April 4th, 2014, 05:28 PM | #1 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
Tank Pad Not sticking!
We put a new tank pad on my GFs 300 and we tried heating it up by putting it in a zip lock and submersing it in hot water to make it more flexible.
We stuck it on the tank and the edges of it seem to be coming loose and sticking up! We washed the bike. Dried it and buffed it with a microfiber towel before applying the tank pad/ Does anyone know a way to make the glue more adhesive? and do you think using a hair dryer to help it flex and adhere to the tank is a good idea? thats what it said on a slip the ebay seller included with the stick on pad.! Its pink and has a ninja chick in it. so my gf really likes it! now we just need it to really adhere!!!
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
April 4th, 2014, 06:33 PM | #2 |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
this thread: http://www.ninjette.org/forums/showthread.php?t=173109 advises using outdoor adhesive if that helps
April 4th, 2014, 07:07 PM | #3 |
Track Clown
MOTM - Sep '15
did you wipe the area with rubbing alcohol?
April 4th, 2014, 09:51 PM | #4 |
Intrepid Adventurer
no I didn't! is that basically to make it cleaner?
I cleaned it very thoroughly but I think I screwed up peeling the paper off of the adhesive side. Also the pad was a little stiff so it didn't want to flex. I think next time I will heat it with a hair dryer and clean the surface with alcohol ! I will just order another on Ebay. oh well . live and learn
April 5th, 2014, 04:18 PM | #5 | |
Track Clown
MOTM - Sep '15
April 5th, 2014, 04:22 PM | #6 |
antiant
MOTM - Oct '14
April 6th, 2014, 09:25 AM | #7 |
Intrepid Adventurer
Has anyone put a regular tank pad on a ninja 300??
I tried to do my best and the tank pad stuck ok at first but later the edges lifted where it had to bend over the ridges of the tank. The ninja 300 tanks are shaped funny and really ruined my feeble attempt at adding a tank pad errrg
April 6th, 2014, 10:24 AM | #8 | |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
New Upgrades - Fender Eliminator, Tank Pad, Tank Overlay Stickers | bbjminardo | 2008 - 2012 Ninja 250R Farkles | 7 | March 22nd, 2013 03:51 AM |
Homemade tank pad? | Yakaru | 2008 - 2012 Ninja 250R Farkles | 1 | September 15th, 2012 09:22 PM |
tank pad | qwkartist2000 | 2008 - 2012 Ninja 250R Farkles | 5 | November 28th, 2011 01:39 AM |
Tank Pad | saxnbass | 2008 - 2012 Ninja 250R Farkles | 6 | November 12th, 2011 09:55 PM |
Tank pad suggestions | sofo | 2008 - 2012 Ninja 250R Farkles | 4 | July 15th, 2009 08:42 PM |
