Correct ?) Installed the Yoshi fender elim kit & connected all the wires back to the original connectors & everything works fine. ( Flash speed is constant with both front flush LEDS & rear stock signals.) Here is where the problem arises...angel eyes/HID are installed directly to the battery with an inline blade fuse which melted after installing the stock rear signals.my family took it back to the shop & installed a new fuse & yesterday was the first time to ride. Daytime riding with the running lights has not caused a problem but 5 minutes into the ride home last night,the headlights went out again...angel eyes still on....the entire 20 km trip home the lights would intermittently come on & go off again UNTIL just a few km from home i was greeted by the sweet smell of burning electrical cables!!!!! I could feel the heat just under the fairing where the fuse is installed,turned off the headlights & continued home slowly. The fuse is melted ! The connection to the fuse block is melted ! The inside of the fuse block is melted ! Has removing this backyard "diode mod" created more current due to removing the LEDS & installing stock signals? My brother in law went to the shop today & they just installed a new fuse & holder which i am sure will have the same result next time i use the lights at night. The fuse that burned last night was 15 amp(blue,& installed inline with the HID/angel eye) What should be my list of things to test? |
June 22nd, 2013, 12:10 PM | #2 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
everything
we will need a lot of info, where did they tap power from, what's feeding the load, what's feeds the (switch?), pics of setup. this sounds like an electrical nightmare to me |
need some electrical help | bhalv | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 26th, 2017 03:31 AM |
Ninja Electrical Problems/Won't Start | kdogg2077 | 2008 - 2012 Ninja 250R Tech Talk | 36 | March 17th, 2014 07:08 AM |
[motogp.com] - Barberá still ‘upset’ about electrical problems | Ninjette Newsbot | Motorcycling News | 0 | April 14th, 2013 10:09 AM |
Electrical problems? | ozmani | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 6th, 2013 06:26 PM |
[motorcyclistonline] - New Permatex® Liquid Electrical Tape Keeps Electrical Connect | Ninjette Newsbot | Motorcycling News | 0 | February 26th, 2011 01:20 AM |
