Old May 23rd, 2019, 09:01 AM   #1
curlyface
2009 Ninja Leaking Right Fork
Hello!
I recently (few weeks ago) purchased a ninja 250 from a friend, my first bike. I've had a number of issues I've dealt with to this point but am now experiencing leaking forks. I've googled quite a bit and found that prior to replacing the seals I should try a seal mate to get the dirt out. The issue is, I don't see any guides on doing this procedure on a ninja 250 itself and I can't seem to get into the seal. There's a fork guide on this forum with this image:
The person seems to fit a knife under the seal without removing that outer black piece around it. My seal is so tight I can't fit anything into that spot to get it out.
I'd really like to avoid spending $400 to get this fixed and try going the seal mate route first. Does anyone have any suggestions on getting the seal off? Here's a photo of my fork, you can see the leak, too: https://imgur.com/a/39qFGzX
thank you
curlyface is offline   Reply With Quote
Old May 23rd, 2019, 09:46 AM   #2
ducatiman
ducatiman's Avatar
https://sealmate.net/
there are "how to's" on their site.....and a contact button. I'd suggest going right to the source for proper, correct service use info.
I think its a offshoot company of Motion Pro?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Effects of leaking fork seal Twisthem488 2008 - 2012 Ninja 250R Tech Talk 7 September 5th, 2015 09:44 AM
right fork tube seems to be leaking.. NinjaBoyEddy 2008 - 2012 Ninja 250R Tech Talk 1 November 18th, 2013 04:36 PM
Fork Seal Leaking broken neck 2008 - 2012 Ninja 250R Tech Talk 16 June 2nd, 2013 11:40 AM
oil leaking on right fork mctran 2008 - 2012 Ninja 250R Tech Talk 26 July 16th, 2012 11:08 PM
Leaking fork seal? EthioKnight 2008 - 2012 Ninja 250R Tech Talk 12 March 6th, 2012 09:20 PM
