Old February 11th, 2018, 01:57 PM   #1
Joppedo
Joppedo's Avatar
Motorcycle(s): 2012 Ninja 250
Changing bike around for different riding style.
Dont know how many people change their bike around for the style of riding but this old timer does. Been three months now from the big move from Arizona to Florida. No more mountain knee dragging curves. First off sitting in traffic three lights to get through and we all know these bikes hate it. First to go was the 97c fan switch. The 18mm bolt gsxr fan switch rated at 85c fits straight across. Keep those temps down. 5 year old bike now so new silicone hoses in pretty blue. antifreeze was my coolant since i was in the mountains and temps would reach in the low single digits, water wetter is now a must for me. second no more diablo rosso 2 tires. i needs tread for the rain. brake, clutch and rear sets needs moving and adjusted for faster response not comfort. Im not worried about my riding skill, im worried about others driving skills so off came the stock mirrors and new blinker indicator ones are now on so i can be seen more. I have a few more ive done and when i think of them ill come back here. Keep riding safe everyone. And Remember if your working on your own bike do it the right way never take short cuts. In the photo you will see solder join in the oem blinker to a weather proof two plug to still be able to remove the fairing.
Last futzed with by Joppedo; February 11th, 2018 at 04:22 PM.
Joppedo is offline   Reply With Quote
Old February 11th, 2018, 03:28 PM   #2
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
well done. maybe a headlight modulator? it's saved my life many times over. i use kisan's
https://kisantech.com/
"trying not to get old"
Old February 11th, 2018, 04:19 PM   #3
Joppedo
Joppedo's Avatar
Not a bad idea, That didn't cross my mind. Thanks for that. Since you brought it up ill also look into a rear brake light flasher. Harley uses them a lot. Ill have to see if DOT allows them or if this state will let me get away with it. After all it tells you in the motorcycle manual to pump your brake a couple of times to get the person behind you attention.
Old February 11th, 2018, 07:04 PM   #4
IIRC, federal law says brake light flashers generally are okay so long as they're not continuously flashing the brake light.
Definitely double check me though, I'm hazy on that.
Old February 11th, 2018, 11:47 PM   #5
maverick9611
MOTM - Feb '18
ebay has em for $10. i’ll look it up
Old February 11th, 2018, 11:50 PM   #6
maverick9611
MOTM - Feb '18
Old February 12th, 2018, 04:26 AM   #7
Joppedo
Joppedo's Avatar
ITs on its way. I can do on the cheap if it works. I saw a couple that are programmable for the amount of flashing you want. alot more pricey, So modulator and flasher on the way.. SO they make small led marker lights for the sides. I use the license plate ones on the side and so far get away with it. Wouldnt marker lights be better?
Old February 12th, 2018, 05:21 AM   #8
maverick9611
MOTM - Feb '18
check out hyperlites
Old February 13th, 2018, 04:28 AM   #9
maverick9611
MOTM - Feb '18
https://kisantech.com/mag/pathblazer.html
it
Old February 13th, 2018, 04:55 AM   #10
maverick9611
MOTM - Feb '18
do you have a part # for the Suzuki fan switch probe?
Old February 13th, 2018, 06:02 PM   #11
Joppedo
Joppedo's Avatar
Sorry for the delay this is the item you can grab from ebay. The guys has a 90 day warranty also. Motorcycle Radiator Fan Thermo Switch 18mm Bolt for Suzuki GSXR600 GSXR750/750X. Direct fit.
Old February 13th, 2018, 06:06 PM   #12
Joppedo
Joppedo's Avatar
Hey mav is that light above say 115 watts.?
Old February 13th, 2018, 10:35 PM   #13
maverick9611
MOTM - Feb '18
on kisans site they a bulb selection menu depending on which type your using
Old February 13th, 2018, 10:40 PM   #14
maverick9611
MOTM - Feb '18
max power is 115 watts, stock bulb 55 watts
Changing handlebars to dirt bike style? A.J. General Motorcycling Discussion 4 August 1st, 2018 06:49 PM
[motogp.com] - Lorenzo: "I still don’t have the riding style for the bike" Ninjette Newsbot Motorcycling News 0 June 5th, 2017 01:16 AM
[roadracingworld.com] - World Superbike: Tom Sykes Says He Is Changing His Riding Sty Ninjette Newsbot Motorcycling News 0 March 30th, 2017 12:50 PM
[sportrider - latest stories] - MotoGP Qatar: Colin Edwards changing riding style Ninjette Newsbot Motorcycling News 0 March 23rd, 2014 03:00 PM
Changing gear shifter to GP style? kimmiegrews 2008 - 2012 Ninja 250R Tech Talk 6 June 17th, 2009 11:50 AM
