Old October 25th, 2013, 01:42 PM   #1
Jono
Jono's Avatar
KTM RC390!!!!!
http://rideapart.com/2013/10/leaked-...014-ktm-rc390/
http://www.visordown.com/motorcycle-...ull/23845.html
The full details are as follows:
TELESCOPIC FORK
The KTM RC 390 high-quality upside-down fork from WP Suspension has the same 43 mm outer tube diameter as the RC8 R – in other words, real racing equipment that guarantees highest levels of stability and precision.
FRAME
Visually similar to the lightweight and approved Duke steel trellis frame, the orange painted frame has been modified to better fit the supersport ergonomics and dynamics. The increase of the steering head angle to 66,5 degrees results in a shorter trail, shorter wheelbase and increased ground clearance. All these modifications release the complete racing potential of the RC and guarantee quick, agile and playful handling.
INSTRUMENT
The 100% digital LCD display has everything you could expect from a state of the art KTM motorcycle, including engaged gear, fuel gauge and service reminder information. Just like supersport racing machines an RPM alert indicates when is the best moment for shifting up.
SWING ARM
The light alloy swingarm with directly linked WP shock absorber excels by providing extreme torsional stiffness and outstanding tracking stability.
WIND SHIELD
The advanced design wind shield in combination with the aerodynamic optimized motorcycle front ensure incredible wind protection for rider’s chest and arms.
SEAT
The two-part seat offers first class supersport ergonomics with perfect support for rider and pillion. With a seat height of 820mm it enables the rider to have a secure stance whilst also being high enough for sporty use and real big-bike feeling.
FUEL TANK
A brand new steel fuel tank with 9,5l capacity (including 1,5l reserve) has been developed for the RC, perfectly matching the supersport style and vehicle design, together with rider ergonomics. Thanks to the economic engine the RC achieves impressive efficiency even when ridden hard for a considerable distance.
HANDLE BAR
Brand new clip on handlebars and switches contribe to a sporty and aggressive riding position combined with advanced control.
WHEELS
Equally lightweight as stable, the 17in orange painted cast light alloy wheels are fitted with grippy Metzeler tyres - 110 mm wide at the front and an impressive 150 mm at the rear. The tyres impress with tremendous grip in both wet and dry conditions, as well as providing supreme durability.
STANDARD ABS
ABS is equipped as standard on every RC 390, ensuring maximum safe on any road condition. When taking the RC to the racetrack ABS is of course disengageable.
SILENCER
The compact underbelly, three-chamber silencer is positioned close to the bike's overall centre of gravity. This aids the centralisation of mass and prevents accidental contact with the rider's and passenger's legs.
A2 LICENSE
With a power/weight ratio of 0.2kW/kg RC390 is right at the limit of the new A2 driver´s license, making the new KTM RC390 the sportiest option for A2 riders.
THIN TAIL
Fitting perfectly into the pure racing look the number plate holder rounds KTM’s high performance bike off.
BODYWORK
The brand new bodywork, footrests and pedals not only provide a unique supersport look but also help the RC to master extreme cornering by allowing a greater leaning angle.
INTEGRATED BLINKERS
As a special feature the RC incorporates blinkers into mirrors structure, which not just looks very sporty but also contributes to the perfect aerodynamics.
HEADLIGHT
Brand new twin headlight opens a new direction for KTM style and perfectly matches with the racing supersport look of the RC.
ENGINE
The state-of-the-art, liquid cooled, single-cylinder four-stroke 375ccm engine with twin overhead camshafts, four valves and electronic fuel injection, already equipped in the Duke 390 provides outstanding power and thanks to the balancer shaft, delivers the highest level of smoothness. Because of the KTM-typical compact design with stacked transmission shafts the engine has an unbelievable low weight of 36kg. Combine that with technical details like a forged piston, Nikasil-cylinder-coating and forced feed lubrication with power-promoting body-evacuation and you get an engine which provides a remarkable 44hp. The engine is equipped with an electric starter powered by a 12V/6Ah battery.
TRIPLE CLAMPS
The brand new forged aluminum triple clamps are eye-catchers and together with the clip on handlebars guarantee a pure supersport racing feeling.
PILLION RIDE SEAT
In order to make no compromises in terms of supersport look the KTM engineers integrated the pillion seat into the bodywork lines so that it looks like a real racing bike tail, but ensuring excellent comfort for the passenger.
BRAKES
KTM developed in cooperation with Brembo a powerful and easy to control brake-system which allows the rider to be always in control of the RC. A four piston radially bolted caliper in combination with a single brake disk (300mm diameter) in the front and a single piston floating caliper with a single brake disk (230mm diameter) for the rear wheel guarantee excellent braking response even under the most extreme conditions.
Who is selling their 250 or 300??
Last futzed with by Jono; October 25th, 2013 at 10:57 PM. Reason: More Details
Old October 25th, 2013, 02:08 PM   #2
I like the way it looks. Specs look great, especially the low weight. But the 2.6 gallon fuel tank worries me a bit. Riding it swiftly could mean a range of right around 100 miles.
Old October 25th, 2013, 03:16 PM   #3
oblivion007
"scandal!"
Motorcycle(s): 2011 250R(Crashed 2/26/2014), 09 ER6n
Ya beat me to it! haha Waiting for it to hit the US! Might dish out my 650 for it.
oblivion007 is offline   Reply With Quote
Old October 25th, 2013, 03:34 PM   #4
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Aw, HELLZ yeah!
Old October 25th, 2013, 03:41 PM   #5
Gurk
Done here.
Motorcycle(s): -
so buying that. is ktm capable of making ugly bikes? i think not.
Gurk is offline   Reply With Quote
Old October 25th, 2013, 03:51 PM   #6
Christofini
Christofini's Avatar
Motorcycle(s): '08 Ninja 250R
Interesting design. Shame they didn't go with the Moto3 fairings. Depending on the price I might be interested...since it's only got 1 cylinder I'm assuming it's a budget bike?
Christofini is offline   Reply With Quote
0 out of 1 members found this post helpful.
Old October 25th, 2013, 04:11 PM   #7
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Man, if that comes to America in the spring I'm gonna have to add it to the stable. So nice.
Old October 25th, 2013, 04:15 PM   #8
adouglas
adouglas's Avatar
Man, in between this and the new BMW NineT, I'm feeling kind of funny in my pants.
Old October 25th, 2013, 04:26 PM   #9
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I need to start saving now.
Old October 25th, 2013, 04:26 PM   #10
thisisbenji
thisisbenji's Avatar
Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom
Thumbs down
Watch this never actually make it to the states.
My Old Bike
My New Bike
thisisbenji is offline   Reply With Quote
Old October 25th, 2013, 04:30 PM   #11
Well, they have made some questionable styling decisions in the past, at least.
Old October 25th, 2013, 04:32 PM   #12
thisisbenji
Right... but that one's so questionable it's actually pretty good looking. It would be like riding around on a Halloween costume, complete with black and orange color scheme.
My Old Bike
My New Bike
Old October 25th, 2013, 06:49 PM   #13
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
looks really nice from the back and side but the front looks absolutely horrendous.
Aggrotech is offline   Reply With Quote
Old October 25th, 2013, 07:10 PM   #14
Jono
Jono's Avatar
Eh, I am now used to filling up around then anyways with my KLX250 which only has a 2 gallon tank. But I can see many people complaining about that. Doesn't bother me a bit, just less weight! This isn't a bike you would want to cruise on for more than 100miles based on those race-like ergos anyways. Fill up the tank and stretch your legs. And repeat until satisfied/sore.
Old October 25th, 2013, 07:11 PM   #15
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
I like the way it looks and I like the suspension. I like the power to weight ratio too,.. but I like this package better as the 390 Duke.
I'm just not sold on the thumper motor in a sport bike, needs at least one more cylinder IMO. So no, I won't be selling my ninja 300 for one.
Old October 25th, 2013, 07:38 PM   #16
bdavison
Wartown, USA
bdavison's Avatar
Um, I'm not big on thumpers, but I will seriously drop coin for this bike in a heartbeat. Billet swingarm, proper suspension, underbody exhaust, trellis frame and 43hp. Its about time someone figured out how to make a small displacement sportbike.
Old October 25th, 2013, 08:10 PM   #17
ChickenRun
ChickenRun's Avatar
Motorcycle(s): 2010 250r SE (without stupid tribal decals)
If it was twin cylinder then I would already be making down payments for it.
"It sounds like a lawnmower."
"Shut up no it doesn't."
ChickenRun is offline   Reply With Quote
Old October 25th, 2013, 08:37 PM   #18
Aufitt
The A Team
Aufitt's Avatar
Motorcycle(s): Z50, CB125, RZ500, MC22, R3.
If it was a twin I'd hate it
Light sporty thumpers suit this style sportsbike.
Not sure if its really what the USA market is into, you probably wont 'get' it, that's why so many small bikes havnt been released in the US over the past 3 decades.
Aufitt is offline   Reply With Quote
Old October 25th, 2013, 08:58 PM   #19
Panda
not an actual panda
Brilliant bike! I want one.
Old October 25th, 2013, 09:00 PM   #20
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Aw, HELLZ yeah!
officially one of the most beautiful bikes I have ever seen. now I'm torn on what I want, cbr600rr/supermoto/ktm rc390.
Old October 25th, 2013, 09:02 PM   #21
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
Light sporty thumpers are called supermotos, and they're way lighter and just as powerful as this bike.
Old October 25th, 2013, 09:07 PM   #22
...I need a tissue.
That spec sheet looks fantastic except the small gas tank. Good to see someone finally debut a small bike that's not made with the intent of selling to only the novice crowd. *fingers crossed*
Old October 25th, 2013, 09:09 PM   #23
Aufitt
The A Team
Aufitt's Avatar
And long before dirtbikes became tards that there was Supermonos
The 390 is only 44hp because of market restrictions.
Old October 25th, 2013, 09:24 PM   #24
Gurk
Done here.
Motorcycle(s): -
Eeehhhh yeah that's not the best design. hahaha. but KTM RC8R is still one of the best beautiful bikes out there for me.. And this 390 is really up there.
We were disagreeing with max @Trailerboy531 about 390's headlights earlier. He hates them. I kinda like it. I'm tired of seeing "pissed off eyes" kind of headlights on every sport bike nowadays.
Old October 25th, 2013, 09:27 PM   #25
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
that's a good point there really isn't much else in terms of headlights on supersports/superbikes other than "pissed off eyes" though I'm not a fan of the RC8 headlights these are sick looking, kinda like the rest of the bike.
Old October 25th, 2013, 09:32 PM   #26
Gurk
Done here.
Motorcycle(s): -
Yeah I like how there's a whole sculpture to the front of the 390 and headlights are inside that form. Instead of what a lot of bikes do nowadays which is just stick the headlights on the front just flat.
Old October 25th, 2013, 09:42 PM   #27
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
Is it 43hp at the rear wheel or at the crank?
Old October 25th, 2013, 09:44 PM   #28
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
crank, I believe it's around 39hp at the wheel.
edit: it's the same engine as the duke 390 naked bike.
Old October 26th, 2013, 05:17 AM   #29
adouglas
adouglas's Avatar
Old October 26th, 2013, 06:40 AM   #30
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
It's a nice bike, but I still see no evidence of it coming to the US.
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Old October 26th, 2013, 07:02 AM   #31
Joshorilla
Bass Master General
Joshorilla's Avatar
every time I look at the KTM side I look at the RC8R and wish they did something smaller, this my friend, is my new bike
Old October 26th, 2013, 07:28 AM   #32
Aodrn
It's a long boring story
Aodrn's Avatar
Motorcycle(s): 2012 Ninja 250
I think it looks like an excellent street bike, but it suffers from the same problem as the Honda. My 250 will lap the Honda 250 on the track because it can't rev. Its a shame the bike looks so track capable, but lacks a cylinder.
#41 MCRA
alex.s :crashing is a normal part of life... people are just in denial about that.
Aodrn is offline   Reply With Quote
Old October 26th, 2013, 08:04 AM   #33
Reswob
Reswob's Avatar
Motorcycle(s): 2008 Triumph Bonneville Black
Well this one isn't exactly a looker. Seems the front end design department was told they were making an enduro while the rest of the team was working on a sportbike. Specs are nice but a single? PASS!
'08 Bonneville Black
sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator
Reswob is offline   Reply With Quote
Old October 26th, 2013, 08:11 AM   #34
Jono
Jono's Avatar
Why so much single cylinder hate??? I don't understand.
Old October 26th, 2013, 08:20 AM   #35
Aodrn
Aodrn's Avatar
Revs are necessary for an effective track bike. That's why you only see freak ducati v twins on the track. Singles have great off the line punch. I would wager the thumper Honda is a better street bike than the 250. (I haven't ridden one so i can't say for sure)
#41 MCRA
Old October 26th, 2013, 08:20 AM   #36
Gurk
Done here.
Motorcycle(s): -
Below article says the slide was at the KTM North American dealer meeting. Soooo I assume it will be available for the US?
"The 2014 KTM RC390 has been a long-time coming, as news of the bike has been in circulation since a leaked slide at the KTM North American dealer meeting hit the internet over two years ago. Built off of the KTM 390 Duke street bike, KTM said the RC390 would have “Moto3 inspired” bodywork when it debuted."
http://www.asphaltandrubber.com/bike...os/#more-49016
Old October 26th, 2013, 08:22 AM   #37
Joshorilla
Bass Master General
Joshorilla's Avatar
Lots of reasons, some true, some exaggerated, some false.
It's more a case of marketing / engine characteristics.
Expect the 390 to RC390 to be more powerful than the Ninja 300, more so with a power tuning to bring it above the A whatever limits for europe.
I think the duke would have done better if the guy didn't bounce off the rev limiter so much, and the RC390 would be more aerodynamic.
Old October 26th, 2013, 08:44 AM   #38
Aufitt
The A Team
Aufitt's Avatar
Singles are much better on change of direction.
plus the 390 has a decent frame, and is lighter.
My cbr250 was 2 secs slower (at the time) vs my EX250 at one track, and 3 secs at a more open track,
Ninja is faster as can hold a gear for a lot more sections and gets a higher top speed,
but feels like a heavy porker and very vague in its handling in comparison, it pushes the front .. but have learnt to ride it on that mushy edge. (0.3 secs off local 250 laptime so right on pace)
I'd guess the 390 to be as agile as the cbr250 but more power than a Ninja 300
quality aside, it should be a little demon. (we hope)
Corner speed is king.
Old October 26th, 2013, 08:55 AM   #39
Aufitt
The A Team
Aufitt's Avatar
^PS both those riders could do with a huge improvement, they lose so much!
Gear changes (clutched!) and are rough as guts,
the 300 wobbles away off the line with BOTH feet out,
the 390 keeps hitting the limiter every gear.
They could take at least a second or two off.
Old October 26th, 2013, 09:02 AM   #40
Joshorilla
Bass Master General
Joshorilla's Avatar
It's true! they were shocking, like you said clutched slow changes and bouncing off the rev limiter, wobbling, ****** riding.
I expected the 390 to woop the 300 at the line though, I am just chalking it up to bad riding.
[motorcyclenews.com - reviews] - KTM RC390 (2014-current) Ninjette Newsbot Motorcycling News 0 October 24th, 2014 10:40 AM
[motorcyclenews.com - reviews] - KTM RC390 (2015-current) Ninjette Newsbot Motorcycling News 0 September 17th, 2014 01:20 PM
[motorcyclistonline] - 2015 KTM RC390 | FIRST RIDE Ninjette Newsbot Motorcycling News 0 September 4th, 2014 03:40 PM
[visordown.com] - KTM RC390 leaked in full Ninjette Newsbot Motorcycling News 0 October 25th, 2013 02:20 PM
[visordown.com] - KTM's new RC390 Ninjette Newsbot Motorcycling News 0 July 15th, 2013 08:20 AM
