Old March 8th, 2018, 04:27 PM   #1
agnt_kruger
agnt_kruger's Avatar
Motorcycle(s): 11'Ninja 250r, 06 Ninja250r(Sold), 01'GSX-R750(Sold), 07'GSX-R1000(Sold), 96 GSX-R600(Sold),11' DR-400s(SOLD)
anyone try this shock?
looks like a good cheaper option, Anyone know anything about this ?
https://www.denniskirk.com/progressi...prd/584871.sku
agnt_kruger is offline   Reply With Quote
Old March 8th, 2018, 10:19 PM   #2
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
wow! $188 bux. only one on hand.
"trying not to get old"
Old March 9th, 2018, 05:45 AM   #3
mgentz
Board Member
better than stock at a super low price. I'd go for it if I didn't already have a super expensive Penske.
Old March 9th, 2018, 07:15 AM   #4
maverick9611
MOTM - Feb '18
i just bought one! the only 1 left is not true. i refreshed and the qty stayed the same.
Old March 9th, 2018, 10:13 AM   #5
agnt_kruger
this is probably better for a heavier rider right? I am 200lbs and wondering how much better this shock would be than stock.
Old March 9th, 2018, 10:15 AM   #6
maverick9611
MOTM - Feb '18
i’ll let ya know. i’m the same weight as you
Old March 9th, 2018, 08:35 PM   #7
Dab
Motorcycle(s): 1996 ninja 250
yeah im still rocking the old pregen shock too and my bike is absolutely bagged with me being 210. sounds like this could be my next step along with some new front springs/seals
Dab is offline   Reply With Quote
Old March 9th, 2018, 09:53 PM   #8
maverick9611
MOTM - Feb '18
i’m new new gen. i do not know if this fits pregen.
Old March 9th, 2018, 10:44 PM   #9
maverick9611
MOTM - Feb '18
this shock fits...
Old March 9th, 2018, 11:03 PM   #10
Should be able to fit it since common upgrade for pregen is to install newgen shock for stiffer spring and preload adjustment. I have one of each in box, will measure tomorrow
Old March 9th, 2018, 11:06 PM   #11
maverick9611
MOTM - Feb '18
I'm sure your right but on the progressive website it shows no listing for pregens. it does show length 12.6”
Old March 10th, 2018, 08:17 AM   #12
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
No longer available.
TEAM ALFALFA
www.apexassassins.com
Old March 10th, 2018, 08:20 AM   #13
maverick9611
MOTM - Feb '18
did you try progressive’s website. they had it there at normal price☹️
Last futzed with by maverick9611; March 10th, 2018 at 10:23 AM.
Old March 10th, 2018, 08:45 AM   #14
AwDang
Motorcycle(s): 286, 296, 599, 799
At $350 it’s no longer worth investigating
AwDang is offline   Reply With Quote
Old March 10th, 2018, 10:45 AM   #15
Alchemist
Crash Test Dummy
Motorcycle(s): none (at the moment)
Not trying to derail the thread, but since the original item is no longer available, what *is* the recommended spring rate for someone around 200-210? I ask because I'm starting a pregen rebuild and I'm about the same weight.
Alchemist is offline   Reply With Quote
Old March 10th, 2018, 10:55 AM   #16
It depends upon your type of riding. If your cruising and commuting, I'd say a spring of 7.0-7.9kg/mm is appropriate. If you're tracking or racing, 8.0-9.5 may be better with smooth surface and matching damping.
Looks like the 435 shock is available at Chapparal for $320
Old March 10th, 2018, 12:58 PM   #17
Alchemist
Crash Test Dummy
Thanks, Danno. I should have specified - cruising/commuting is definitely my application and there are enough potholes around here that the "smooth surface" assumption is wantonly violated.
Old March 10th, 2018, 10:41 PM   #18
maverick9611
MOTM - Feb '18
so it is possible
https://www.ninjette.org/forums/showthread.php?t=54601
Old March 11th, 2018, 01:32 AM   #19
Yup, problem with those compatibility databases is there are actually three possible values:
1. Tested YES
2. Tested NO
3. Untested
Problem is, if a combination that DOES fit hasn't been tested, it falls into category 3 and is not listed. Really annoying because it's incomplete and not accurate data.
I went through this with Amazon recently with buying replacement H7 bulb for my CBR600RR. Bulbs are commodity items like potato chips; everyone has them. However, because Amazon has only tested one or two, it lists pretty much every H7 as "does not fit your CBR600RR". It would've been more accurate if they just said, " this product has not been tested on your bike so we cannot confirm YES or NO on fit"
Old March 11th, 2018, 04:50 AM   #20
maverick9611
MOTM - Feb '18
that’s a logical explanation.
Old March 11th, 2018, 08:46 AM   #21
Ralgha
Ralgha's Avatar
Yeah, Amazon's "fitment" information is nearly worthless. If it says it fits, it probably does, but if it says it doesn't...it means nothing, because it still often does.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old March 11th, 2018, 02:58 PM   #22
Dab
I figured i could swap a newgen size shock in fairly easily just wanted to know my ninjettes personal reviews on their upgrades
Old March 11th, 2018, 04:03 PM   #23
Here's some reviews of newgen shock on pregen
https://www.ninjette.org/forums/showthread.php?t=117676
https://www.ninjette.org/forums/showthread.php?t=148473
Old March 11th, 2018, 10:07 PM   #24
Dab
yeah may as well find a next to new 300 stock shock just seen a couple on amazon for around 60$
Old March 16th, 2018, 06:54 AM   #25
Flying
Motorcycle(s): 2010 Ninja 250
Here is the manufacturer's catalog:
https://www.progressivesuspension.com/pdfs/7100-105.pdf
Refer to Order No. 435-1001
Old March 16th, 2018, 01:44 PM   #26
Can find it at many retailers. Just costs $320-350. Maybe Kirk didn't want it on their shelves anymore and did a close-out.
Old March 16th, 2018, 04:39 PM   #27
maverick9611
MOTM - Feb '18
must have been on the shelf awhile. shock label said it was made in 2013
Old April 5th, 2018, 03:19 PM   #28
agnt_kruger
how does the shock work ?
Old April 8th, 2018, 12:39 PM   #29
maverick9611
MOTM - Feb '18
installing today
Old April 8th, 2018, 12:42 PM   #30
maverick9611
MOTM - Feb '18
super easy with blairs stand.
i used a dano jack from my zrx days for keeping the rear wheel/swingarm from dropping
nice
Old April 13th, 2018, 04:08 PM   #31
agnt_kruger
well, how is it?
Old April 13th, 2018, 04:29 PM   #32
mgentz
Board Member
@maverick9611 would you be able to measure your stock shock eye-to-eye length? What is that number in mm?
Old April 13th, 2018, 05:48 PM   #33
maverick9611
MOTM - Feb '18
i’ll do it in the morn
Old April 13th, 2018, 05:55 PM   #34
mgentz
Board Member
Awesome. Thanks!
Old April 14th, 2018, 04:44 AM   #35
maverick9611
MOTM - Feb '18
well, how is it?
soon as i finish sinnob poly sprox install, rear hugger and motobrix chain oiler,i'll let ya know.
Old April 14th, 2018, 04:50 AM   #36
maverick9611
MOTM - Feb '18
i would check out
motochief.net in indonesia if you want a rear shock at a great price. out ninja buddy bernawanfr can help with shipping. our ninja is called the 250 karbu(carbs)
ohlins for $ 508. try finding that in the states at that price
Old April 14th, 2018, 07:41 AM   #37
Ralgha
Ralgha's Avatar
Ohlins for $500 seems too good to be true. Do we know they're legit?
Old April 14th, 2018, 07:50 AM   #38
mgentz
Board Member
Any luck?
Old April 14th, 2018, 12:53 PM   #39
maverick9611
MOTM - Feb '18
this = to 320.04 mm. this is what got also( maybe not the .04)
Old April 14th, 2018, 02:35 PM   #40
mgentz
Board Member
So, stock is 320mm. Thank you!
R6 Shock? Triple R 2008 - 2012 Ninja 250R Tech Talk 10 July 9th, 2014 12:10 PM
1996 ZX600C shock or 2010 300 shock jgcable 1986 - 2007 Ninja 250R Tech Talk 9 April 30th, 2014 05:35 AM
>'08 Rear Shock Kokosun Items Wanted 2 July 10th, 2013 09:51 AM
Replacing my rear shock with a newgen rear shock... ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 12:38 PM
looking for a J shock Ninja Nut Items Wanted 1 February 19th, 2010 10:16 PM
