Old February 18th, 2019, 08:09 AM   #1
minimatt
minimatt's Avatar
Stalling when put in gear
Hello,
So I've only been driving around 2 weeks now. I went out for a drive around today and half way through my journey in the middle of stop and go traffic my ninja decides to stall and I thought "well, ****. what did I do this time". Me still being a noobie, I assumed it must've been poor clutch control. But since that incident it has stalled a number of times when put into first, even when completely still. I managed to get home fine with no stalls for some reason, but the bike stalls whenever I go into gear now that I'm home. Starts up fine in neutral. Doesn't start up in 1st gear. Not sure if the ninja can even do that though. It's an instant cut-off when put into first.
Any ideas on what to check? Kickstand switch seems to be in working order, but I'm looking at it through the eyes of a guy who's never done anything mechanical before. I assume it's the clutch? Before the problem occurred, the bike moves forward slightly when put into first, if that bit of information helps. I assumed most bikes do that though.
-Bike stalled in 1st in middle of traffic
-Pulled over
-Bike kept stalling until magically went into first without dying
-Died in 1st again halfway home.
-Pulled over
-Again bike managed to go into first. Didn't stall for the rest of the journey after that.
-Got home and bike just completely dies off when put in gear.
I would consider my clutch control pretty good now, I do stall from time to time again, but i know 100% It's not me causing it this time.
minimatt is offline   Reply With Quote
Old February 18th, 2019, 08:46 AM   #2
Sounds like the clutch needs adjustment to me -
https://faq.ninja250.org/wiki/Adjust...e_clutch_cable
What is the hot idle speed set at?
The carbs/TBs may need to be synced or there may be maintenance items (air filter, valve adjustment) that may need to be done.
I would also check the kickstand and clutch switches - https://faq.ninja250.org/wiki/Unders...afety_switches
More general info - https://faq.ninja250.org/wiki/Ninja250_Howto
It dangerous to ride like it is, so if you can't get it sorted I would take it to someone that can.
Old February 18th, 2019, 09:23 AM   #3
dodgerdad
dodgerdad's Avatar
My money's on the kickstand switch. 🤑
Old February 18th, 2019, 01:32 PM   #4
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
what he said ^^^^^^^
Old February 18th, 2019, 06:56 PM   #5
Yup.
Kickstand switch is not indicating that kickstand is in UP position when it really is.
So bike thinks kickstand is DOWN and when you put it in gear, it turns OFF engine for your protection.
Unless you can see electrons flowing in wires, switches must be tested electronically.
Do you have multimeter and know how to use it to measure resistance (ohms)?
Old February 19th, 2019, 03:59 AM   #6
minimatt
minimatt's Avatar
That's strange. If it was the kickstand switch why would it happen halfway through the journey when I've already had the kickstand up for an hour and haven't put it down? I don't have a multimeter but i'll borrow one from a friend. I have a slight idea on how to use it, but not proficiently. Checking the resistance should be no problem. Where would I connect the positive and negative on the switch for the ninja 250r?
You guys are probably right about the kickstand switch. I've tried changing it into gear while revving, still cuts off instantly. Bike can be pushed with clutch in while in 1st gear (off), which means the clutch isn't sticking. Everything seems to be leaning towards kickstand.
Old February 19th, 2019, 06:55 AM   #7
Kowalski
Kowalski's Avatar
Motorcycle(s): 2014 Ninja 300
How much free play is in your clutch lever? Sounds like the clutch isn’t completely disengaging to me. Can you pull the clutch in and push the bike while it’s in gear?
For the kick stand you don’t need a meter. You just unplug the kick stand sensor and jump the 2 pins together. You can use a piece of wire or even a paper clip. Of you want to permanently bypass it you can use a butt connector and splice the wires together. This is what I’ve done on my track bikes.
Kowalski is offline   Reply With Quote
Old February 19th, 2019, 07:04 AM   #8
minimatt
minimatt's Avatar
To be honest, it seems like little to no free play. I only bought the bike 2 months ago. Just seems to be how the previous owner preferred it. I've grown accustomed to it. That's why I changed my mind about the clutch not being fully engaged being the case, considering how little free play there is. I've also tried giving it a rev while changing it into 1st gear. It's an instant cut-out.
I'll try looking into bypassing the kick stand sensor as you said. Thanks for the tip.
Edit: Yes, I can push the bike in gear with the clutch in.
Old February 19th, 2019, 10:28 AM   #9
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
If your kickstand sensor is not quite right that could give you your intermittant problem. It could have been shorting/behaving for a bit until it finally failed. So now the bike thinks the kickstand is always down. Test it with the bypass, then replace it.
Old February 19th, 2019, 03:43 PM   #10
minimatt
minimatt's Avatar
Hi guys, thank you all so much for your help! As I, and some of you, have suspected, it was the kickstand switch.
It was an easy 20 minute fix (temporary). Disconnect the connectors of your kickstand switch. Inside the connector there's two pins you push in to release the wire from the connector. I electrically taped the two wires together with contact. This essentially bypasses the kickstand switch, so do be careful when doing this. I will try to get the switch replaced as soon as I can.
I would have spliced the two connectors together with heat shrink butt connectors, however, that would be a more permanent fix, as stated by Kowalski.
You could also cut off the kickstand male connector wires, splice the two wires together, and connect it back to the female connector. It is essentially the same, except that you don't have to mess with any of the main wires.
Bike goes in gear just fine and runs now.
Here's a helpful video of the process: https://youtu.be/FLxyE0jSrBo
Old February 19th, 2019, 04:18 PM   #11
dodgerdad
dodgerdad's Avatar
Old February 19th, 2019, 04:35 PM   #12
minimatt
minimatt's Avatar
Originally Posted by dodgerdad View Post
Solid guess
Old February 20th, 2019, 06:41 AM   #13
Excellent, Gian.
Of course as you said, it's worth the trouble to replace the switch. I had a friend in England who forgot to put up the stand on his Kawasaki triple and died when it pitched him into oncoming traffic while making a left turn. Luckily in the US it usually pitches the bike off the road, but that's not without problems too.
I have a couple old motorcycles without side stand switches, and have made it part of my starting procedure to not ever start the engine until I retract the stand if I'm sitting on the bike.
Honda had a neat solution... they put a rubber finger on the foot of the stand so if it hits the pavement while moving it flips the stand back.
Old February 23rd, 2019, 04:45 PM   #14
minimatt
minimatt's Avatar
Thanks, Jim!
Sorry to hear about your friend. I've made it a habit to only start up the bike when the kickstand is up. It's a good habit I've made from this ordeal for the meantime while I wait for a new kickstand switch.
Old February 24th, 2019, 07:38 AM   #15
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
I have owned and ridden lots of bikes. Kick stand switches are for novice riders.
Too many safety interlocks can get you killed in traffic. Like your switch failing while riding in traffic.
Too bad Kawasaki did not ditch the kickstand switch and put a gas gauge on the pregens.
Cafe Racer is offline   Reply With Quote
Old February 24th, 2019, 06:49 PM   #16
Ralgha
Ralgha's Avatar
My new gen has a gas gauge, it's useless, totally inaccurate, much like Cessnas.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old February 24th, 2019, 08:54 PM   #17
CaliGrrl
CaliGrrl's Avatar
I think the first time I tried to start riding with my kickstand down I'd been riding for just over 2 years. Went to lunch with a friend, go to start the bike, put in gear.... dies. Ok, maybe I let the clutch out too fast. Try it again. Dies.
Uh... kickstand. Got it.
Old February 25th, 2019, 01:55 AM   #18
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
just leave the switch off. i'm sure you can remember that. just one less thing to worry about.
"trying not to get old"
[motogp.com] - Put 'em up: martial arts clinic gets Assen in gear Ninjette Newsbot Motorcycling News 0 June 28th, 2018 06:40 AM
2003 Ninja Dies when put in gear RichmondKawi 1986 - 2007 Ninja 250R Tech Talk 21 December 17th, 2016 12:46 AM
Stalling in 1st Gear at stops - HELP!!!!! kingskater 2008 - 2012 Ninja 250R Tech Talk 27 September 5th, 2012 08:39 AM
Gear-Tip: Put A*s Smart armor inserts from your leathers into your jeans WhiteRice Motorcycle Gear 1 September 26th, 2011 12:14 AM
HELP! Bike will start but once put in gear dies TreyE 1986 - 2007 Ninja 250R Tech Talk 6 September 3rd, 2009 12:45 PM
