Old February 17th, 2019, 10:27 AM   #1
Sylar
Motorcycle(s): ninja 250 gpx
2001 ninja wont start after winter
Engine cranks but it wont start. Choke or open throttle dont make any difference. Cam timing is ok. valve clearence is ok. there is no residue in carburator (drained them and the fuel was clean). Fuel in tank is from october Spark plugs have 1000 km. Battery is brand new and good. The bike was ok before winter. Planning to check spark plugs and ignition wires. Any other ideas ??
Sylar is offline   Reply With Quote
Old February 17th, 2019, 11:39 AM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Don't know about the gas there, but here in the States in can go bad in a month or 2. The "choke" isn't really a choke, it's an enrichener circuit and needs the throttle closed all the way to make the mixture richer. I've had to clean my carbs after a winter storage before, make sure your getting fuel through the carbs, and getting spark.
PS: welcome
Old February 17th, 2019, 11:50 AM   #3
Sylar
I drained the carb bowls and then after trying to start engine they wer filled up. I assume this means petcock is not a problem here and is working fine, but is this mean that fuel is getting thru the carbs to combustion chamber ??
sorry for poor english
ps been so long here as a reader that i felt here like home and forget to say hallo
Old February 17th, 2019, 12:07 PM   #4
ducatiman
ducatiman's Avatar
"fuel from October"
Try first.....dump the old fuel (including what is in the carb bowls) ...fill with fresh!
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old February 17th, 2019, 03:02 PM   #5
Z1R rider
Z1R rider's Avatar
I'll guarantee your English is better than my Polish!!
Do as ducatiman says and start with fresh fuel. It's a good sign that the carb bowls are filling with fuel, but that does not mean the fuel is getting through the carb passages which feed into the intake (hose between the carb and the head) and on to the cylinders. If you crank on it for 15 or 20 seconds and pull a spark plug you should be able to see that the electrodes are wet with fuel or at least smell gas on them. If not you'll need to clean the carbs.
Old February 18th, 2019, 08:51 AM   #6
As noted - drain the tank and floatbowls and refill with fresh gas.
Chances are that's all it is.
Make sure the battery is fully charged because you will need to crank to produce vacuum to open the petcock and fill the floatbowls.
Try different throttle openings and choke settings if it doesn't fire after a bit, and charge the battery between attempts.
Old February 19th, 2019, 09:14 AM   #7
Sylar
Ok soooo spark plugs are ok spark plug wires are ok the fuel is getting into combustion chamber. The fuel is fresh and it wont even try to start..... Any ideas ??
Edit:
pissed off went to store and buy autostart. And it run for about 2 - 3 sekonds then died. Tried again but it did nothing (think battery was already tired). Right now im charging battery. Correct me if im wrong but if it will run again for short periods of time on autostart and then died it will mean that carburator is guilty here and even if it gives fuel it is not properly sprayed and mixed with air ??
Old February 19th, 2019, 11:58 AM   #8
If it pops and runs on Starting Fluid it means you aren't getting fuel.
If you have confirmed there is fuel in the floatbowls, the chances are good the jets are plugged.
If you didn't add stabilizer to the gas or drain the floatbowls before storing there's a pretty good chance that's the issue.
Old February 19th, 2019, 12:03 PM   #9
ducatiman
ducatiman's Avatar
immediately stop the use of starting fluid....doesn't play well with plastic slides......clear the carb circuits instead
Custom Carb Service
Old February 19th, 2019, 12:29 PM   #10
Sylar
Ok i dont use it again. "plastic slides" - i dont know which element this is. Could you explain ??
Old February 19th, 2019, 03:21 PM   #11
ducatiman
ducatiman's Avatar
przepustnica or poślizgnąć się in your language? I try
the black plastic throttle valve...slider that goes up and down when you open/close the throttle
the plastic could be damaged by the autostart (starting fluid)
Custom Carb Service
Old February 19th, 2019, 04:03 PM   #12
Sylar
https://joemonster.org/filmy/96118/P..._Kanady_mowili 00:10 - poślizgnąć się in my language xD
I ve always thought that that kind of valves should be metal due to rough conditions in "engine environment"
Old February 20th, 2019, 06:53 AM   #13
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
The first thing I would do is check the petcock is working by pulling a vacuum either with a syring, turkey baster or by sucking. If the petcock failed and you are not getting fuel then anything else you try down line is just wasting time and effort.
Next make sure the bowls are full.
I bought a bike that had not run in years. The petcock needed cleaning. After that the carbs needed cleaning. Now it runs perfectly. Oh I also had the dissemble the gas cap and clean that filthy thing. There was corrosion and crap everywhere.
Cafe Racer is offline   Reply With Quote
Old February 20th, 2019, 08:15 AM   #14
ducatiman
ducatiman's Avatar
he confirmed bowls were filling in post #3, was then advised to clean carbs in #9
Custom Carb Service
Old March 20th, 2019, 10:58 AM   #15
Sylar
Finally did my carbs. It was all factorys fault xD Bowls were clean jets were clean everything was clean. Everething except mixture screw port. Ther were idel mixture screw plugs in my carburator so the ports and screws were never cleaned and all messy. Also one of the screws were backed out only 2 turns and the other one 2 an 1/4 so they both were out of factory specs out of factory.......
Old March 20th, 2019, 05:28 PM   #16
Actually, manual states 2-turns out is correct spec for U.S. and CA bikes. So yours was correct and slightly rich on one side. Starting issues was most likely clogged pilot jet due to dried petrol.
What did you set yours to? If set to new-gen spec of 2.5-turns, that will also work. But 0.5 turns difference will not stop engine from starting.
Old March 24th, 2019, 09:10 AM   #17
Sylar
I had set them to 2.5 . Before ninja could not idle under 2000 rpm. Now I can set idle even on 1000 rpm and it stay there ( that carb synchronization is yet to be done.)
2007 Ninja 250 dies and wont start when warm Hewes 1986 - 2007 Ninja 250R Tech Talk 12 September 19th, 2018 11:31 PM
After LONG winter sitting, bike wont start RedNinja09 General Motorcycling Discussion 44 January 20th, 2018 02:34 PM
Backfiring wont start 2007 Ninja 250r ColeJefferson 1986 - 2007 Ninja 250R Tech Talk 8 October 24th, 2016 05:31 PM
- - -Bike Wont Start - - - Triple R 2008 - 2012 Ninja 250R Tech Talk 1 July 31st, 2014 06:54 AM
2007 Ninja 250 wont start...any suggestions? tkessler 1986 - 2007 Ninja 250R Tech Talk 11 February 26th, 2014 10:36 AM
