Old August 5th, 2015, 12:43 PM   #1
Ghostt
Ghostt's Avatar
Possible alternative for Factory Pro Blue Magic Shift Spring
I was wondering if the Blue Magic Shift Spring is worth the $30, or not. Or is there a cheap solution? Like maybe a spring from another model bike?
http://www.factorypro.com/Prod_Pages/prodk14.html
I welcome all comments.
violente et ignorantia
ZX-2R BLOG
Last futzed with by Ghostt; August 18th, 2015 at 02:43 AM.
Old August 5th, 2015, 01:01 PM   #2
why not just shim your existing spring
Old August 5th, 2015, 01:06 PM   #3
Ghostt
Ghostt's Avatar
I had considered that.
I'm guessing the Factory Pro is a higher rate, so if I shim the existing spring it wouldn't increase the spring rate, it would just be preloaded so to speak.
I know some of the earlier Kawasaki used the same set up, like the KZ750 FOR example, if one of those have a higher rate than the Ninjette.
ZX-2R BLOG
Old August 5th, 2015, 01:52 PM   #4
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
^^ correct, while a shim in the spring may help give a desired result - it is not apples to apples with replacing with higher rate spring. It would be nice to find a cheaper alternative. I suppose what we need to do is determine the rate of the stocker and get some dimensions.
Old August 5th, 2015, 02:05 PM   #5
Ghostt
Ghostt's Avatar
Now if I cut the OEM spring, and then shim the difference, then we are in business.
Just like fork springs.
ZX-2R BLOG
Old August 5th, 2015, 04:27 PM   #6
Ralgha
Ralgha's Avatar
I installed the blue spring in my bike. Definitely stiffer, though it did loosen up a bit with use. Haven't had any missed shifts with it, I like it.
Old August 5th, 2015, 07:37 PM   #7
sharky nrk
sharky nrk's Avatar
yeah that you could do
Old August 5th, 2015, 08:39 PM   #8
Ghostt
Ghostt's Avatar
Would you happen to know how much stiffer the blue vs OEM spring was? Did it look different, like the thickness of the spring/wire diameter?
I don't suppose to have a micrometer handy?
My theory about this spring is it's from another model bike, and Factory Pro found the one, and is either repackaging, or have them made to that spec.
I know earlier models of Kawasaki used the same design, I'm guessing it's one of those.
ZX-2R BLOG
Old August 5th, 2015, 08:44 PM   #9
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Curious but why the stiff shift spring? what are we looking for with the change?
Old August 5th, 2015, 09:04 PM   #10
Ghostt
Ghostt's Avatar
Okay so after some quick research, I found this spring, and it's many uses
92081-112 SPRING
Description
Purchase this Kawasaki 92081-112 SPRING --- SPRING, SPRING, NEUTRAL,POSITIONING
This Kawasaki 92081-112 SPRING is used on these models and components:
1981 KLT200-A1 KLT200 GEAR CHANGE MECHANISM ('81-'82 KLT200-A1
1981 KLT200-A1 KLT200 GEAR CHANGE MECHANISM ('83 KLT200-A4-A4A
1981 KLT200-A2 KLT200 GEAR CHANGE MECHANISM ('81-'82 KLT200-A1
1981 KLT200-A2 KLT200 GEAR CHANGE MECHANISM ('83 KLT200-A4-A4A
1982 KLT200-A3 KLT200 GEAR CHANGE MECHANISM ('81-'82 KLT200-A1
1982 KLT200-A3 KLT200 GEAR CHANGE MECHANISM ('83 KLT200-A4-A4A
1982 KLT250-A1 KLT250 GEAR CHANGE MECHANISM ('82 A1)
1983 KLT200-A4 KLT200 GEAR CHANGE MECHANISM ('81-'82 KLT200-A1
1983 KLT200-A4 KLT200 GEAR CHANGE MECHANISM ('83 KLT200-A4-A4A
1983 KLT200-A4A Duckster GEAR CHANGE MECHANISM ('81-'82 KLT200-A1
1983 KLT200-A4A Duckster GEAR CHANGE MECHANISM ('83 KLT200-A4-A4A
1983 KLT250-A2 KLT250 GEAR CHANGE MECHANISM ('82 A1)
2002 KVF650-A1 Prairie 650 4X4 OIL PUMP-OIL FILTER
2002 KVF650-B1 Prairie 650 4X4 Advantage Classic OIL PUMP-OIL FILTER
2003 KVF650-A2 Prairie 650 4X4 OIL PUMP-OIL FILTER
2003 KVF650-B2 Prairie 650 4X4 Advantage Classic OIL PUMP-OIL FILTER
2004 KSV700-A1 KFX700 V Force OIL PUMP-OIL FILTER
2004 KSV700-B1 KFX700 V Force OIL PUMP-OIL FILTER
2004 KVF700-A1 Prairie 700 4x4 OIL PUMP-OIL FILTER
2004 KVF700-B1 Prairie 700 4x4 Hardwoods Green HD OIL PUMP-OIL FILTER
2005 KSV700-A2 KFX700 OIL PUMP-OIL FILTER
2005 KSV700-B2 KFX700 OIL PUMP-OIL FILTER
2005 KVF650-D1 Brute Force 650 4x4 OIL PUMP-OIL FILTER
2005 KVF650-E1 Brute Force 650 4x4 OIL PUMP-OIL FILTER
2005 KVF700-A2 Prairie 700 4x4 OIL PUMP-OIL FILTER
2005 KVF700-B2 Prairie 700 4x4 Hardwoods Green HD OIL PUMP-OIL FILTER
2005 KVF700-D1 Prairie 700 4x4 Team Green Special Edition OIL PUMP-OIL FILTER
2005 KVF750-A1 Brute Force 750 4x4i OIL PUMP-OIL FILTER
2005 KVF750-B1 Brute Force 750 4x4i Hardwoods Green HD OIL PUMP-OIL FILTER
2006 KSV700A6F KFX700 OIL PUMP-OIL FILTER
2006 KSV700B6F KFX700 OIL PUMP-OIL FILTER
2006 KSV700C6F KFX700 OIL PUMP-OIL FILTER
2006 KVF650D6F Brute Force 650 4x4 OIL PUMP-OIL FILTER
2006 KVF650E6F Brute Force 650 4x4 Hardwoods Green HD OIL PUMP-OIL FILTER
2006 KVF650F6F Brute Force 650 4x4i OIL PUMP-OIL FILTER
2006 KVF650G6F Brute Force 650 4x4i Hardwoods Green HD OIL PUMP-OIL FILTER
2006 KVF700A6F Prairie 700 4x4 OIL PUMP-OIL FILTER
2006 KVF700D6F Prairie 700 4x4 Team Green Special Edition OIL PUMP-OIL FILTER
2006 KVF750A6F Brute Force 750 4x4i OIL PUMP-OIL FILTER
2006 KVF750B6F Brute Force 750 4x4i OIL PUMP-OIL FILTER
2006 KVF750C6F Brute Force 750 4x4i OIL PUMP-OIL FILTER
2007 KSV700A7F KFX700 OIL PUMP-OIL FILTER
2007 KSV700B7F KFX700 OIL PUMP-OIL FILTER
2007 KVF650D7F Brute Force 650 4x4 OIL PUMP-OIL FILTER
2007 KVF650E7F Brute Force 650 4x4 Hardwoods Green HD OIL PUMP-OIL FILTER
2007 KVF650F7F Brute Force 650 4x4i OIL PUMP-OIL FILTER
2007 KVF650G7F Brute Force 650 4x4i Hardwoods Green HD OIL PUMP-OIL FILTER
2007 KVF650H7F Brute Force 650 4x4i OIL PUMP-OIL FILTER
2007 KVF750A7F Brute Force 750 4x4i OIL PUMP-OIL FILTER
2007 KVF750B7F Brute Force 750 4x4i OIL PUMP-OIL FILTER
2007 KVF750B7FA Brute Force 750 4x4i OIL PUMP-OIL FILTER
2007 KVF750C7F Brute Force 750 4x4i OIL PUMP-OIL FILTER
2008 KRF750A8F Teryx 750 4X4 OIL PUMP-OIL FILTER
2008 KRF750B8F Teryx 750 4X4 OIL PUMP-OIL FILTER
2008 KRF750C8F Teryx 750 4X4 LE OIL PUMP-OIL FILTER
2008 KRF750D8F Teryx 750 4X4 LE OIL PUMP-OIL FILTER
2008 KRF750F8F Teryx 750 4X4 NRA Outdoors OIL PUMP-OIL FILTER
2008 KSV700A8F KFX700 OIL PUMP-OIL FILTER
2008 KSV700B8F KFX700 OIL PUMP-OIL FILTER
2008 KVF650D8F Brute Force 650 4x4 OIL PUMP-OIL FILTER
2008 KVF650E8F Brute Force 650 4x4 Hardwoods Green HD OIL PUMP-OIL FILTER
2008 KVF650F8F Brute Force 650 4x4i OIL PUMP-OIL FILTER
2008 KVF650G8F Brute Force 650 4x4i Hardwoods Green HD OIL PUMP-OIL FILTER
2008 KVF650H8F Brute Force 650 4x4i OIL PUMP-OIL FILTER
2008 KVF750D8F Brute Force 750 4x4i OIL PUMP-OIL FILTER
2008 KVF750E8F Brute Force 750 4x4i Hardwoods Green HD OIL PUMP-OIL FILTER
2008 KVF750E8FA Brute Force 750 4x4i NRA Outdoors OIL PUMP-OIL FILTER
2008 KVF750F8F Brute Force 750 4x4i OIL PUMP-OIL FILTER
2009 KRF750G9F Teryx 750 FI 4X4 OIL PUMP-OIL FILTER
2009 KRF750J9FA Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2009 KRF750K9F Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2009 KRF750L9F Teryx 750 FI 4X4 LE Sport OIL PUMP-OIL FILTER
2009 KRF750L9FA Teryx 750 FI 4X4 LE Sport Monster Energy OIL PUMP-OIL FILTER
2009 KRF750M9F Teryx 750 FI 4X4 NRA Outdoors OIL PUMP-OIL FILTER
2009 KSV700A9F KFX700 OIL PUMP-OIL FILTER
2009 KSV700B9F KFX700 OIL PUMP-OIL FILTER
2009 KVF650D9F Brute Force 650 4x4 OIL PUMP-OIL FILTER
2009 KVF650E9F Brute Force 650 4x4 Hardwoods Green HD OIL PUMP-OIL FILTER
2009 KVF650F9F Brute Force 650 4x4i OIL PUMP-OIL FILTER
2009 KVF650G9F Brute Force 650 4x4i Hardwoods Green HD OIL PUMP-OIL FILTER
2009 KVF750D9F Brute Force 750 4x4i OIL PUMP-OIL FILTER
2009 KVF750E9F Brute Force 750 4x4i Hardwoods Green HD OIL PUMP-OIL FILTER
2009 KVF750E9FA Brute Force 750 4x4i NRA Outdoors OIL PUMP-OIL FILTER
2010 KRF750NAF Teryx 750 FI 4X4 OIL PUMP-OIL FILTER
2010 KRF750PAF Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2010 KRF750RAF Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2010 KRF750SAF Teryx 750 FI 4X4 Sport OIL PUMP-OIL FILTER
2010 KRF750SAFA Teryx 750 FI 4X4 Sport OIL PUMP-OIL FILTER
2010 KRF750TAF Teryx 750 FI 4X4 (SGE) OIL PUMP-OIL FILTER
2010 KVF650DAF Brute Force 650 4x4 OIL PUMP-OIL FILTER
2010 KVF650FAF CANADA ONLY OIL PUMP-OIL FILTER
2010 KVF650GAF CANADA ONLY OIL PUMP-OIL FILTER
2010 KVF750DAF Brute Force 750 4x4i OIL PUMP-OIL FILTER
2010 KVF750EAF Brute Force 750 4x4i Realtree APG HD OIL PUMP-OIL FILTER
2010 KVF750FAF Brute Force 750 4x4i OIL PUMP-OIL FILTER
2011 KRF750NBF Teryx 750 FI 4X4 OIL PUMP-OIL FILTER
2011 KRF750PBF Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2011 KRF750RBF Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2011 KRF750SBF Teryx 750 FI 4X4 Sport OIL PUMP-OIL FILTER
2011 KRF750SBFA Teryx 750 FI 4X4 Sport OIL PUMP-OIL FILTER
2011 KRF750VBF Teryx 750 FI 4x4 LE (SGE) OIL PUMP-OIL FILTER
2011 KVF650DBF Brute Force 650 4x4 OIL PUMP-OIL FILTER
2011 KVF650FBF Brute Force 650 4x4i OIL PUMP-OIL FILTER
2011 KVF750DBF Brute Force 750 4x4i OIL PUMP-OIL FILTER
2011 KVF750FBF Brute Force 750 4x4i OIL PUMP-OIL FILTER
2012 KRF750NCS Teryx 750 FI 4X4 OIL PUMP-OIL FILTER
2012 KRF750PCS Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2012 KRF750RCS Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2012 KRF750SCS Teryx 750 FI 4X4 Sport OIL PUMP-OIL FILTER
2012 KRF750SCSA Teryx 750 FI 4X4 Sport OIL PUMP-OIL FILTER
2012 KRF750VCS Teryx 750 FI 4x4 LE (SGE) OIL PUMP-OIL FILTER
2012 KVF650DCF Brute Force 650 4x4 OIL PUMP-OIL FILTER
2012 KVF650DCS Brute Force 650 4x4 OIL PUMP-OIL FILTER
2012 KVF650FCF Brute Force 650 4x4i OIL PUMP-OIL FILTER
2012 KVF650FCS Brute Force 650 4x4i OIL PUMP-OIL FILTER
2012 KVF750GCF Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2012 KVF750GCS Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2012 KVF750HCF Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2012 KVF750HCS Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2012 KVF750JCF Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2012 KVF750JCS Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2012 KVF750LCF Brute Force 750 4x4i OIL PUMP-OIL FILTER
2012 KVF750LCS Brute Force 750 4x4i OIL PUMP-OIL FILTER
2013 KRF750NDF Teryx 750 FI 4X4 OIL PUMP-OIL FILTER
2013 KRF750PDF Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2013 KRF750RDF Teryx 750 FI 4X4 LE OIL PUMP-OIL FILTER
2013 KRF750SDF Teryx 750 FI 4X4 Sport OIL PUMP-OIL FILTER
2013 KVF650DDF Brute Force 650 4x4 OIL PUMP-OIL FILTER
2013 KVF650FDF Brute Force 650 4x4i OIL PUMP-OIL FILTER
2013 KVF750GDF Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2013 KVF750HDF Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2013 KVF750JDF Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2013 KVF750LDF Brute Force 750 4x4i OIL PUMP-OIL FILTER
2014 KVF750GEF Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2014 KVF750HEF Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2014 KVF750JEF Brute Force 750 4x4i EPS OIL PUMP-OIL FILTER
2014 KVF750LEF Brute Force 750 4x4i OIL PUMP-OIL FILTER
1969 H1 Mach III TRANSMISSION-CHANGE DRUM ('73-'77 D-E-F
1970 H1-A TRANSMISSION-CHANGE DRUM ('73-'77 D-E-F
1971 H1-B TRANSMISSION-CHANGE DRUM ('73-'77 D-E-F
1971 MT1 Mini-Trail TRANSMISSION-CHANGE DRUM ('71-'75)
1971 MT1 Mini-Trail TRANSMISSION-CHANGE DRUM ('76-'80)
1972 H1-C TRANSMISSION-CHANGE DRUM ('73-'77 D-E-F
1972 MT1A TRANSMISSION-CHANGE DRUM ('71-'75)
1972 MT1A TRANSMISSION-CHANGE DRUM ('76-'80)
1973 F11 TRANSMISSION-CHANGE DRUM ('73-'75 F11-F1
1973 F11M TRANSMISSION-CHANGE DRUM ('73 F11M)
1973 F11M TRANSMISSION-CHANGE DRUM ('73-'75 F11-F1
1973 H1-D TRANSMISSION-CHANGE DRUM ('73-'77 D-E-F
1974 F11-A TRANSMISSION-CHANGE DRUM ('73-'75 F11-F1
1974 H1-E TRANSMISSION-CHANGE DRUM ('73-'77 D-E-F
1974 KS125 TRANSMISSION-CHANGE DRUM ('74-'75)
1974 KS125 TRANSMISSION-CHANGE DRUM ('76-'79)
1974 KX125 TRANSMISSION-CHANGE DRUM
1974 KZ400 TRANSMISSION-CHANGE DRUM ('74 -'75
1974 KZ400 TRANSMISSION-CHANGE DRUM ('76 -'77
1974 MT1B TRANSMISSION-CHANGE DRUM ('71-'75)
1974 MT1B TRANSMISSION-CHANGE DRUM ('76-'80)
1975 F11-B TRANSMISSION-CHANGE DRUM ('73-'75 F11-F1
1975 H1-F TRANSMISSION-CHANGE DRUM ('73-'77 D-E-F
1975 KD125 TRANSMISSION-CHANGE DRUM
1975 KS125-A TRANSMISSION-CHANGE DRUM ('74-'75)
1975 KS125-A TRANSMISSION-CHANGE DRUM ('76-'79)
1975 KX125-A TRANSMISSION-CHANGE DRUM
1975 KZ400-D TRANSMISSION-CHANGE DRUM ('74 -'75
1975 KZ400-D TRANSMISSION-CHANGE DRUM ('76 -'77
1975 KZ400-S Special TRANSMISSION-CHANGE DRUM ('75 S)
1975 KZ400-S Special TRANSMISSION-CHARGE DRUM ('76-'77 S2-S3)
1975 MT1C TRANSMISSION-CHANGE DRUM ('71-'75)
1975 MT1C TRANSMISSION-CHANGE DRUM ('76-'80)
1976 KD125-A2 TRANSMISSION-CHANGE DRUM
1976 KE100-A5 KE100 GEAR CHANGE MECHANISM (KE100-A9-A10)
1976 KE125-A3 KE125 TRANSMISSION-CHANGE DRUM ('74-'75)
1976 KE125-A3 KE125 TRANSMISSION-CHANGE DRUM ('76-'79)
1976 KH500-A8 TRANSMISSION-CHANGE DRUM ('73-'77 D-E-F
1976 KM100-A1 GEAR CHANGE MECHANISM (KM100-A6-A7)
1976 KV75-A5 TRANSMISSION-CHANGE DRUM ('71-'75)
1976 KV75-A5 TRANSMISSION-CHANGE DRUM ('76-'80)
1976 KX125-A3 TRANSMISSION-CHANGE DRUM
1976 KZ400-D3 TRANSMISSION-CHANGE DRUM ('74 -'75
1976 KZ400-D3 TRANSMISSION-CHANGE DRUM ('76 -'77
1976 KZ400-S2 Special TRANSMISSION-CHANGE DRUM ('75 S)
1976 KZ400-S2 Special TRANSMISSION-CHARGE DRUM ('76-'77 S2-S3)
1976 KZ750-B1 TRANSMISSION (KZ750-B1-B2)
1976 KZ750-B1 TRANSMISSION (KZ750-B3-B4)
1977 KD125-A3 TRANSMISSION-CHANGE DRUM
1977 KE100-A6 KE100 GEAR CHANGE MECHANISM (KE100-A9-A10)
1977 KE125-A4 KE125 TRANSMISSION-CHANGE DRUM ('74-'75)
1977 KE125-A4 KE125 TRANSMISSION-CHANGE DRUM ('76-'79)
1977 KM100-A2 GEAR CHANGE MECHANISM (KM100-A6-A7)
1977 KV75-A6 TRANSMISSION-CHANGE DRUM ('71-'75)
1977 KV75-A6 TRANSMISSION-CHANGE DRUM ('76-'80)
1977 KZ400-A1 TRANSMISSION-CHANGE DRUM
1977 KZ400-D4 TRANSMISSION-CHANGE DRUM ('74 -'75
1977 KZ400-D4 TRANSMISSION-CHANGE DRUM ('76 -'77
1977 KZ400-S3 Special TRANSMISSION-CHANGE DRUM ('75 S)
1977 KZ400-S3 Special TRANSMISSION-CHARGE DRUM ('76-'77 S2-S3)
1977 KZ650-B1 GEAR CHANGE MECHANISM
1977 KZ750-B2 TRANSMISSION (KZ750-B1-B2)
1977 KZ750-B2 TRANSMISSION (KZ750-B3-B4)
1978 KD125-A4 TRANSMISSION-CHANGE DRUM
1978 KE100-A7 KE100 GEAR CHANGE MECHANISM (KE100-A9-A10)
1978 KE125-A5 KE125 TRANSMISSION-CHANGE DRUM ('74-'75)
1978 KE125-A5 KE125 TRANSMISSION-CHANGE DRUM ('76-'79)
1978 KL250-A1 KLR250 GEAR CHANGE MECHANISM ('78-'79 KL250-A1
1978 KL250-A1 KLR250 GEAR CHANGE MECHANISM ('80-'81 KL250-A3
1978 KL250-A1A KLR250 GEAR CHANGE MECHANISM ('78-'79 KL250-A1
1978 KL250-A1A KLR250 GEAR CHANGE MECHANISM ('80-'81 KL250-A3
1978 KM100-A3 GEAR CHANGE MECHANISM (KM100-A6-A7)
1978 KM100-A3A GEAR CHANGE MECHANISM (KM100-A6-A7)
1978 KV75-A7 TRANSMISSION-CHANGE DRUM ('71-'75)
1978 KV75-A7 TRANSMISSION-CHANGE DRUM ('76-'80)
1978 KX125-A4 TRANSMISSION-CHANGE DRUM
1978 KZ200-A1 GEAR CHANGE MECHANISM
1978 KZ200-A1A GEAR CHANGE MECHANISM
1978 KZ400-A2 TRANSMISSION-CHANGE DRUM
1978 KZ400-B1 GEAR CHANGE MECHANISM
1978 KZ400-C1 GEAR CHANGE MECHANISM
1978 KZ650-B2 GEAR CHANGE MECHANISM
1978 KZ650-B2A GEAR CHANGE MECHANISM
1978 KZ650-D1 SR GEAR CHANGE MECHANISM
1978 KZ650-D1A SR GEAR CHANGE MECHANISM
1978 KZ750-B3 TRANSMISSION (KZ750-B1-B2)
1978 KZ750-B3 TRANSMISSION (KZ750-B3-B4)
1979 KD125-A5 TRANSMISSION-CHANGE DRUM
1979 KE100-A8 KE100 GEAR CHANGE MECHANISM (KE100-A9-A10)
1979 KE125-A6 KE125 TRANSMISSION-CHANGE DRUM ('74-'75)
1979 KE125-A6 KE125 TRANSMISSION-CHANGE DRUM ('76-'79)
1979 KL250-A2 KLR250 GEAR CHANGE MECHANISM ('78-'79 KL250-A1
1979 KL250-A2 KLR250 GEAR CHANGE MECHANISM ('80-'81 KL250-A3
1979 KLX250-A1 KLX250 GEAR CHANGE MECHANISM
1979 KM100-A4 GEAR CHANGE MECHANISM (KM100-A6-A7)
1979 KV75-A8 TRANSMISSION-CHANGE DRUM ('71-'75)
1979 KV75-A8 TRANSMISSION-CHANGE DRUM ('76-'80)
1979 KX125-A5 TRANSMISSION-CHANGE DRUM
1979 KZ1300-A1 GEAR CHANGE MECHANISM
1979 KZ200-A2 GEAR CHANGE MECHANISM
1979 KZ400-B2 GEAR CHANGE MECHANISM
1979 KZ400-H1 GEAR CHANGE MECHANISM
1979 KZ650-B3 GEAR CHANGE MECHANISM
1979 KZ650-D2 SR GEAR CHANGE MECHANISM
1979 KZ750-B4 TRANSMISSION (KZ750-B1-B2)
1979 KZ750-B4 TRANSMISSION (KZ750-B3-B4)
1980 KD80-M1 KD80 GEAR CHANGE MECHANISM
1980 KE100-A9 KE100 GEAR CHANGE MECHANISM (KE100-A9-A10)
1980 KE125-A7 KE125 GEAR CHANGE MECHANISM ('80-'81 A7-A8)
1980 KE125-A7 KE125 GEAR CHANGE MECHANISM ('82-'83 A9-A10)
1980 KL250-A3 KLR250 GEAR CHANGE MECHANISM ('78-'79 KL250-A1
1980 KL250-A3 KLR250 GEAR CHANGE MECHANISM ('80-'81 KL250-A3
1980 KLX250-A2 KLX250 GEAR CHANGE MECHANISM
1980 KM100-A6 KM100 GEAR CHANGE MECHANISM (KM100-A6-A7)
1980 KV75-A9 KV75 TRANSMISSION-CHANGE DRUM ('71-'75)
1980 KV75-A9 KV75 TRANSMISSION-CHANGE DRUM ('76-'80)
1980 KZ1300-A2 GEAR CHANGE MECHANISM
1980 KZ250-D1 KZ250 GEAR CHANGE MECHANISM ('80 D1)
1980 KZ250-D1 KZ250 GEAR CHANGE MECHANISM ('81 D2)
1980 KZ440-A1 LTD GEAR CHANGE MECHANISM ('80 A1)
1980 KZ440-A1 LTD GEAR CHANGE MECHANISM ('81-'83 A2-A3-A4)
1980 KZ440-B1 GEAR CHANGE MECHANISM ('81 B2)
1980 KZ440-D1 LTD Belt GEAR CHANGE MECHANISM ('80 D1)
1980 KZ440-D1 LTD Belt GEAR CHANGE MECHANISM ('81-'83 D2-D3-D4
1980 KZ550-A1 GEAR CHANGE MECHANISM ('80-'81 A1-A2)
1980 KZ550-A1 GEAR CHANGE MECHANISM ('82-'83 A3-A4)
1980 KZ550-C1 LTD GEAR CHANGE MECHANISM ('80-'81 C1-C2)
1980 KZ550-C1 LTD GEAR CHANGE MECHANISM ('82-'83 C3-C4)
1980 KZ650-E1 LTD GEAR CHANGE MECHANISM
1980 KZ650-F1 GEAR CHANGE MECHANISM
1980 KZ750-E1 GEAR CHANGE MECHANISM ('80 KZY 50-E1)
1980 KZ750-E1 GEAR CHANGE MECHANISM ('81 -'82 KZ750-E2
1980 KZ750-G1 LTD II GEAR CHANGE MECHANISM
1980 KZ750-H1 LTD GEAR CHANGE MECHANISM ('80 H1)
1980 KZ750-H1 LTD GEAR CHANGE MECHANISM ('81-'83 H2-H3-H4)
1981 KD80-M2 KD80 GEAR CHANGE MECHANISM
1981 KE100-A10 KE100 GEAR CHANGE MECHANISM (KE100-A9-A10)
1981 KE125-A8 KE125 GEAR CHANGE MECHANISM ('80-'81 A7-A8)
1981 KE125-A8 KE125 GEAR CHANGE MECHANISM ('82-'83 A9-A10)
1981 KL250-A4 KLR250 GEAR CHANGE MECHANISM ('78-'79 KL250-A1
1981 KL250-A4 KLR250 GEAR CHANGE MECHANISM ('80-'81 KL250-A3
1981 KM100-A7 KM100 GEAR CHANGE MECHANISM (KM100-A6-A7)
1981 KZ1300-A3 GEAR CHANGE MECHANISM
1981 KZ250-D2 CSR GEAR CHANGE MECHANISM ('80 D1)
1981 KZ250-D2 CSR GEAR CHANGE MECHANISM ('81 D2)
1981 KZ440-A2 LTD GEAR CHANGE MECHANISM ('80 A1)
1981 KZ440-A2 LTD GEAR CHANGE MECHANISM ('81-'83 A2-A3-A4)
1981 KZ440-B2 GEAR CHANGE MECHANISM ('81 B2)
1981 KZ440-D2 LTD Belt GEAR CHANGE MECHANISM ('80 D1)
1981 KZ440-D2 LTD Belt GEAR CHANGE MECHANISM ('81-'83 D2-D3-D4
1981 KZ440-D3 LTD Belt GEAR CHANGE MECHANISM ('80 D1)
1981 KZ440-D3 LTD Belt GEAR CHANGE MECHANISM ('81-'83 D2-D3-D4
1981 KZ550-A2 GEAR CHANGE MECHANISM ('80-'81 A1-A2)
1981 KZ550-A2 GEAR CHANGE MECHANISM ('82-'83 A3-A4)
1981 KZ550-C2 LTD GEAR CHANGE MECHANISM ('80-'81 C1-C2)
1981 KZ550-C2 LTD GEAR CHANGE MECHANISM ('82-'83 C3-C4)
1981 KZ550-D1 GPz GEAR CHANGE MECHANISM
1981 KZ650-H1 CSR GEAR CHANGE MECHANISM ('81-'82 H1-H2)
1981 KZ650-H1 CSR GEAR CHANGE MECHANISM ('83 H3)
1981 KZ750-E2 GEAR CHANGE MECHANISM ('80 KZY 50-E1)
1981 KZ750-E2 GEAR CHANGE MECHANISM ('81 -'82 KZ750-E2
1981 KZ750-H2 LTD GEAR CHANGE MECHANISM ('80 H1)
1981 KZ750-H2 LTD GEAR CHANGE MECHANISM ('81-'83 H2-H3-H4)
1982 KD80-M3 KD80 GEAR CHANGE MECHANISM
1982 KE100-B1 KE100 GEAR CHANGE MECHANISM
1982 KE125-A9 KE125 GEAR CHANGE MECHANISM ('80-'81 A7-A8)
1982 KE125-A9 KE125 GEAR CHANGE MECHANISM ('82-'83 A9-A10)
1982 KL250-A5 KLR250 GEAR CHANGE MECHANISM
1982 KZ1300-A4 GEAR CHANGE MECHANISM
1982 KZ250-L1 CSR Belt GEAR CHANGE MECHANISM
1982 KZ440-A3 LTD GEAR CHANGE MECHANISM ('80 A1)
1982 KZ440-A3 LTD GEAR CHANGE MECHANISM ('81-'83 A2-A3-A4)
1982 KZ440-D4 LTD Belt GEAR CHANGE MECHANISM ('80 D1)
1982 KZ440-D4 LTD Belt GEAR CHANGE MECHANISM ('81-'83 D2-D3-D4
1982 KZ440-G1 GEAR CHANGE MECHANISM
1982 KZ550-A3 GEAR CHANGE MECHANISM ('80-'81 A1-A2)
1982 KZ550-A3 GEAR CHANGE MECHANISM ('82-'83 A3-A4)
1982 KZ550-C3 LTD GEAR CHANGE MECHANISM ('80-'81 C1-C2)
1982 KZ550-C3 LTD GEAR CHANGE MECHANISM ('82-'83 C3-C4)
1982 KZ550-H1 GPz GEAR CHANGE MECHANISM
1982 KZ650-H2 CSR GEAR CHANGE MECHANISM ('81-'82 H1-H2)
1982 KZ650-H2 CSR GEAR CHANGE MECHANISM ('83 H3)
1982 KZ750-E3 GEAR CHANGE MECHANISM ('80 KZY 50-E1)
1982 KZ750-E3 GEAR CHANGE MECHANISM ('81 -'82 KZ750-E2
1982 KZ750-H3 LTD GEAR CHANGE MECHANISM ('80 H1)
1982 KZ750-H3 LTD GEAR CHANGE MECHANISM ('81-'83 H2-H3-H4)
1982 KZ750-M1 CSR Twin GEAR CHANGE MECHANISM
1982 KZ750-N1 Spectre GEAR CHANGE MECHANISM
1982 KZ750-R1 GPz GEAR CHANGE MECHANISM
1983 KD80-M4 KD80 GEAR CHANGE MECHANISM
1983 KE100-B2 KE100 GEAR CHANGE MECHANISM
1983 KE125-A10 KE125 GEAR CHANGE MECHANISM ('80-'81 A7-A8)
1983 KE125-A10 KE125 GEAR CHANGE MECHANISM ('82-'83 A9-A10)
1983 KZ440-A4 LTD GEAR CHANGE MECHANISM ('80 A1)
1983 KZ440-A4 LTD GEAR CHANGE MECHANISM ('81-'83 A2-A3-A4)
1983 KZ440-D5 LTD Belt GEAR CHANGE MECHANISM ('80 D1)
1983 KZ440-D5 LTD Belt GEAR CHANGE MECHANISM ('81-'83 D2-D3-D4
1983 KZ550-A4 GEAR CHANGE MECHANISM ('80-'81 A1-A2)
1983 KZ550-A4 GEAR CHANGE MECHANISM ('82-'83 A3-A4)
1983 KZ550-C4 LTD GEAR CHANGE MECHANISM ('80-'81 C1-C2)
1983 KZ550-C4 LTD GEAR CHANGE MECHANISM ('82-'83 C3-C4)
1983 KZ550-F1 Spectre GEAR CHANGE MECHANISM
1983 KZ550-H2 GPz GEAR CHANGE MECHANISM
1983 KZ550-M1 LTD Shaft GEAR CHANGE MECHANISM
1983 KZ650-H3 CSR GEAR CHANGE MECHANISM ('81-'82 H1-H2)
1983 KZ650-H3 CSR GEAR CHANGE MECHANISM ('83 H3)
1983 KZ750-F1 LTD Shaft GEAR CHANGE MECHANISM
1983 KZ750-H4 LTD GEAR CHANGE MECHANISM ('80 H1)
1983 KZ750-H4 LTD GEAR CHANGE MECHANISM ('81-'83 H2-H3-H4)
1983 KZ750-K1 LTD Belt GEAR CHANGE MECHANISM
1983 KZ750-L3 GEAR CHANGE MECHANISM
1983 KZ750-N2 Spectre GEAR CHANGE MECHANISM
1983 ZN1300-A1 Voyager GEAR CHANGE MECHANISM
1983 ZX750-A1 GPz 750 GEAR CHANGE MECHANISM
1984 KD80-M5 KD80 GEAR CHANGE MECHANISM
1984 KE100-B3 KE100 GEAR CHANGE MECHANISM
1984 KZ550-F2 LTD Shaft GEAR CHANGE MECHANISM
1984 KZ700-A1 GEAR CHANGE MECHANISM
1984 KZ750-K2 CANADA ONLY GEAR CHANGE MECHANISM
1984 ZN1300-A2 Voyager GEAR CHANGE MECHANISM
1984 ZN700-A1 LTD Shaft GEAR CHANGE MECHANISM
1984 ZX550-A1 GPz GEAR.CHANGE MECHANISM
1984 ZX750-A2 GPz 750 GEAR CHANGE MECHANISM
1984 ZX750-E1 GPz 750 Turbo GEAR CHANGE MECHANISM
1985 KD80-M6 KD80 GEAR CHANGE MECHANISM
1985 KE100-B4 CANADA ONLY GEAR CHANGE MECHANISM
1985 ZN1300-A3 Voyager GEAR CHANGE MECHANISM
1985 ZN700-A2 LTD Shaft GEAR CHANGE MECHANISM
1985 ZX550-A2 GPz GEAR.CHANGE MECHANISM
1985 ZX600-A1 Ninja 600 CRANKSHAFT
1985 ZX600-A1 Ninja 600 GEAR CHANGE MECHANISM
1985 ZX750-A3 GPz 750 GEAR CHANGE MECHANISM
1985 ZX750-E2 GPz 750 Turbo GEAR CHANGE MECHANISM
1986 EX250-E1 Ninja 250R GEAR CHANGE DRUM & FORKS
1986 KD80-M7 KD80 GEAR CHANGE MECHANISM
1986 KE100-B5 KE100 GEAR CHANGE MECHANISM
1986 ZL600-A1 ZL600 Eliminator CRANKSHAFT
1986 ZL600-A1 ZL600 Eliminator GEAR CHANGE MECHANISM
1986 ZN1300-A4 Voyager GEAR CHANGE MECHANISM
1986 ZX550-A3 GPz GEAR.CHANGE MECHANISM
1986 ZX600-A2 Ninja 600 CRANKSHAFT
1986 ZX600-A2 Ninja 600 GEAR CHANGE MECHANISM
1987 EX250-E2 Ninja 250R GEAR CHANGE DRUM & FORKS
1987 KD80-M8 KD80 GEAR CHANGE MECHANISM
1987 KE100-B6 KE100 GEAR CHANGE MECHANISM
1987 ZL600-A2 ZL600 Eliminator CRANKSHAFT
1987 ZL600-A2 ZL600 Eliminator GEAR CHANGE MECHANISM
1987 ZN1300-A5 Voyager GEAR CHANGE MECHANISM
1987 ZX600-A3 Ninja 600 CRANKSHAFT
1987 ZX600-A3 Ninja 600 GEAR CHANGE MECHANISM
1987 ZX600-B1 Ninja 600RX CRANKSHAFT
1987 ZX600-B1 Ninja 600RX GEAR CHANGE MECHANISM
1988 EL250-B2 Eliminator GEAR CHANGE DRUM-SHIFT FORK(S)
1988 EX250-F2 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1988 KE100-B7 KE100 GEAR CHANGE MECHANISM
1988 ZN1300-A6 Voyager GEAR CHANGE MECHANISM
1988 ZX600-C1 Ninja 600R CRANKSHAFT
1988 ZX600-C1 Ninja 600R GEAR CHANGE MECHANISM
1989 EL250-B3 Eliminator GEAR CHANGE DRUM-SHIFT FORK(S)
1989 EX250-F3 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1989 KE100-B8 KE100 GEAR CHANGE MECHANISM
1989 ZX600-C2 Ninja 600R CRANKSHAFT
1989 ZX600-C2 Ninja 600R GEAR CHANGE MECHANISM
1990 EX250-F4 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1990 KE100-B9 KE100 GEAR CHANGE MECHANISM
1990 ZR550-B1 Zephyr GEAR CHANGE MECHANISM
1990 ZX600-C3 Ninja 600R CRANKSHAFT
1990 ZX600-C3 Ninja 600R GEAR CHANGE MECHANISM
1991 KE100-B10 KE100 GEAR CHANGE MECHANISM
1991 ZR550-B2 Zephyr GEAR CHANGE MECHANISM
1991 ZX600-C4 Ninja 600R CRANKSHAFT
1991 ZX600-C4 Ninja 600R GEAR CHANGE MECHANISM
1992 KE100-B11 KE100 GEAR CHANGE MECHANISM
1992 ZR550-B3 Zephyr GEAR CHANGE MECHANISM
1992 ZX600-C5 Ninja 600R CRANKSHAFT
1992 ZX600-C5 Ninja 600R GEAR CHANGE MECHANISM
1993 KE100-B12 KE100 GEAR CHANGE MECHANISM
1993 ZR550-B4 Zephyr GEAR CHANGE MECHANISM
1993 ZX600-C6 Ninja 600R CRANKSHAFT
1993 ZX600-C6 Ninja 600R GEAR CHANGE MECHANISM
1994 KE100-B13 KE100 GEAR CHANGE MECHANISM
1994 ZX600-C7 Ninja 600R CRANKSHAFT
1994 ZX600-C7 Ninja 600R GEAR CHANGE MECHANISM
1995 KE100-B14 KE100 GEAR CHANGE MECHANISM
1995 ZX600-C8 Ninja 600R CRANKSHAFT
1995 ZX600-C8 Ninja 600R GEAR CHANGE MECHANISM
1996 KE100-B15 KE100 GEAR CHANGE MECHANISM
1996 ZL600-B2 Eliminator 600 CRANKSHAFT
1996 ZL600-B2 Eliminator 600 GEAR CHANGE MECHANISM
1996 ZX600-C9 Ninja 600R CRANKSHAFT
1996 ZX600-C9 Ninja 600R GEAR CHANGE MECHANISM
1997 KE100-B16 KE100 GEAR CHANGE MECHANISM
1997 ZL600-B3 Eliminator 600 CRANKSHAFT
1997 ZL600-B3 Eliminator 600 GEAR CHANGE MECHANISM
1997 ZX600-C10 Ninja 600R CRANKSHAFT
1997 ZX600-C10 Ninja 600R GEAR CHANGE MECHANISM
1998 KE100-B17 KE100 GEAR CHANGE MECHANISM
1999 KE100-B18 KE100 GEAR CHANGE MECHANISM
2000 KE100-B19 KE100 GEAR CHANGE MECHANISM
2000 KH125-M5 GEAR CHANGE MECHANISM
2001 KE100-B20 KE100 GEAR CHANGE MECHANISM
2003 KH125-M8 GEAR CHANGE MECHANISM
2004 KH125-M9 GEAR CHANGE MECHANISM
Funny thing is you can see it was used on the earlier model Ninjette, along with other bigger models.
But if you look up the same spring, but for older model Ninjette, you don't see the large crossover
Overview
92144-1580 SPRING
Description
Purchase this Kawasaki 92144-1580 SPRING --- SPRING,NEUTRAL POSITION
This Kawasaki 92144-1580 SPRING is used on these models and components:
1991 EL250-E1 Eliminator 250 GEAR CHANGE DRUM-SHIFT FORK(S)
1991 ZR750-C1 Zephyr 750 GEAR CHANGE MECHANISM
1992 EL250-E2 Eliminator 250 GEAR CHANGE DRUM-SHIFT FORK(S)
1992 EX250-F6 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1992 ZR750-C2 Zephyr 750 GEAR CHANGE MECHANISM
1993 EL250-E3 Eliminator 250 GEAR CHANGE DRUM-SHIFT FORK(S)
1993 EX250-F7 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1993 ZR750-C3 Zephyr 750 GEAR CHANGE MECHANISM
1994 EL250-E4 Eliminator 250 GEAR CHANGE DRUM-SHIFT FORK(S)
1994 EX250-F8 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1995 EX250-F9 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1996 EX250-F10 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1997 EX250-F11 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1998 EX250-F12 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
1999 EX250-F13 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2000 EX250-F14 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2000 ZR750-F2 ZR-7 GEAR CHANGE MECHANISM
2001 EX250-F15 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2001 ZR750-H1 ZR-7S GEAR CHANGE MECHANISM
2002 EX250-F16 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2002 ZR750-H2 ZR-7S GEAR CHANGE MECHANISM
2003 EX250-F17 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2003 ZR750-H3 ZR-7S GEAR CHANGE MECHANISM
2004 EX250-F18 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2004 ZR750-H4 CANADA ONLY GEAR CHANGE MECHANISM
2005 EX250-F19 Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2005 ZR750-H5 CANADA ONLY GEAR CHANGE MECHANISM
2006 EX250F6F Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2007 EX250F7F Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2008 EX250J8F Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2009 EX250J9F Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2009 EX250J9FA Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2010 EX250JAF Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2010 EX250JAFA Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2011 EX250JBF Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2011 EX250JBFA Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2012 EX250JCF Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
2012 EX250JCFA Ninja 250R GEAR CHANGE DRUM-SHIFT FORK(S)
So I find this interesting to say the least.
ZX-2R BLOG
Old August 5th, 2015, 09:13 PM   #11
Ghostt
Ghostt's Avatar
From the Factory Pro website
F-Pro
Blue Shift Spring
Guys be like "When you gonna make a 250 Shift Spring?"
Find Neutral easier - (ok, n is pretty easy to find on a Kaw :-)
Improve lazy shifting.
virtually eliminate missed shifts.
virtually eliminate false neutrals.
help prevent gearbox damage caused by missed shifts.
Countless hours of thought went into this spring's specs.
"The Blue Magic spring
ZX-2R BLOG
Old August 5th, 2015, 11:59 PM   #12
corksil
Motorcycle(s): A lot.
Snake oil and "mechanic in a bottle" if you ask me.
I bought into the hype and figured I had to have one. After looking around, I found a forum member who sold me a used one for a few bucks to cover shipping. He mentioned not much a feel difference on his track 250r... said it was about the difference in feel between having a chain properly tensioned (feeling of blue spring) and having a chain with too much slop.
I paid him and he shipped the spring, and then we had a few back and forth PM about the feel of the spring at which point I lost my enthusiasm to install it due to his words.
Regardless, I still have this magic blue spring and I've never installed it as the bike has been down for installation of race cams, valve lash adjust, and several other overhaul type procedures.
If anyone needs any measurements, I have a full wealth of machinist tools in my possession and this spring is sitting in storage on the bench right next to my tapered roller steering stem bearings and other "this part will make the bike defy gravity" type things which I haven't had the time to install.
Let me know what you want to know.
Reason I cooperate is that I called the company and pretended to be an idiot, asked a few questions about variable valve timing advance and other preschool engine hot-rodding techniques regarding their products and was thoroughly dissatisfied with the knowledge of the salesman.
His pitch was "you won't understand this, and don't try, but send us money!"
I can't blame him, we are all trying to turn a profit.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy.
Old August 6th, 2015, 12:19 AM   #13
Ghostt
Ghostt's Avatar
If it's possible, could you measure both springs? I'm curious if there is a difference between the wire diameters, and number of coils.
ZX-2R BLOG
Old August 6th, 2015, 06:26 AM   #14
sharky nrk
sharky nrk's Avatar
So the "theory" behind this is somewhat logical. What you have with the shift spring, is the mechanism that holds a "follower pin" against the recesses of the shift star attached to the shift drum.
When you depress the shift lever and it turns the shift star/drum - the star pushes up against the "follower pin", compresses the spring at the height of the star point, and then follows the profile of the shift star.
The stiff spring provides a greater force against the "follower pin" as it rides along the shift star profile, which may allow for more positive feel of engagement and the additional force keep the pin against the profile of the star with less "slop".
The spring and pin's actual purpose is to provide the "hold" for the shift drum in neutral. As neutral on the star has a little valley at the peak of the "star point" between gears. A worn out/weak/whatever spring/pin/star makes neutral pretty difficult to find fyi.
Old August 6th, 2015, 07:44 AM   #15
Ralgha
Ralgha's Avatar
It was significantly stiffer than stock, it took noticeably more force to shift. It also does feel very positive when engaging the new gear. It's not completely snake oil as there is a definite change, whether the change is "better" or not, I'm not sure. It's not worse though.
Old August 6th, 2015, 03:23 PM   #16
Ghostt
Ghostt's Avatar
Okay so I just pulled the trigger on a used one on eBay for cheap, even got the whole assembly
neutral position bolt and pin, spring
off running 78 KZ400 with 20,000 miles
good used condition- no issues
P/N 92001-1037 (bolt)
P/N 92043-076 (pin)
P/N 92081-112 (spring)
All the part numbers are identical to the Ninjette, with the exception of the spring itself.
It's used, hopefully not too much, so now I wait til it arrives to find out if this is a cheaper alternative to the Blue Spring.
If there's a difference, I will then move on to ordering a new one, just in case the used one is too used, and might have lost its spring so to speak of.
My theory is Kawasaki switched to a lighter spring, same as they did with the clutch springs themselves, to make it easier to shift for beginners.
File Type: jpg $T2eC16NHJF4FFkt8RW8JBSQyhQd!nQ--60_1.JPG (33.4 KB, 100 views)
ZX-2R BLOG
Old August 7th, 2015, 06:42 AM   #17
sharky nrk
sharky nrk's Avatar
^^^ awesome let us know!!!!!
Old August 7th, 2015, 11:37 AM   #18
Ghostt
Ghostt's Avatar
Most definitely, I'm curious myself to know, it's better to spend $3 than $30 for a spring.
ZX-2R BLOG
Old August 7th, 2015, 05:40 PM   #19
MAZ 80
MAZ 80's Avatar
Motorcycle(s): 07 Ninja 01 Sportster
$30 is a lot for a pretty blue paint job. If you have the means to measure distance and force simultaneously, it's not difficult to determine the rate. Once you have the rate and size you want, start looking at McMaster Carr and work your way to Century and the other big spring manufacturers. Somebody out there probably has what you are looking for off the shelf. You may have to buy 10 or 20 or them. Sounds like a group buy.
https://www.ninjette.org/forums/showthread.php?t=238279
I'd be happy to do the measuring if you don't have the stuff.
Sounds like you have a lot of measuring stuff, I'd be happy to fill you in on the details of the procedure if you need it.
MAZ 80 is offline   Reply With Quote
Old August 10th, 2015, 10:01 AM   #20
Ghostt
Ghostt's Avatar
Okay parts arrived today, so I tore into the usps priority mail box like I kid on Christmas morning.
Upon visual inspection between the springs, the newer one is a bit longer, the wire gauge is also a little thicker. Next was the pinch test, and the newer one is also a little bit stiffer, took more effort to compress.
Unfortunately no ride report due the rain, but I did install it, and I did notice a difference between the two just going for neutral to first.
Stay tuned for a ride report, and more information, measurements will have to wait til my new digital caliper arrives.
@corksil if you could take some measurements of the Blue Magic Spring, that would be appreciated.
Til then here's a picture, you can see the physical differences to see for yourself. OEM Ninjette on the left, part # 92081-1112 on the right.
ZX-2R BLOG
Old August 10th, 2015, 03:57 PM   #21
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
Were you experiencing false neutrals, or the bike popping out of gear?
GregS is offline   Reply With Quote
Old August 10th, 2015, 03:59 PM   #22
Ghostt
Ghostt's Avatar
Popped out a couple of times under hard acceleration, but I blame my left foot for being too easy.
ZX-2R BLOG
Old August 10th, 2015, 05:17 PM   #23
GregS
From what I've heard, the blue spring works wonders. I used their kit on my 300 and it made a world of difference.
Old August 10th, 2015, 06:20 PM   #24
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
Stock spring is weak and becomes compressed and your shifts at times become a false neutral, or once in a great while will pop out of gear on you as the spring didn't allow it to seat properly in the groove from the lack of pressure.
I have had to pull mine out and stretch it back out and can tell the difference immediately.
I keep wanting to get one but always seem to forget to pull the trigger on buying it.
Old August 10th, 2015, 07:39 PM   #25
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Good information @Ghostt, looking forward to your ride report.
By the way when I look to the website about the 'Blue Magic Shift Spring' the shipping price makes me thinking twice...
From Germany the shipping for items like this is app. 7.50 USD.
Old August 10th, 2015, 07:41 PM   #26
Ghostt
Ghostt's Avatar
Yeah shipping cost @ $14.00 USD for a little spring is absolutely ridiculous IMHO
Hopefully this may be a cheaper alternative to the Blue Magic Spring. Ordering one new from partzilla is still under $10.00.
ZX-2R BLOG
Old August 11th, 2015, 06:14 AM   #27
sharky nrk
sharky nrk's Avatar
i hope it works out well, your absolutely right that the cost of the factory pro spring and shipping is crazy - I think we still could get someone to measure one up for us and then we could pick springs in a range to suit rider preference
Old August 11th, 2015, 08:50 AM   #28
sharky nrk
sharky nrk's Avatar
oops double post
Old August 11th, 2015, 09:14 AM   #29
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Get me the measurements of ether spring and I'll start looking at my parts suppliers for options. At a quick glance the tempered steel(made to resist heat) are about $2.50 each, some are sold individual and others in packs of 6-12. Just because someone out there found a spring that'll fit into 500 different bike doesn't mean it the perfect one for every bike. If someone feeds me a little info then I'll probably order several options and give them all a try.
I need the total uncompressed length, #of coils, wire thickness, ID and OD. Measurements can be in MM or Inch, I convert the values on my end.
By the way what's involved in changing the spring? Is it a 10 min job or something more involved?
Old August 11th, 2015, 10:13 AM   #30
bruce71198
bruce71198's Avatar
I run these in my race bikes to prevent the back shifting from 6th to 5th. They seem to have reduced this phenomenon by about 90%. After you get used to the initial stiffness and added effort to shift you really don't notice it. Clunks a little bit more when shifting from neutral to 1st gear. All in all I would say this product does what it was designed for. You have to be the judge if its to pricey for your wallet.
Old August 11th, 2015, 12:01 PM   #31
Ghostt
Ghostt's Avatar
Waiting on my new digital caliper to arrive.
And changing the spring is about a 2 minute job.
ZX-2R BLOG
Old August 11th, 2015, 11:51 PM   #32
spring rate, preloaded spring, effective spring length... what gives, you might ask ("the spring does!" -- shouted from the audience)
what is the difference? look at the end result. two numbers. force at full deflection. force at minimum deflection.
suppose you have a stock spring rate of 10n at 1mm deflection, and 100n at 10mm deflection. the spring is 10n/mm spring rate right?
suppose you swap to a fancy 12n/mm spring... at 1mm deflection, its 12n. at 10mm deflection, 120n.
suppose you have your 10n/mm spring preloaded by 2 mm. now at 1mm deflection, its actually 30n. and at 2 mm deflection, its 40n. at 10mm deflection, its 120n.
what would the difference be in feel? thats the real quantifier, right? how it feels? ("ungh! feels so good!!")
with the preloaded spring, the initial movement will be stiffer, but then ease into the same end-throw stiffness. with the higher spring rate, it would be easier at the beginning, but then get to the same stiffness at the end.
so which is better for your gear shifts? i would think the one that is stiffer at the beginning would be better. hell, i would probably pick a preloaded spring that is a LOWER spring rate than stock if anything.
good luck, have fries.
Old August 12th, 2015, 06:03 AM   #33
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I love the way you think and that something I'll consider when I'm picking out various springs from the catalog. I took a quick glance at how the sting is used and held in the motor and was thinking some preload washers could be used to tune the different springs and find a preferred setup with only a few different ones purchased.
Old August 12th, 2015, 06:05 AM   #34
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
If simply pull my spring out at the shop while I'm here but I've been commuting via bicycle lately and don't have my ninja handy. Eventually I'll remember to pull it out and measure it if someone on here doesn't beat me to it.
Old August 12th, 2015, 06:26 AM   #35
sharky nrk
sharky nrk's Avatar
yeah, good points - a curious note would be of course how much is the spring preloaded in resting state (if at all) and how much is maximum compression from the height of the shift star?
Old August 12th, 2015, 01:52 PM   #36
bruce71198
bruce71198's Avatar
But the 12n/mm spring is much longer, so the preload is going to be greater.
Old August 12th, 2015, 02:10 PM   #37
length and spring rate are not related. and 12n/mm is a hypothetical spring. you probably mean the blue magic spring is longer. but since we dont know the spring rate, for all we know it could be the same rate as stock but slightly longer to force preload without a washer
Old August 12th, 2015, 03:04 PM   #38
bruce71198
bruce71198's Avatar
Isn't there a way to calculate spring rate knowing the coil diameter, wire thickness and number of coils?
Old August 12th, 2015, 04:41 PM   #39
you also need to know what type of steel it is.
Old August 12th, 2015, 04:50 PM   #40
Skullz
Skullz's Avatar
Spring steel O_o
Factory Pro Detent Arm Shift Kit Surferboy120 2013 - 2017 Ninja 300 Tech Talk 62 February 13th, 2019 07:41 PM
FactoryPro Shift Spring -- anyone used? abhijitz Ninjettes At Speed 2 May 15th, 2014 05:35 PM
[kropotkin thinks...] - Honda's Magic Gearbox: Worth A Few Hundredths A Shift Ninjette Newsbot Motorcycling News 0 March 19th, 2011 05:01 AM
blue magic blue magic New Members 12 June 14th, 2010 11:50 AM
