November 10th, 2013, 03:29 PM | #1 |
Leaking fluid... should I taste?
Yes, my question is literally as crazy as it sounds.
I took my tank off last night to pull my carbs to futz with my float heights, but discovered some fluid along the left side of the the engine along the valve cover gasket. Upon visual inspection the valve cover and gasket appear to be seated properly. There isn't enough fluid yet that it's all over, so I think I caught it fairly early. The fluid is dirty, so the color doesn't really tell me much, but it does not smell like fuel. It's also not enough to be obvious. I think it's either oil or coolant. The leak appears to start around where the water-pipe goes down into the the block. It seems like this location really could be spot either oil or coolant might leak, but I'm guessing it's more likely coolant. I tried to smell for sweet, but again it's a small enough sample that I'm not possitive. So.... should I try tasting it? I know coolant is poisonous if you drink it, but a small lick???? I read some sciency thing once about how doctors saved someone who drank coolant by forcing vodka into their system. Apparently the etoh. chemically reverses some badness by converting the death in the coolant to something else. That was my understanding, but I don't think a lick and spit would be bad..... I know Dr.s used to do urine tests by tasting it themselves... years ago of course. I can't believe I'm actually asking this, but should I try it or commit myself for being a danger to myself?
November 10th, 2013, 03:48 PM | #3 |
MOTM - Sep '18, Feb '16
Don't taste it. Its probably coolant. The hose going into the head has a tendency to leak. Has the valve cover been off?
Coolant taste sweet. And it is poison. If it is just a trace and not enough to drip. Leave it.
November 10th, 2013, 04:52 PM | #4 |
OK, I won't taste it... thanks for saving my life.
November 10th, 2013, 05:01 PM | #5 |
Join Date: Sep 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R, 2008 Suzuki GSX-R600, 2006 Suzuki GSX-R600 Posts: 31
I would not taste it - if you can get some on your finger, I would imagine oil would be more slippery, oily than coolant.
Has the valve cover ever been off? I know you said it looks sealed, but it's possible it might not be if it was removed and not put back on correctly. I would wipe it all up, and just keep an eye on it. If it comes up again soon, the coolant should be a watery green, and if it comes up again soon as dark, it's probably oil. |
November 10th, 2013, 05:15 PM | #6 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
November 10th, 2013, 05:21 PM | #7 |
Yes, it's been off several times. I've done a handful of valve adjustments, but the last one was long enough ago that I would have seen leakage earlier if that was the problem. I just removed the cover and inspected everything. It appears there is a little brown-milky fluid around the pipe, which I'm assuming right now is coolant.
I pulled the pipe and inspected it. (Did the same on my spare [original] motor that lives on a stand in the corner, for reference.) There isn't anything obvious, but the gasket is probably worn, thus the cause of the leak. I was dreading leaving my bike in pieces over the next week and hitching rides while I wait for a $.77 + $5-10 shipping part, until I remembered something....... A few years ago I purchased in advanced all the parts the manual calls for for one of the major services. This one included all the gaskets for the water lines. I never installed them because I didn't think something that wasn't broke needed fixing. I dug through my parts and sure enough, I've got two spares! Not only that but I cataloged it in a way that is idiot-proof so I'd know what it was later. Feelin' awesome right now!
November 10th, 2013, 05:50 PM | #8 |
Sweeeeeeeeet
November 10th, 2013, 05:57 PM | #9 |
Join Date: Sep 2013 Motorcycle(s): 09 Ninja 250 Posts: 13
Wow. You are smart. Every time I put something away where I can find it. I don't find it again until I don't need it again. Good stuff.
November 10th, 2013, 07:13 PM | #10 |
I demand a poll!! The answer's always yes. YOLO!
November 11th, 2013, 10:46 AM | #11 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Just for reference, I think it is also the same as the small o-ring you get with the fram/aftermarket oil filters.
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
November 11th, 2013, 10:54 AM | #12 | |
EDIT: I just cross-referenced the part numbers, and can confirm these are indeed the same.
petcock leaking | s3an78 | 1986 - 2007 Ninja 250R Tech Talk | 15 | August 18th, 2014 06:32 AM |
leaking oil D: | TwoSixSided | 2008 - 2012 Ninja 250R Tech Talk | 4 | December 3rd, 2013 06:06 PM |
Coolant leaking into oil and oil leaking out of somewhere. | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 31 | May 25th, 2013 04:09 PM |
A little taste of mud | Lou | Pictures | 11 | September 15th, 2011 12:11 PM |
leaking petcock | crackerjack | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 15th, 2010 11:47 AM |
