Old February 25th, 2019, 09:06 PM   #1
Darksik
Darksik's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R, 99' Suzuki Katana 600 (RIP)
Too much air to the carbs?
Hi guys, I previously commented that I had a problem with my ninja, since I removed a piece of paper that obstructed a hole in the snorkel, the motorcycle made many explosions and i need to open more the throtle, I thought that the spark plugs could be dirty with oil, I changed the spark plugs and I put a K & N filter thinking that could be that problem, I put the piece of paper back to the snorkel and the motorcycle accelerated better, as before removing the piece of paper, the mechanic said that maybe the carburetors are not calibrated
Darksik is offline   Reply With Quote
Old February 25th, 2019, 09:30 PM   #2
Ralgha
Ralgha's Avatar
Well many people here are more knowledge than I with respect to engines, but it sounds to me like you're running way too lean. Probably need to clean the carbs, unless they've been rejetted to be too lean.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old February 25th, 2019, 10:22 PM   #3
Yup, clogged carbs need complete removal, disassembly, and thorough cleaning.
Related threads:
https://www.ninjette.org/forums/showthread.php?t=330960
https://www.ninjette.org/forums/showthread.php?t=322846
https://www.ninjette.org/forums/showthread.php?t=321223
https://www.ninjette.org/forums/showthread.php?t=317977
https://www.ninjette.org/forums/showthread.php?t=317810
https://www.ninjette.org/forums/showthread.php?t=316395
https://www.ninjette.org/forums/showthread.php?t=315193
https://www.ninjette.org/forums/showthread.php?t=280658
Old March 1st, 2019, 08:38 AM   #4
ducatiman
ducatiman's Avatar
@Darksik -
As you are running a factory airbox, its safe to say you've got optimum air flow, pressures, etc....as dictated by airbox capacity and configuration to work in conjunction with the supplied CV carbs. I'd tend to trust the capabilities of those Kawasaki design engineers, tasked with meeting emissions standards, performance, fuel consumption and within economical goals. I'll go on record stating they did a pretty darn good job.
As Kawasaki sold a ton of 250's worldwide over a long production period....i'd further commend them with a corporate "mission accomplished!".
That said, you HAVE received valid info above by members @Ralgha and @DannoXYZ on needing to fully review fuel delivery and carburetor function and cleanliness.
As the airbox is (basically) a fixed entity...the fuel system (carbs) are, in fact, prone to negative influences.... restriction, maladjustment, weather, effects of poor fuel.... on and on.
Get the paper out of the airbox, properly clean and adjust them carbs and RIDE!
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 1st, 2019, 08:42 AM   #5
Darksik
Darksik's Avatar
@Darksik -
That said, you HAVE received valid info by members on needing to fully review fuel delivery and carburetor function and cleanliness.
About that theme of adhust the carbs is to move the "carb sync adjuster screw"?
Old March 1st, 2019, 09:21 AM   #6
ducatiman
ducatiman's Avatar
amongst many other tasks involved, yes.
Urge you to NOT experiment with synch, until the carbs are truly cleaned first. Don't do an "end run".
Custom Carb Service
Old March 1st, 2019, 01:05 PM   #7
That's the one part you don't want to touch. Leave that alone. But disassemble down to these parts and clean each one well.
Old March 2nd, 2019, 10:32 AM   #8
Darksik
Darksik's Avatar
The mechanic told me the problem was the diaphragms, he told me by telephone, the diaphragms were bad installed also one piece of the diaphragm was cut, i don't know how
Air box to carbs HOTWAX 1986 - 2007 Ninja 250R Tech Talk 4 June 11th, 2018 01:53 PM
[motorcycle.com] - Arnott air Introduces Ultimate Ride Air Suspension Kits For 06-17 Ninjette Newsbot Motorcycling News 0 October 24th, 2017 03:00 PM
[webbikeworld.com] - MotoPumps Air Shot Portable Tire Air Compressor Review Ninjette Newsbot Motorcycling News 0 January 3rd, 2017 07:20 AM
Does this sound like dirty carbs/air filter? Chazeman2 1986 - 2007 Ninja 250R Tech Talk 7 May 4th, 2014 04:53 PM
best way to seat the air box to carbs. fixture 1986 - 2007 Ninja 250R Tech Talk 2 November 13th, 2009 02:18 PM
