July 17th, 2014, 12:26 AM | #1 |
Join Date: Jun 2013 Motorcycle(s): 2001 ex 250 Posts: 49
Where to relocate stuff?
Hi everyone. Been a while since I've been on here but I'm continuing my cafe project and was about to take off the rear fender. I was wondering how everyone relocated the stuff attached to the fender. I did the search but couldn't really find any detailed explanations of how stuff got relocated. If you could link me to a thread that would be cool too.
Oh I'm also taking out the airbox and am actually just planning to trim the rear fender like how @Chicagobob did. |
July 17th, 2014, 07:28 AM | #2 | |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
If you take out your airbox, you'll have more room elsewhere to mount stuff, like on the rear fender, battery box, or maybe on a plate attached to the top of the frame rails. You should try to isolate it from spray from the rear wheel. |
July 17th, 2014, 09:21 AM | #3 |
@Chicagobob okay sorry if this is a silly question but I can't think of how to mount a custome plate to the bike frame. Would I just try to use whatever available stock holes there are or is there a way to mount to the frame without welding?
July 17th, 2014, 11:04 AM | #4 | |
There are several options that don't require welding. Since an electrics tray is usually not load-bearing, you could attach it with double-sided tape (foam core servo tape is the strongest). You could also use pop rivets, which require drilling (usually 1/8" holes), but can easily be removed (also by drilling). Finally, you could bolt it on, either with self-tapping screws, bolts into tapped holes (weak, because the tubes are made of soft steel), or bolts through the entire frame tube (May crimp the tube if tightened too much, and adds the bulk of nuts). I've even seen guys use hose clamps, which is how Vetter used to mount its fairings. On our 250, we used the self-tapping screws to attach sheet metal items to the frame, but on later projects we've had cleaner results with pop rivets for light-duty fastening. We haven't had problems with them failing or vibrating loose. Whatever you choose, good luck with your build. |
July 17th, 2014, 11:13 AM | #5 |
typically i relocate parts to the trash can
July 17th, 2014, 12:31 PM | #6 |
July 21st, 2014, 05:59 AM | #7 |
Join Date: May 2014 Motorcycle(s): 99 Ninja 250 Posts: 217
You can check out my build thread as I am in the process of turning mine into a naked/cage bike. I made some new brackets and what not which helped relocate a good amount of parts and also was able to hide the fuse box under the gas tank. My thread is called "My first bike project!" if you want any ideas. It is not done yet so not all my pictures are uploaded.
July 21st, 2014, 08:55 AM | #8 | |
July 21st, 2014, 09:13 AM | #9 |
I know it may not be the nicest looking way of doing it as I am new to fabricating and I did not weld anything. Everything I did can be put back to original. I got my ideas from many different people throughout the forum and internet so credit is given to all of them. I am trying to do it cheaply but I did not have certain items so the price has increased over the past few weeks.
[roadracingworld.com] - What's Better Than Cool Stuff? Cool Stuff For Free! Take The | Ninjette Newsbot | Motorcycling News | 0 | March 12th, 2014 12:20 AM |
HELP. WTF is This stuff? | krolinked | 2008 - 2012 Ninja 250R Tech Talk | 20 | February 9th, 2013 06:28 PM |
Choke cable relocate | pjed | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 21st, 2012 04:39 PM |
Hugger and some other stuff | bowersox3589 | Motorcycle-related | 4 | October 12th, 2011 10:42 AM |
License Plate Relocate Fail | HKr1 | General Motorcycling Discussion | 24 | April 16th, 2011 07:00 AM |
