Old January 28th, 2015, 06:36 PM   #1
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Gixxer shock on a pregen (with pics)
There are probably as many different ways to do this project as there are people that have done it, here's how I did it.
to start with the stock shock is 12.5" c to c
as you can see I've added a preload spacer about 3/4" thick under the stock spring
GSX-R shock is also 12.5" c to c (might be 1/16" under)
first I drilled out the eyelets to 15/32" to fit the stock Ninja bolts
then we have to grind or file or machine the bottom clevis on the inside to fit the lower Ninja bushing from the suspension linkage
I chose to use the grinder, be careful to not take out too much material or the aluminum clevis will bend or break when you tighten the lower linkage bolt
the upper shock mount bracket interferes with the Gixxer shock where the front of the rear fender bolts up
so away with it (the bracket), I used a sawzall with a metal cutting blade
aaauh, fits much better
now I cut the battery box off of the air box (I used a hand hacksaw)to move it up about an inch
I used a couple of sheet rock screws to reattach the battery box
then I cut the front of the rear fender
to slide it under the battery box and reattach it with the 2 bolts in the bottom of the battery box
have to drill a new hole in the overflow mounting tab as the rear fender gets relocated a little
Put you plastics back on and your ready to go. Static height is 1/4" lower as the stock shock with the spacer did not sag under it's own weight, however the sag (with rider) ended up the same (about 1.25"). I used the stock Gixxer spring and all the stock Ninja linkage and bones.
Old January 28th, 2015, 08:30 PM   #2
Great pics !!!
Old January 28th, 2015, 09:14 PM   #3
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Thanks this answered many questions I had.
My Cafe Racer Build
My intro post
Old January 28th, 2015, 09:50 PM   #4
Old January 30th, 2015, 11:03 AM   #5
spent_too_much
spent_too_much's Avatar
Great, simple write up. The pics are very helpful - especially the one that depicts where to grind for the lower shock mount spacer.
Did you need to shim your dog bones, to space them out a little bit? I have read where others state that they catch on the the shock spring.
Old January 30th, 2015, 04:04 PM   #6
Z1R rider
Z1R rider's Avatar
I've done it to this one (a 2000) and an 02 without a problem, it's close but a miss is as good as a mile.
Maybe they had a different year shock or something I can't even tell you for sure what year these are as my son just picked them up off ebay, but I've got 3 of them and they're all the same.
Old February 5th, 2015, 06:48 PM   #7
rubber side down
rubber side down's Avatar
Motorcycle(s): 01 gixxer 1k, 02 gixxer 600, 02 ninja 250, a slew of dirt bikes
2009 is the year of shocks. I think 08 was the same shock. 07 and older have the resevior up higher which runs more interference with mounting it. The 09's have the pretty blue anodizing on them. ha ha ha.
rubber side down is offline   Reply With Quote
Old February 5th, 2015, 07:01 PM   #8
Ghostt
Ghostt's Avatar
I dig ANY DIY project, awesome job
violente et ignorantia
ZX-2R BLOG
Old February 7th, 2015, 04:44 PM   #9
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
For whatever it's worth, Racetech's calculator breaks them down into '01-'03, '04-'05, and '06-'09. They're listed as having 450#, 425#, and 525# spring rates respectively. For comparison, the PreGen is 440# and the NewGen is 520#.
Just browsing some eBay pics, it looks like the '06-'07 ones have the reservoir sticking pretty much straight out, like the '08-'09 ones, as pictured in the first post. The '04-'05 and '01-'03 ones both have it angling up quite a bit.
Old February 11th, 2015, 09:12 AM   #10
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
yes, I have an 05 gxsr 600 shock and the reservoir sits pretty hi...
Qomomoko is offline   Reply With Quote
Old July 8th, 2019, 11:16 PM   #11
Updating this DIY guide to simplify and make it even easier to do. For those wishing to install GSX-R shocks on Ninjette, there is no need to drill out upper shock bushing or your frame mounts. The 10mm bolt used for GSX-R shock is fine because it generates sufficient friction to hold bushing in between ears.
To use factory unmolested 12mm mounting ears and 10mm shock eyelet, you just need two sleeves like this. Might need to remove 1mm from width to not extend beyond width of mounting ears on frame. These fill up larger hole in frame mounting ears and allows simple bolt-on use of GSX-R 10mm bolt.
Polaris # 5135275 - https://www.ebay.com/itm/302898035590
Old December 26th, 2019, 12:39 PM   #12
Ceeloo Yello
Motorcycle(s): 250
Would it also work if you were to grind down the bushing instead of the lower clevis?
Old December 26th, 2019, 03:32 PM   #13
Above instructions for top-mount of shock. Yes for bottom mount you can do:
1. narrow bushing on knuckle to width of shock clevis
2. use bushing-inside-of-bushing to fit shock clevis to factory bushing. Should be 12.7mm OD and 10mm ID. Just wide enough to tightly fit tightly inside clevis and factory bushing. This sleeve should fit inside factory bushing. Ream ID out to 10mm with length for tight fit on clevis on shock (slightly narrower than narrowed factory bushing so all clamping-pressure goes onto knuckle bushing).
This sleeve radially locates and centre GSX-R 10mm bolt inside of factory knuckle bushing once that's been narrowed to fit inside shock clevis. Lateral location is provided by narrowed factory knuckle bushing. Once bolt is fitted with minimal play, tightening it locks everything in place. Rotation is done by factory bushing inside of knuckle.
https://www.zoro.com/bunting-bearing...12/i/G4189586/
No hacking frame needed!
Last futzed with by DannoXYZ; December 26th, 2019 at 10:02 PM.
Old December 26th, 2019, 05:43 PM   #14
Ceeloo Yello
Motorcycle(s): 250
Cool, thank Danno
Old December 30th, 2019, 08:28 PM   #15
I need to take apart rear-suspension and confirm knuckle-bushing has enough extra-width to grind down to fit inside GSX-R's shock clevis... Perhaps this weekend...
Old January 21st, 2020, 02:38 PM   #16
Ceeloo Yello
Motorcycle(s): 250
Just took apart my pre gen for swing arm service and found that the nut for the upper shock mount is actually welded to the frame so most likely you would need to drill out the eyelet of the shock.
Old February 24th, 2020, 12:56 PM   #17
Ceeloo Yello
Motorcycle(s): 250
To answer my own question - the answer is no, the uni trak is also too wide.
Old June 11th, 2020, 02:13 PM   #18
Ceeloo Yello
Motorcycle(s): 250
Finally got my gixxer shock installed thanks to this great write up.
Gixxer rear shock question - rear stiffness too high cookiebug79 2008 - 2012 Ninja 250R Tech Talk 20 January 17th, 2015 08:19 AM
Pregen rear shock Josh_kcco Motorcycle-related 0 March 7th, 2014 11:23 PM
Best rear shock for the pregen Josh_kcco 1986 - 2007 Ninja 250R Tech Talk 17 March 6th, 2014 08:13 PM
Newgen rear shock in Pregen. 02337 1986 - 2007 Ninja 250R Tech Talk 35 October 31st, 2012 11:25 AM
PreGen Shock..fit NewGen? gamma500 2008 - 2012 Ninja 250R Tech Talk 13 October 19th, 2009 10:12 AM
