Notices
Old January 21st, 2019, 06:37 PM   #1
Juliamun111
Motorcycle(s): Ninja 250 2012
Carburetor hosing help!!!
My stupid self took apart my bike to clean the carbs and now I cant remember where some of the vacuum lines go and why my idle adjustment knob is just dangling out the side of my bike :I please help. I've attached pretty clear photos!
Juliamun111 is offline   Reply With Quote
Old January 22nd, 2019, 07:07 AM   #2
ducatiman
ducatiman's Avatar
welcome to ninjette......and see this
https://faq.ninja250.org/wiki/Hose_r...ine_fuel_tanks
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old January 22nd, 2019, 09:15 AM   #3
Juliamun111
I have already got all vacuum tubes connected to the gas tank and petcock :I I was thinking maybe one of the mystery lines were the overflow tube? Where is that connected too? The other one is connected too the t tubing, but all photos I've seen show where the bottom two tunes go (one goes to petcock, one goes Into carbs) but doesn't show where the central line comes from
Old January 22nd, 2019, 10:24 AM   #4
ducatiman
ducatiman's Avatar
https://faq.ninja250.org/wiki/File:Routing.gif
this should be ALL hoses from carbs to tank on a Ca model
Custom Carb Service
Old January 22nd, 2019, 03:10 PM   #5
ducatiman
ducatiman's Avatar
just realized this thread is posted in the wrong (300) section....
Custom Carb Service
Old January 22nd, 2019, 05:27 PM   #6
Also the diagrams are for pre-gen '88-07 bikes. She's got a new-gen '08-12.
I think there's a new-gen diagram somewhere... back in bit...
Old January 22nd, 2019, 05:30 PM   #7
Idle-adjuster goes underneath carbs to left side of bike.
You'll see wire loop (shepherd's crook) that holds a split grommit.
Shove cable into split in grommit.
Old January 22nd, 2019, 06:57 PM   #8
ducatiman
ducatiman's Avatar
good @DannoXYZ .... a most knowledgeable Ca member to help out....I've actually seen just 1 Ca model, an EX500 at that, around 10 years ago.
Custom Carb Service
Old January 22nd, 2019, 06:59 PM   #9
Juliamun111
@DannoXYZ THANK YOU SO MUCH!!
Old January 22nd, 2019, 09:16 PM   #10
This is vent tube for carbs. Dumps excess petrol in event of overflow.
It should go down between two rubber tubes between carbs down to centre of bike. Exit by rear shock next to crankcase vent tube and gas-tank vent tube
Old January 22nd, 2019, 10:12 PM   #11
This air suction valve is located between cylinder-head valve-cover and frame.
Short big hose connects to valve cover.
Long big hose connects to airbox.
Medium small hose connects to... Yup... that right!
Old January 23rd, 2019, 12:37 PM   #12
You're welcome!
Carburetor routing Abelburnem 2008 - 2012 Ninja 250R Tech Talk 4 October 7th, 2017 08:32 AM
carburetor skip 2008 - 2012 Ninja 250R Tech Talk 9 June 5th, 2017 12:39 PM
Carburetor Cleaning Motofool Videos 3 May 20th, 2014 08:42 PM
carburetor bolts james250ninja 2008 - 2012 Ninja 250R Tech Talk 3 September 2nd, 2011 01:53 PM
Carburetor Heads Up Jakester9500 1986 - 2007 Ninja 250R Tech Talk 14 March 31st, 2010 09:44 AM
