Old June 30th, 2009, 09:42 AM   #1
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
axle nut torque?
anybody have a maint. manual? i have mine tightened untill i can feel resistance turning the wheel then backed off so the wheel spins freely and i can get my cotter pins in.
I dont have a tourqe wrench unfortunatley just wondering
QTRltrPWR
nate-bama is offline   Reply With Quote
Old June 30th, 2009, 09:45 AM   #2
Snake
Snake's Avatar
MY shop manual is at the house. When I get home I can look it up for you. Do you need the torque for the front, back or both?
Old June 30th, 2009, 09:48 AM   #3
krbreton
krbreton's Avatar
Motorcycle(s): '97 Ninjette, '06 Ninja 650R
Front - 65 ft-lb
Rear - 80 ft-lb.
Good luck. Keep the rubber down.
-Kyle
Not all those who wander are lost...
-J.R.R. Tolkien
krbreton is offline   Reply With Quote
Old June 30th, 2009, 09:52 AM   #4
Jerry
Jerry's Avatar
Motorcycle(s): 2007 EX250
That "resistance" may be that you have the speedo re-installed wrong, it's easy to misalign it.
It's worth double checking.
Jerry is offline   Reply With Quote
Old June 30th, 2009, 09:53 AM   #5
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
thanks guys by the way does anyone have a manual that can be emailed..seems like i read a post somewhere
QTRltrPWR
Old June 30th, 2009, 09:56 AM   #6
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
yeah i think ill pull it back apart i know im nowhere near 65 ft lbs..with the speedo misaligned will it still read correct? mine is verified by rpm
QTRltrPWR
Old June 30th, 2009, 10:59 AM   #7
Jerry
Jerry's Avatar
Mine read right, but I only went a mile, and it was pretty hot.
If you find an online manual, it is illegal.
try this: http://faq.ninja250.org/wiki/Reinsta...he_front_wheel
Old June 30th, 2009, 11:27 AM   #8
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
thanks ive seen that a few times and i guess i just skimed that first paragraph
QTRltrPWR
Old June 30th, 2009, 02:03 PM   #9
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
ok got the tourqe wrench and yes my speedo drive was not meshed properly glad i got it back apart and put together safely...let the flaming begin
QTRltrPWR
Old July 2nd, 2009, 07:40 PM   #10
krbreton
krbreton's Avatar
All part of the learning process. Anything that doesn't cause an incident is just more wrenching experience.
-J.R.R. Tolkien
Old July 3rd, 2009, 08:22 AM   #11
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
yeah well thank god for my cotter pin skills
QTRltrPWR
rear axle torque sparkplug896 1986 - 2007 Ninja 250R Tech Talk 10 December 20th, 2013 03:41 AM
Front Axle Castle Nut JLinde1339 1986 - 2007 Ninja 250R Tech Talk 8 December 9th, 2011 01:23 PM
Hitch Pin for rear Axle nut? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 3 July 6th, 2009 08:30 AM
Rear Axle Nut Rawr 2008 - 2012 Ninja 250R Tech Talk 16 May 22nd, 2009 08:40 AM
Front Axle Nut Flashmonkey 1986 - 2007 Ninja 250R Tech Talk 6 May 9th, 2009 10:57 PM
