Old March 26th, 2017, 07:31 PM   #1
MauR
MauR's Avatar
Motorcycle(s): 250R
Koso RX2 Mounting Plate
I decided to make my own mounting plate for my Koso RX2... Attached is the scanned image in case someone decide to try it. I'm sure this can be improved.
Just print at 100%
It is made from 2.4mm acrylic and will be covered with adhesive vinyl
I'll try to post some pictures when it is mounted. I'm waiting form the connectors from cycleterminal.com to make it plug and play.
Hope this helps someone.
MauR is offline   Reply With Quote
Old April 12th, 2021, 03:54 PM   #2
Holy_Rider
Motorcycle(s): 2012 Kawasaki Ninja 250r
Any chance you can link what you got to make it plug and play. I talked to a guy in the uk, apparently he found a mount and plug and play kit but has yet to get back to me... so I think I'm going to have to figure this one out on my own. Appreciate your help man.
Holy_Rider is offline   Reply With Quote
Old April 12th, 2021, 08:21 PM   #3
MauR
MauR's Avatar
Motorcycle(s): 250R
Hello!!
If a recall correctly you need one 9Pin Connector and one 2Pin Conector. Don't remember if male or female connectors but they are cheap so maybe you could buy both of them.
Here is the link http://www.cycleterminal.com/110-connectors.html
And a picture of the connector in my bike. I used a cutted harness because the connectors were lost in the mail. By this picture it looks like the connectors were MALE.
Also a picture of the speed sensor mounted in the wheel.
My RX2 had 2 temp sensors and one speed sensor... so with the mounting plate it was all done... I recommend using carbon fiber for the plate. Acrylic didn't last
Sorry I don't have more pictures of the process
Hope this helps
Old April 14th, 2021, 05:00 PM   #4
Holy_Rider
Hey man, just wondering if you got the fuel gauge to work properly. I've seen a lot of people had issues with this. Any chance you know what the correct settings are for the ohms?
Old April 15th, 2021, 08:23 AM   #5
MauR
MauR's Avatar
Motorcycle(s): 250R
It works great and I used the 100ohm Setting
Old April 16th, 2021, 05:01 AM   #6
Holy_Rider
Any chance you can check the settings you used from A1 to A10 just so I can make im using the proper setting strategies work for the ninja 250 08-12. Thank you so much for your help man.
Old April 19th, 2021, 12:44 PM   #7
MauR
MauR's Avatar
Motorcycle(s): 250R
Sure!!
I am using the following settings:
1. Km/h (regional Preference)
2. 4C Cycles and 2P Pistons Hi-Act
3. `C (regional preference)
4. 100Km/h Speed Warning
5. 10,000 rpm warning
6. Over Heating Water 110`C, Oil 120`C
7. Cincumference 1845mm and 3P (I'm using only 3 magnets)
8. 24Hr Clock
9. 100 Ohm hesitance and 20% remaining warning
10. i did not setup the power test.
Koso Rx1 or Rx2 gauge contents and extras? Daakuryu 2008 - 2012 Ninja 250R Farkles 12 April 12th, 2021 12:13 PM
KOSO RX2 MauR 2008 - 2012 Ninja 250R Tech Talk 14 August 23rd, 2017 06:44 PM
Koso RX2 Gauge with voltmeter? Boomstick 2008 - 2012 Ninja 250R Farkles 32 June 12th, 2017 08:50 AM
koso rx2 09 ninja 250 karter 2008 - 2012 Ninja 250R Tech Talk 22 December 13th, 2015 09:03 AM
Turn signal mounting plate replacing...HELP rph12 1986 - 2007 Ninja 250R Tech Talk 5 March 8th, 2012 09:48 PM
