September 30th, 2014, 08:57 AM | #1 |
Replacing Dash Lights
Hi guys.
My speedometer lights went out and i need to replace them. Does anyone know how to do this (with pictures) and know what bulbs to use? thanks!! |
September 30th, 2014, 10:17 AM | #2 |
Join Date: Oct 2013 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 219
https://www.ninjette.org/forums/showthread.php?t=169472
these are the ones i purchased: http://www.ebay.com/itm/111197894979 |
September 30th, 2014, 10:29 AM | #3 |
MOTM - Jan '18, Sep '13
As he showed above, get T10 wedge bulbs.
I got some cheap LEDs off ebay as well. Keep in mind that electricity only flows through LEDs in one direction, unlike a normal bulb, so if you plug it in the wrong way it won't turn on. It's not broken though. Just swap them around until they light up. You may want to keep a normal bulb for the turn signal indicator though because it won't work as intended otherwise. You can literally reach behind the gauge from under the bike and pluck out each bulb to swap, although its a tight fit. I did it blind, but you can just count how many you've swapped. The bulbs pop out super easily. There are 7 bulbs total. Picture of the back here: https://www.ninjette.org/forums/show...58&postcount=5
My Ninja 300 |
September 30th, 2014, 11:05 AM | #4 |
thanks for answering my question. I already ordered the bulbs hopefully they come in soon. =)
Now about reaching from under the bike to the back of the dashboard.... is there something i should be looking for? Or is it better from left/right side? Thanks |
September 30th, 2014, 11:08 AM | #5 |
I just moved around a lot to get to the angles I needed. Granted I have tiny hands so you'll have to see if you're able to get to all the bulbs lol.
My Ninja 300 |
October 3rd, 2014, 05:54 AM | #6 |
Wow you must have some tiny hands. My bulbs came in last night and I tried to get to the back of the dashboard but couldn't reach
Option b? |
October 3rd, 2014, 06:07 AM | #7 |
Remove your handlebars and take off the cover that it is seated in.
Paint side up, rubber side down! |
Dash lights flickering no starter ?!?! | jamasda | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 6th, 2014 08:06 PM |
...Dash Lights. | himynameisjoe | 2008 - 2012 Ninja 250R Tech Talk | 11 | January 20th, 2013 09:57 AM |
Dash lights | Flashy | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 23rd, 2012 07:42 AM |
dash led lights | jnz | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 24th, 2012 08:49 AM |
Dash lights/ front headlights flickering? | gilmorec61 | 2008 - 2012 Ninja 250R Tech Talk | 17 | February 27th, 2012 08:42 AM |
