Old October 9th, 2013, 09:20 AM   #1
cuong-nutz
cuong-nutz's Avatar
300 motor in 250 frame
After studying pictures, and part numbers, it looks like it'll fit in the 250 frame. @Lychee mentions the exact same reference points on the newgen. I don't think it'll work on a pregen motor since the mounting points are different: http://www.ninjette.org/forums/showthread.php?t=117632....unless you swap over the front engine mounts from that engine generation.
The intake side of the head of the motor may possibly be the same diameter as the 250 motor. If you look at the 300 TB boots, it necks down from large to small. You COULD possibly reuse your 250 carbs and rejet, but why bother when you can have full EFI!
It makes me giddy thinking I can do a complete 300 motor swap in my 250
Top 3 pictures are the newgen front motor mounts.
Then 2 pregen motor mounts and then 4 300 motor mounts. I'll have to see if the pre pregen motor mounts are similar.
HalfFast Racing Team
Old October 9th, 2013, 09:25 AM   #2
allanoue
allanoue's Avatar
MOTM - Sep '14
@alex.s aslo wants to do this I think
Old October 14th, 2013, 09:07 PM   #3
PeeFo
Motorcycle(s): 1989 250 ninja
I am currently working on this. I bought a pregen for a couple hundred bucks with a blown motor and in looking for a replacement i was able to get a 300 motor for about the same money as a 250. I can confirm that the motor bolts right in and is almost identical externally. I am going to run the 300 motor on carbs at least to start out. I am kind of at a halt right now figuring out what to do about the exhaust because it will have to be a custom job. I will post some pics next time im in the garage
PeeFo is offline   Reply With Quote
Old October 15th, 2013, 07:06 AM   #4
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
how would you handle the ignition? Electronics scare me!
My Cafe Racer Build
My intro post
Old October 15th, 2013, 07:18 AM   #5
cuong-nutz
cuong-nutz's Avatar
I take it you're going to reuse the stock exhaust and have a shop fab the rear section of the exhaust. Did you use the 300 front engine brackets or reused the stock pregren engine mounts?
I don't know the specifics of the 300 but he can reuse the stock CDI and rejet for the motor for the time being.
Old October 15th, 2013, 07:48 AM   #6
You'd have to look into the pick-ups for the 300 before doing that.
I know the pregen uses 4 pickups. I also know the efi version of the newgen uses more pickups than the carb version of the newgen. (From talking to shadowwolf about his oe efi retrofit). That might be the only issue with using the stock CDI with a 300 engine; too many pickups for the CDI.
Might be easier to do the whole shebang at once and go with the entire oe efi setup
Old October 15th, 2013, 07:54 AM   #7
cuong-nutz
cuong-nutz's Avatar
What are you referring the picks up to?
Old October 15th, 2013, 08:46 AM   #8
crazymadbastard
Ignition system pickus- they tell the computer at what location the crank is at so that it knows when/wher to fire- just like ignition points.
My Cafe Racer Build
My intro post
Old October 15th, 2013, 08:50 AM   #9
cuong-nutz
cuong-nutz's Avatar
Yeah, that's what I kind of figured. I need to do some more researching.
Old October 15th, 2013, 08:59 AM   #10
crazymadbastard
There's the rub, we need to see if we can use the 250 wheel and pickup on the 300 motor. Or maybe someone has used megasquirt to run the stock efi hardware.
My Cafe Racer Build
My intro post
Old October 15th, 2013, 09:41 AM   #11
cuong-nutz
cuong-nutz's Avatar
Eyeballing the parts, it looks like you can swap the rotors over. The only thing I am unsure of is the 300's sensor read input. Perhaps swap the whole pregren stator, cover, and wiring over onto the 300 block?
300 crank angle sensor resistance 180-280 ohms
250 crank angle sensor resistance 100-150 ohms
300 crank angle sensor peak voltage 4.5 V
250 crank angle sensor peak voltage 3.2 V
Oh, and the 300's rotor has a crap ton of pick ups @choneofakind. Take a look:
Old October 15th, 2013, 10:22 AM   #12
One more excuse to transplant the OE EFI from the 300 to the franken-bike it's going into. The heck with those carbs
Old October 15th, 2013, 10:22 AM   #13
cuong-nutz
cuong-nutz's Avatar
Extra info about the 250 and 300 motor and tranny and extra.
Old October 15th, 2013, 10:24 AM   #14
cuong-nutz
cuong-nutz's Avatar
werd
Old October 15th, 2013, 08:15 PM   #15
PeeFo
here is a pic of my project bike torn apart in a million pieces
here the 300 motor that i just put the 250 clutch cover on
here is a pic showing how the carb boots slide onto the 300 head
Old October 15th, 2013, 08:22 PM   #16
PeeFo
I would love to run efi, but I am missing a few of the sensors required and I dont have the fuel pump. I do have the complete wiring harness ecu and throttlebody assembly. I think it will be alot easier for me to get it running and dialed in on the carbs. I didn't realize the crank angle sensors are different so I will probably swap the 250 stator bits over.
Any ideas on what jet sizes I should start tuning from?
Old October 15th, 2013, 08:28 PM   #17
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Old October 15th, 2013, 10:00 PM   #18
Your cylinder size is very similar to that of a 600cc bike. What main jets do they run? 130's?
Old October 18th, 2013, 12:40 PM   #19
bandit_fosky
Motorcycle(s): ninja 250 r
im verycurious to know how far you have got im considering this for my 250 here in the uk but also considering the 500 swap
bandit_fosky is offline   Reply With Quote
Old November 23rd, 2013, 01:25 PM   #20
PeeFo
Allright so i had a few hours to play with the bike this morning, so I hooked up all the various sensors, cleaned my carbs and pulled her outside to see if it would run and if my wiring job was ok. Forgive the ****** video quality as I was trying to hit the starter button, film and work the choke at the same time.
Lots of work left to do, but before I start ordering pods and jets and tires I wanted to make sure this motor was good. Was definitely a big relief hearing that dude fire up
Old December 21st, 2013, 06:45 PM   #21
EMSRacer07
EMSRacer07's Avatar
more pics please @PeeFo
Old December 21st, 2013, 08:33 PM   #22
JohnnyBravo
What the heck was I doin 23 nov to miss that vid being posted?
Lookin good!
Old December 23rd, 2013, 07:58 AM   #23
TonyKZ1
TonyKZ1's Avatar
Motorcycle(s): 1975 Kawasaki KZ400D (Sold), 1989 Kawasaki Ninja 250 (sold), 1997 Yamaha XJ600s Seca II
Wow, good luck and keep us updated with your progress.
Tony
1997 Yamaha Seca II - mostly stock, Racetech upgraded forks, FZ6R rear shock, Oxford Heated Grips, Barkbusters Blizzard Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old December 30th, 2013, 07:12 AM   #24
espacef1fan
Motorcycle(s): Suzuki TL1000R
Do you have some detailed pictures of the 300 engine bolted up?
Have Pregen 250. WTT for a dual sport... 250cc and up
espacef1fan is offline   Reply With Quote
Old January 6th, 2014, 06:52 PM   #25
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
+2 more pix.
chugs is offline   Reply With Quote
Old January 6th, 2014, 08:23 PM   #26
EMSRacer07
EMSRacer07's Avatar
I can try to get a few pics up tomorrow. Basically for the pregen you need to grind both front mount sides about 1/8 inch from both sides for the 300 engine to fit. Rear mounts are the same.
I bet with newgen 250 it might go straight in since the front mounts are different. But to keep the pregen radiator you would need the pregen mounts.
Also the exhaust needs to be modified a bit since the body on the 300 is wider than the pregen.
I almost got mine running. Just a matter of figuring out where I am going to put stuff. Everything is already plugged in and figured out what i needed for the fuel pump. Should be running possibly by next week.
Old January 7th, 2014, 01:45 PM   #27
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
FYI, the EX500 uses 130's and they're known for being rich up top.
But I hate carbs, so I'd do anything I could to bring the 300's FI over along with the engine. If Ecotrons had a 250-style, all-in-one FI kit for the 500, I probably would've ordered it by now.
Old January 7th, 2014, 01:53 PM   #28
Good to know, it was just a ballpark guess for where to start. I figured the 600cc bike would have larger main jets than needed because their intakes are tuned for high end.
I'm sure you could modify that system for a 500 easily. The engines are very similar to the pregen. Same number of ignition pickups (I think). You'd just need to get it wired right and fiddle with the TB's/injectors a bit. That ecotrons system is very easy to work with and tune. If you're really serious, email the company and ask about it. They're pretty good about working with you.
Old January 8th, 2014, 01:53 PM   #29
PartsNinja
Ninja Parts Master
PartsNinja's Avatar
Motorcycle(s): 2011 Ducati Streetfighter 1098, 2014 Honda CB1100 Cafe, 2007 SV1000S, Quite a few 2008-2012 Ninja 250s
@cuong-nutz If you need any sensors or small bits or ANYTHING off of a 300 to make this work, let Parts Ninja know (We are curious to see how this works out and could do special pricing on the parts), we just got a really nice condition 2013 that will be stripped down starting this weekend. We should have any part you could possibly require.
Add me on Instagram: @d_jalb Or follow me on eBay: PartsNinja
PartsNinja is offline   Reply With Quote
Old January 8th, 2014, 06:25 PM   #30
mgentz
Board Member
^ awesome right there...
Old January 20th, 2014, 11:08 AM   #31
johninja
Motorcycle(s): 09 ninja 250
So how many guys have successfully translated the 300 engine in the 250
johninja is offline   Reply With Quote
Old January 20th, 2014, 12:30 PM   #32
EMSRacer07
EMSRacer07's Avatar
Hmm well i am hoping to start mine this week.
Old January 20th, 2014, 12:36 PM   #33
mgentz
Board Member
A few of us have more power than 300
Old January 25th, 2014, 03:03 PM   #34
Here's one thread with someone just finishing putting a 300 engine into a pre-gen:
http://www.ninjette.org/forums/showthread.php?t=165565
Old March 27th, 2014, 11:03 AM   #35
mjegan
Motorcycle(s): 1999 Ninja 250
Did you end up swapping the flywheel to get the correct ignition patern?
mjegan is offline   Reply With Quote
Old March 27th, 2014, 11:16 AM   #36
EMSRacer07
EMSRacer07's Avatar
For me I just took everything, wiring harness, ecu, etc and everything works great.
Idk how PeeFo did his, might have to make sure the pickups are the same for the pregen
Old March 27th, 2014, 11:38 AM   #37
mjegan
I've looked into it and the 300 and 250 flywheel have a different pickup pattern. I'm curious to how smoothing it works with a different tooth count.
Old October 6th, 2014, 08:40 AM   #38
ninja2007
Motorcycle(s): 2007 Ninja
Does the Pregen or 08-12 exhaust fit the under the 300 engine?
Thanks,
Zach
ninja2007 is offline   Reply With Quote
Old October 6th, 2014, 08:49 AM   #39
EMSRacer07
EMSRacer07's Avatar
Thanks,
Zach
The stock 300 exhaust does a S shape under the oil pan. So you could make it fit but i dont think it would clear the oil pan without any modification. Pregen doesnt work at all.
Old October 7th, 2014, 04:36 AM   #40
ninja2007
Thanks!
Comparing the 250 & 300 motor/engine (Version 2) cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 147 May 1st, 2023 08:34 PM
Comparing the 250 and 300 motor/engine (picture intense) cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 24 May 9th, 2014 03:48 PM
