January 17th, 2018, 11:13 AM | #1 |
Engine gaskets
Dose anyone have a link for gasket outlines? I could have sworn at one point in time I saw a link for it but cant find it now.
January 17th, 2018, 11:28 AM | #2 |
Which gaskets?
January 17th, 2018, 12:09 PM | #3 |
case covers and the oil strainer. I can buy them and make outlines, but i was just trying to be cheap
January 17th, 2018, 12:11 PM | #4 |
When I want to make a gasket, I lay the material on the part and tap around it with a soft hammer gently. It leaves a print I can follow to cut it out. But maybe you already know that technique.
January 17th, 2018, 03:27 PM | #5 |
I was going to use grease/or ink to do that but. I like your idea better. thank you.
January 17th, 2018, 03:50 PM | #6 |
You're welcome. It's the way my father taught me to do it when I was about eight or ten (late 60s) and he got a discarded lawnmower engine so we could take it apart and put it back together. Welcome to the board by the way, Cody.
January 17th, 2018, 04:06 PM | #7 |
Thank you Hoping to get thing together for a track day this summer.
January 17th, 2018, 04:53 PM | #8 |
I just lay cover over gasket-material and trace outside with sharp Xacto knife. One-pass and it's 1/2-done.
Then I carefully do inside-cut while maintaining constant width. 2nd-pass and it's done. Nice clean edges that doesn't protrude past edge of cases like a gang of beavers gnawed at it. I've also tried computer-controlled vinyl-cutter, but that took longer to draw shape correctly than to just carve by hand. Also considered laser-engraver, but again, takes a while to draw exact shape of gasket to guide laser. Faster to wield Xacto knife! |
January 17th, 2018, 06:34 PM | #9 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
Bill
Insanity: doing the same thing over and over again expecting different results each time. |
January 18th, 2018, 11:24 AM | #10 |
You sir are my hero. I would have never thought about that.
January 18th, 2018, 11:33 AM | #11 |
January 18th, 2018, 12:58 PM | #12 |
Sure. I would advise placing a piece of clothing or cloth over the object you're copying to block as much extraneous light from hitting the platen (spelled right this time) glass. If you can, turn off all the lights in the room also. Bill
February 6th, 2018, 12:39 PM | #13 |
Did the copy trick yesterday, and it worked great. Thanks again for the help.
what gaskets to change during engine tear down? | ebrammer252 | 1986 - 2007 Ninja 250R Tech Talk | 19 | May 22nd, 2014 04:07 AM |
Gaskets | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 10 | November 6th, 2013 06:27 AM |
Make your own gaskets | cuong-nutz | General Motorcycling Discussion | 4 | October 11th, 2013 03:09 PM |
Petcock gaskets? | MasterCylinder | 1986 - 2007 Ninja 250R Tech Talk | 15 | September 12th, 2013 06:02 AM |
Engine-to-Header gaskets (NewGen) | USMCEvan | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 18th, 2012 09:45 PM |
