Notices
Old January 21st, 2019, 09:41 AM   #1
Skrrrt
Motorcycle(s): 2008 Ninja 250
How can I get these handlebars!???
hello everyone ! maybe you've seen me at the new member area, I am doing my 500cc ninja 250 swap...
I have a 2008 ninja 250
and instead of an angled handlebar I was wondering if I can get something like this on there? I want something more straight .
https://www.motosport.com/product/?a...segment=badger
pros and cons if this can be done?
if not what would you suggest as a better upgrade for the handlebars.. I feel like its to uncomfortable at times... I don't know.
Skrrrt is offline   Reply With Quote
Old January 21st, 2019, 10:43 AM   #2
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
This ought to get you started:
https://www.ninjette.org/forums/showthread.php?t=75165
It looks as if, at minimum, you'll need to drill a couple of holes in your upper triple. You need a place to mount the riser blocks.
Define "more straight." Do you mean less pulled back when viewed from above, or more horizontal when viewed from the front?
There's also rise and forward/aft placement to consider. The grips aren't going to wind up where they are now. Don't be surprised if you need a longer front brake line and longer cables for the clutch and throttle.
There may be clearance issues with the front fairing/windscreen.
Going to a separate handlebar will raise your hands quite a bit and make an already-upright bike even moreso. This is because the riser blocks will raise the bar, and the bar itself will also add some rise. You may also find that the bar isn't angled the way you like anyway. Depends on the bar you choose, of course.
Another option is Apex clip-ons. These are costly but super-adjustable to suit your preferences.
Old January 21st, 2019, 04:32 PM   #3
I like clip-on bars: https://www.ebay.com/itm/183637480298
I find them most comfortable about 1" above seat height.
Old January 21st, 2019, 05:47 PM   #4
Skrrrt
for this season ill be doing alot of mountain riding and minimum offroad so i like the fel of the handlbars on the grom and supermotos idk maybe because i learned from how to ride on them first when i was in vietnam lol, but anyways the handlebars on the grom are more straight as where the ninja handlebars are inverted at an angle, i find sometimes thats uncomfortable for my long rides.
Old January 21st, 2019, 05:49 PM   #5
Skrrrt
Any cons or safety issues if i drill two holes into the triple clamp?
Old January 21st, 2019, 05:55 PM   #6
No problem. They've got tonne of holes already. Make sure outside edges all around are smooth of nicks; that's where cracks starts.
So by straighter, you mean bars going more sideways and bent upwards instead of downwards?
Old January 21st, 2019, 06:48 PM   #7
Skrrrt
BINGO LIKE THOSE!!!!
A buddy of mine is running a more sideways one, and its very comfortable for my shoulders "i have a shoulder impingement syndrome" at a certain amount of time or certain pressure point my shoulder gets unbearably painful so these bars would help.
and for sure ill definitely do it professionally!
Old January 23rd, 2019, 06:26 AM   #8
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
I think ive seen bar conversion parts on some of the asian motorcycle vendors websites.
Dave Wolfe is offline   Reply With Quote
Old January 23rd, 2019, 12:49 PM   #9
Yeah, easy to find. I like this design best:
- one-piece design, so both bores are in-line and concenctric
- 4 bolts clamps everything together
- 4 bolts through triple-clamp for more secure connection rather than just 2
- fewer bolts, you can check torque on triple-clamp bolts without removing handlebar
Old January 23rd, 2019, 06:10 PM   #10
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
https://japan.webike.net/ps/#!p.m=5921&p.c=1037&p.sk=1
Cant vouch for any of this stuff.
Handlebars wobble Sykes92 General Motorcycling Discussion 20 December 5th, 2013 08:51 PM
Wanted: Handlebars LoneRonin Items Wanted 3 March 20th, 2013 05:14 PM
Pregen handlebars kg4kpg Items Wanted 2 October 8th, 2012 05:57 PM
Handlebars Eagle981 1986 - 2007 Ninja 250R Tech Talk 13 September 30th, 2012 09:11 PM
why do our handlebars look different? shellneil General Motorcycling Discussion 5 November 20th, 2009 03:49 AM
