Old August 11th, 2018, 04:11 PM   #1
$wim
Motorcycle(s): 06 ninja 250r, 82 yamaha xj750
06 250r idle issues
So after all the help I got with getting my bike running I figured I’d reach out again. Since finishing the previous work of cleaning and replacing the main jets, my bike idles at a high 5-7 and if left idling without riding it will overheat. I already have been messing around with the idle adjustment knob and it does nothing, this have something to do with the idle mixture screws?
$wim is offline   Reply With Quote
Old August 11th, 2018, 08:33 PM   #2
THusker
Check to make sure the throttle cables are adjusted properly. If too tight the cable will not allow the throttle to be adjusted by the idle speed knob.
THusker is offline   Reply With Quote
Old August 11th, 2018, 11:17 PM   #3
Is this high-idle with or without choke on?
Old August 11th, 2018, 11:24 PM   #4
$wim
Idles high with it on and off
Old August 12th, 2018, 05:38 AM   #5
Vacuum leak.
An engine will only run at speed dictated by ingested air, no more, no less.
Check around boots for incomplete seating and/or rips or holes.
Old August 19th, 2018, 04:02 AM   #6
$wim
Vacuum leak.
I did have a previous problem with that before.. I will be taking off my tank and checking over vaccum seals, throttle, ect. I will be on with an update later today
Idle issues Matthew243301 2008 - 2012 Ninja 250R Tech Talk 1 February 15th, 2018 03:41 PM
Idle issues - Idle is different every time I start up. 106 1986 - 2007 Ninja 250R Tech Talk 6 November 13th, 2014 04:57 PM
idle issues jgcable 1986 - 2007 Ninja 250R Tech Talk 9 July 30th, 2014 03:13 PM
Idle/running issues SDninja 1986 - 2007 Ninja 250R Tech Talk 15 August 19th, 2010 02:09 PM
Idle issues Gyrene 1986 - 2007 Ninja 250R Tech Talk 15 May 4th, 2010 11:43 AM
