February 28th, 2009, 09:33 PM | #1 |
DIY -Weighted Bar Ends for Clipons for FREE!!! (almost)
In my search to get rid of the wobbles I've been experiencing on the front end of my bike, one of the possible causes I've researched could be the non weighted bar ends of the Woodcraft clipons I installed recently. So, I went searching for a universal type of bar end, but what I was finding were very light weight aluminum types that weren't very weighty.
If only I could find some that were the same weight as the stock bar ends that would be great!!! Hey... wait a minute.... I knew I had seen the mounting method used in the universal type bar ends before... they are the same that is used on my dirt bike "bark busters". I could use the same technique to mount my stock bar ends to the clip on tubes!! Okay, first step is to remove the plastic end caps from the Woodcraft clipons. I used an adjustable pliers (most likely older than most of us on the board) to work the cap off. Just grab it and twist and twist and twist. It will eventually come out. Once that's off, it's time to prepare the bar end. You will need the stock bar end and a slightly longer bolt that the stock setup uses. I ended up with a 2 1/2" countersunk head allen 5/16" bolt found at the hardware store. I wanted to use a metric bolt, but they didn't have any long enough. Also a metric washer the will fit over the 5/16" bolt and also fit into the clipon tube. A piece of fuel line that will slip over the bolt and still fit inside the clipon tube and a 5/16" nut. Stick the bolt through the stock bar end weight... then stick the washer on the bolt Measure out and cut the fuel line so that it leaves enough space on the end of the bolt after it is slipped onto the bolt. when done, this is what you are left with. Tighten the nut down to the fuel line till it is snug, then insert the assembled part into the clipon tube. Tighten the bolt with the allen wrench. As the bolt turns, it also turns the nut, but the nut gets caught on the fuel line and starts to be tightened on the bolt. As the nut is drawn in, it expands the rubber fuel line inside the tube and pushes it out against the inside of the tube, securing the bar end to the tube. Keep tightening the allen bolt until the bar end is solid on the clipon tube. Do this to both sides and when completed, you will have weighted bar ends for your clipons for free... (or the cost of some bolts, washers and nuts. ) |
February 28th, 2009, 09:39 PM | #2 |
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
Great DIY.
Has this fixed the front end wobble problem?
Son: When I grow up I want to ride a motorbike. Father: You can't do both son. |
February 28th, 2009, 09:42 PM | #3 |
just did this a few minutes ago. It's way too windy (50mph gusts) to be out right now.
February 28th, 2009, 09:49 PM | #4 |
I'm lovin' it.
I've always thought that Hawaii had beautiful weather 24/7
Well I do hope this cures the front end wobbling problem. All the best!
February 28th, 2009, 09:51 PM | #5 |
Thanks, but somehow my guess is that it's another related item and this won't stop it. I was looking for a way to weight the bars anyway.
February 28th, 2009, 09:54 PM | #6 |
I'm lovin' it.
Weld some 10kg dumbbells on each side
February 28th, 2009, 11:31 PM | #7 |
忍者
Join Date: Dec 2008 Motorcycle(s): None Now - Used to have an '08 Ninja 250R Candy Blue Posts: 151
wow kkim! I'm pretty impressed. you're pretty innovative! this is great info and a great DIY! I'll have to remember this for when I get my woodstock clip-ons! cheers!
March 25th, 2009, 06:12 AM | #8 |
Join Date: Feb 2009 Motorcycle(s): 08 Ninja 250R Posts: 112
Kelly, did you use a specific type/size of fuel line or can I just ask for some at an autoparts store? I bought a bar ends kit but the rubber end is too big for the hole in the clipon.
March 25th, 2009, 11:07 AM | #9 |
Some weird Canuck!
Join Date: Dec 2008 Motorcycle(s): '92 CBR250RR "Babyblade", 2008 Ninja 250R, 2001 CBR600F4i Posts: 209
would a generic steering dampener not work? a company probably makes one by now.
March 25th, 2009, 11:20 AM | #10 | |
Just measure the clipon hole size and go look for some fuel line with that OD or a bit smaller. |
March 25th, 2009, 11:21 AM | #11 |
March 25th, 2009, 11:36 AM | #12 |
self wrencher
Holy barend batman...
March 25th, 2009, 12:08 PM | #13 |
I went to an auto store and bought some 5/16 size fuel line and it works! Just in case anyone else needs to know. Thanks Kelly for the idea the bike feels alot smoother with the bar ends.
March 25th, 2009, 12:17 PM | #14 |
Glad it worked. |
March 25th, 2009, 01:17 PM | #15 |
IC2(SW)
Pretty slick diy
March 25th, 2009, 01:23 PM | #16 |
lol... us old farts are cheap bastids! ...oh, wait, look who I'm talking to.
besides, I wanted a way to check if maybe my wobbling problem was due to the unweighted clipons and this was the simplest, easiest way I could find to get some bar ends with some heft to them to test the theory. unfortunately they didn't help, but they do help to reduce vibrations, so it wasn't a total loss. |
March 25th, 2009, 03:46 PM | #17 |
Wannabe Reborn
Totally stupid question from a n00b(not me, some random guy sitting next to me):
What do clip-ons do, what exactly are they? Just an aftermarket set of handgrips? And The weight on the bar ends will help reduce vibrations from suspension/road? Could you increase the stock weighted bar ends?
March 25th, 2009, 04:17 PM | #18 |
http://www.ninjette.org/forums/showthread.php?t=11365
increased weight dampens vibrations and yes, you can increase the weight of the bar ends, if you can find any heavier than what is on there stock. |
March 25th, 2009, 04:36 PM | #19 |
Wannabe Reborn
I can make them as heavy as I want. I have access to a machine shop filled to brim with material and equipment. What I worry about is how heavy is too heavy. Obviously if I put weights on there that measure 6 inches beyond the tube, of 316L Sanitary stainless steel, 1.5 round, then that is adding around a couple pounds to each side...too much?
March 25th, 2009, 04:53 PM | #20 |
dunno, but a guess would be, yes, that's too much. experiment and let us know what works best.
June 19th, 2009, 05:23 PM | #21 |
Join Date: Mar 2009 Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636. Posts: 918
idk how I missed this DIY, but I'm glad I found it.
Just what I was looking for!!!! thanks Kelly |
June 19th, 2009, 05:45 PM | #22 |
Join Date: Jun 2009 Motorcycle(s): 09 250R, 08 connie 14, 08 honda ruckus(gave to mom) Posts: 92
did this as well, great mod
June 20th, 2009, 08:48 AM | #23 |
Kkim.. I know you've said you had front end wobbles.. when exactly did/do you get them? when in the middle of a turn? going on a straightaway riding normally?
June 20th, 2009, 10:20 AM | #24 |
February 17th, 2011, 02:56 PM | #25 |
Join Date: Oct 2010 Motorcycle(s): 09 ninja 250 Posts: 131
kkim,
i got the woodcraft clip-ons installed thanks to your awesome DIY thread. now Im trying to do this bar ends DIY but im having trouble finding the bolt so that specific size. I went to Home depot and lowes and spent an hour there and still cant find it. found out later from the people that there that they dont have it for sure. so now im all bummed out anyone know where i can get these bolts around san diego area? i would try kragens and pepboy next.
ride it like you stole it! |
February 17th, 2011, 03:09 PM | #26 |
I bought mine from a local Ace Hardware store.
February 17th, 2011, 06:00 PM | #27 |
+1 for Ace, they have more bolts/nuts than any store. I got mine there as well for the clipons (at the Pacific Beach Ace, but I'm sure there's one closer to you). I also think I have extra hosing if you need it.
February 17th, 2011, 06:44 PM | #28 |
For some reason, the local Ace has a lot of metric hardware that the other stores don't carry, too. It's not cheap, but when you need a couple of specific bolts, there's no better place to go around here than Ace.
February 18th, 2011, 06:56 AM | #29 | |
February 18th, 2011, 10:03 AM | #30 | |
March 6th, 2011, 03:01 PM | #31 |
Join Date: Jul 2009 Motorcycle(s): Ninja 250r 09 SE Posts: 172
What kind of aftermarket bar end would fit ? i'm checking on ebay, some have metric size, other have SAE...
http://cgi.ebay.ca/NEW-UNIVERSAL-7-8...ht_1903wt_1739 http://cgi.ebay.ca/BEA-SI-CNC-Alumin...#ht_2599wt_905 |
March 6th, 2011, 06:23 PM | #32 |
Join Date: Dec 2009 Motorcycle(s): Ninja 250R Posts: 432
I did this DIY today and it really works. I was able to find the screws and nuts at my local Lowes. Picked up some stainless steel screws and bolts.
March 7th, 2011, 02:34 AM | #33 |
i did this DIY too! awesome result...got everything at ACE hardware.
July 29th, 2011, 06:42 PM | #34 |
Join Date: May 2011 Motorcycle(s): 2010 250R SE Green Machine, 2011 250R SE White Lightning Posts: 155
No luck at Ace and had to settle for silver crosshead bolts at OSH but worked the same. Thanks again Kelly!!!
July 29th, 2011, 06:59 PM | #35 |
Join Date: May 2011 Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue Posts: 623
I had no luck at Ace, but will go to Lowes tomorrow.
September 26th, 2011, 11:34 PM | #36 |
All pics in first post replaced. Big thanks to Paul for finding them, recreating them, and cataloging them.
September 27th, 2011, 12:10 AM | #37 |
An even better solution, albeit a bit pricey.
Weighted bar ends for woodcraft bars 5/8" | Singh2jz | Items Wanted | 8 | April 8th, 2015 01:12 AM |
Bar Ends / Grips for Clipons | jjb84 | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 1st, 2015 10:26 AM |
HVMP Heavy Weighted Bar Ends | rasta | Motorcycle-related | 1 | March 10th, 2014 03:16 PM |
Woodcraft clipons with standard bar ends? | TS250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 17th, 2011 04:55 AM |
