May 21st, 2014, 09:08 PM | #1 |
Join Date: May 2014 Motorcycle(s): 2007 Ninja EX250 Posts: 78
Clicking, and Squeaking noise.
So. My engine is squeaking, clicking/ticking, and will only rev to like 5000 RPM, and it is scary when you rev it. I did my best to adjust the valves, it is better than it was before, it was only revving to 3000 RPM, is it still the valves or what? The bike only has 1500 Miles on it.
May 21st, 2014, 09:29 PM | #2 |
That is not a good sign at all. Is the cam chain tensioner functioning properly? I find it hard to believe that your valves need adjustment with that low of mileage. You wouldn't happen to have a video or sound of it running?
May 21st, 2014, 09:50 PM | #3 |
Well. I don't have a video. But I'll get you one. I didn't check the tensioner, I don't even know where it is. What does the noise mean?
May 22nd, 2014, 03:59 AM | #4 | |
It may also help you to look at the Troubleshooting Guide to help determine what may be wrong with your bike. |
May 22nd, 2014, 01:27 PM | #5 |
Before I post a video, I want you guys to read what the person who posted this (http://www.kawiforums.com/ninja-250r...ing-noise.html) said. I had all these things happen except coolant loss and my engine started ticking the next time I was able to run my engine. Oh and I did use sea-foam in the gas. I also run 10W-30 fully Synthetic.
May 22nd, 2014, 01:30 PM | #6 |
it's kinda nice that you don't have to remove the cams or chain to adjust the pregen valve clearance
May 22nd, 2014, 01:32 PM | #8 |
May 22nd, 2014, 01:33 PM | #9 |
May 22nd, 2014, 01:53 PM | #10 | |
May 22nd, 2014, 01:54 PM | #11 |
Does it sound like this?
May 22nd, 2014, 01:55 PM | #12 | |
May 22nd, 2014, 01:56 PM | #13 | |
May 22nd, 2014, 01:57 PM | #14 |
if you fix your video link, maybe we would be able to hear it and give you a better answer
May 22nd, 2014, 01:57 PM | #15 |
Give the video 20 minutes and you can play it.
May 22nd, 2014, 02:00 PM | #17 |
May 22nd, 2014, 02:05 PM | #20 |
May 22nd, 2014, 02:06 PM | #21 |
yep. what does the inside look like? were all the valves going up and down all the way? seems pretty hard to tell without taking the cams off.
May 22nd, 2014, 02:08 PM | #22 |
May 22nd, 2014, 02:15 PM | #23 |
how closely were you paying attention? i have missed the fact that a valve did not return completely all the way up before until taking a second look.
what is the chain spec at? is it stretched beyond recognition? could just be that the timing is so far off a piston is tapping a valve. just so you know the difference... 30w runs 30cSt at 100c. 40 being 40cSt at 100c. you are talking about a quarter less viscous oil than what the crank was designed for. this means that it is much more likely that it will mar the plane bearing because the oil isn't providing enough suspension between the two parts. if you're easy on the engine maybe it doesn't make any difference. but if its already got issues or you are stressing the engine, you are taking away vital cushion between the crank and rod planes and the crank and case and you are putting play into those systems which means they will degrade quicker. engines are spec'ed to a specific oil weight for a reason.
May 22nd, 2014, 02:15 PM | #24 |
My guess is that his valve timing is off a tooth. Or bent valve.
May 22nd, 2014, 02:18 PM | #25 |
Think maybe its the cam chain?
May 22nd, 2014, 02:18 PM | #26 |
you can check the condition of the cam chain by taking the cover off and measuring the distance between 20 links. there is a spec somewhere. i think its like 127mm or something
May 22nd, 2014, 02:20 PM | #27 | |
May 22nd, 2014, 02:24 PM | #29 | |
May 22nd, 2014, 02:24 PM | #30 |
Cam chain spec here in this thread: https://www.ninjette.org/forums/showthread.php?t=104334
May 22nd, 2014, 02:26 PM | #31 |
May 22nd, 2014, 02:26 PM | #32 |
you can check timing by putting the engine to tdc2 (i always forget... it is 2 right? maybe its tdc1) and looking at the cam sprockets. they have marks that should line up with the head case edge. if you take off the top chain guide from off the cams, you can measure/pull on the cam chain which gives you a better idea of how stretched it is.
May 22nd, 2014, 02:27 PM | #33 |
Top of the page in the tech section is a sticky of the how to-tos.
http://faq.ninja250.org/wiki/What_is...t_procedure%3F
May 22nd, 2014, 02:27 PM | #34 | |
May 22nd, 2014, 02:50 PM | #35 |
No, it's not. It's very possible. Your video sounds just like this one. Which BTW had a spun rod bearing.
Link to original page on YouTube. |
May 22nd, 2014, 03:17 PM | #36 |
Well. I think it might of jumped time. If I move it to where the IN mark on the intake cam is, the EX mark on the exhaust can doesn't line up with the top of the head.
May 22nd, 2014, 03:26 PM | #37 |
Is it off time? You can't even see the EX mark
And on a side note like my mod? |
May 22nd, 2014, 03:36 PM | #38 |
it doesn't look that far off.
maybe the chain is stretched a little bit but it looks like timing is reasonably close. still could be a bent valve or a blown journal like blue said, examine your oil screen
May 22nd, 2014, 05:21 PM | #39 |
Bearing it be. F**K!
May 22nd, 2014, 05:22 PM | #40 |
Its damn glitter.
Ticking/clicking noise? | rmorse | 2008 - 2012 Ninja 250R Tech Talk | 18 | August 15th, 2012 07:36 AM |
Quiet squeaking noise coming from gas tank? | ajcadoo | 2008 - 2012 Ninja 250R Tech Talk | 13 | February 27th, 2012 09:25 AM |
Ticking/Clicking noise coming off throttle | patw | 2008 - 2012 Ninja 250R Tech Talk | 15 | September 4th, 2011 04:01 PM |
Strange clicking noise started last night... help? | modrummer | 1986 - 2007 Ninja 250R Tech Talk | 6 | August 28th, 2011 05:38 PM |
Help - squeaking noise coming from front wheel / fork? | muffinman | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 17th, 2009 05:11 PM |
