June 17th, 2014, 01:32 AM | #1 |
Join Date: Jul 2013 Motorcycle(s): 1990 GPX250, 1998 Suzuki DRZ400E Posts: 26
Gpx 250 clutch issue (i think)
Hi,
My father and i just replaced the clutch plates in our Gpx250. Now that we have done that the bike starts and runs fine, doesnt go anywhere or do anything in 1st (makes a clunk like normal) as if it was in neutral and we are unable to shift up from neutral. What could be the cause of this? |
June 17th, 2014, 02:11 AM | #2 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
You have the clutch pressure plate out of index. The plate cannot compress the clutch plates. There is a mark on the basket and the pressure plate that have to line up. Once you see how it works, you will understand.
The bike will not shift into 2nd gear unless you are moving. The feature called "neutral finder" makes it easy to find neutral while sitting still. Take the clutch apart, orient the pressure plate, reassemble, and ride.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
June 17th, 2014, 02:33 AM | #3 | |
EDITED to say holy crap your a saviour, thank you so much. i found photo of an sv650 with the markings on the pressure plate and was able to find markings on my gpx. thanks you so much for the help. you really did save me, i wouldnt have slept tonight if i hadnt have been able to fix it (it's 8:00pm here) Last futzed with by bowerbird100; June 17th, 2014 at 03:05 AM. Reason: don't need what i asked for anymore. :) |
June 22nd, 2014, 03:14 PM | #4 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
Originally Posted by jgcable; I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it. |
04 250 Clutch Not Disengaging After Issue...Please Help! | yukongt94 | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 1st, 2011 07:17 PM |
Replacing clutch basket on 88 gpx RII | qwaka | 1986 - 2007 Ninja 250R Tech Talk | 5 | August 28th, 2011 04:52 PM |
