Old June 25th, 2019, 05:57 PM   #1
MauR
MauR's Avatar
Motorcycle(s): 250R
Just one more HID retrofit
Hello All!!
I just wanted to share my HID projector setup. It is based on the following thread but with just one projector/lens.
https://www.ninjette.org/forums/show...t=hid+retrofit
https://www.ninjette.org/forums/show...7&postcount=66
Still needs a LED strip in the upper section facing to the carbon fiber plate to make the reflecting Ninja vinyl glow.
It is a Bi-Xenon lens so it should be enough to ride.
I'm sharing this since it looks like everyone is using 2 projectors and I liked the asymmetric look.
Regards
MauR is offline   Reply With Quote
Old June 25th, 2019, 06:43 PM   #2
Wow! You've done some really excellent work on your bike!!!
Old June 25th, 2019, 06:56 PM   #3
MauR
MauR's Avatar
Motorcycle(s): 250R
Thank you so much!!!! Every idea came from this forum and members like you!!! THANKS
Old June 25th, 2019, 08:04 PM   #4
Let's see some beam shots! Like against white garage door!
Old June 26th, 2019, 08:08 AM   #5
MauR
MauR's Avatar
Motorcycle(s): 250R
Sure!!! It should be installed this weekend.
Old June 26th, 2019, 02:28 PM   #6
Ceeloo Yello
Motorcycle(s): 250
That sure is purty..
Old June 26th, 2019, 05:35 PM   #7
MauR
MauR's Avatar
Motorcycle(s): 250R
Thanks!!!
Here it is fully assembled... will be installed soon.
The LED strip is connected with the HID so whenever the light is on the logo will be "on"
It will be using the same connector as the OEM low beam and I still need to adapt a connector for the high bean/HID solenoid.
The light beam is a flat line and light output seems to be very good. we will see...
Old June 27th, 2019, 08:13 PM   #8
MauR
MauR's Avatar
Motorcycle(s): 250R
Finished!!
It is mounted and working...
Old June 27th, 2019, 10:21 PM   #9
That's incredible! Good job!
What's specs on your light? Brand & model? Ta
Old June 28th, 2019, 05:38 AM   #10
Ralgha
Ralgha's Avatar
That looks great, nicely done!
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old June 28th, 2019, 05:42 AM   #11
MauR
MauR's Avatar
Motorcycle(s): 250R
THANKS!!!!!
These are the projectors:
https://www.amazon.com.mx/gp/product...?ie=UTF8&psc=1
The bulbs are generic H1 HID, 4200K
The ballast is fixed behind the instruments panel
Old June 28th, 2019, 05:42 AM   #12
MauR
MauR's Avatar
Motorcycle(s): 250R
Thanks!!!!
Old June 28th, 2019, 08:45 PM   #13
Fantastic, I love that someone finally went asymmetric with a retrofit. Well done.
Old June 28th, 2019, 10:18 PM   #14
What were your considerations for putting light on one side versus other?
Old June 29th, 2019, 06:35 AM   #15
MauR
MauR's Avatar
Motorcycle(s): 250R
Just the fact that the "nose" in the middle of the headlamp might cut/interfere with the light beam. So I decided to put it in the right side since we drive on the right side of the road and cutting left side of the beam would be the best for oncoming traffic.
At the end , the "nose" did not interfere with the beam
Old July 8th, 2020, 03:06 AM   #16
From other thread:
Originally Posted by MauR View Post
@DannoXYZ and @arthury if i can help with your projects please let me know.
I bought an extra headlight assy to keep one in case something went wrong...
By now I'm using LED H1 Bulbs (No ballast and easier wiring)
Also I went with two projectors, there's is so much better light output with both. Thinking on testing HID's with dual projectors but LED's are OK.
Regards!!!!
Thanks! Will definitely contact you for more info once I'm further in. Probably need more info or photos on how that plate and light is attached.
So you replaced HID bulb with LED and reused same projector light? Can you get another photo like this with LED bulb? Thx!
Old July 8th, 2020, 07:09 PM   #17
MauR
MauR's Avatar
Motorcycle(s): 250R
From other thread:
Shure!!!
Attached pictures of Low and Hi light pattern (2 projectors with LED bulbs)
Also attached some notes on the assembly.
Hopefully this is useful.
Let me know if I can do more to help
Old July 9th, 2020, 07:21 PM   #18
MauR
MauR's Avatar
Motorcycle(s): 250R
Some more notes...
Old July 11th, 2020, 01:01 AM   #19
@MauR, thank you SO MUCH for photos and instructions! Gonna make it much, much easier.
Larger-than-filament LED definitely causes less-sharp focusing as can be seen by fuzzy cut-off line. But at least projector separates light and dark sides much, much better than reflector lights. LED definitely looks weaker than HID, even with two of them! I’m going to research LED bulbs more, most of them fall short of even incandescent bulbs. There's rampant lying with vendors claims such as this 1200w 260 000 lumen bulb!!! Asking them what it actually puts out comes back with "about 1 000-1 500 lumens" . Which is less than incandescent bulb and many times less than HID!
Perhaps I may make my own bulb from a Cree XHP70.2 LED or some such.
Last futzed with by DannoXYZ; July 11th, 2020 at 08:50 PM.
Old July 11th, 2020, 11:13 AM   #20
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
Thanks , MauR.
arthury is offline   Reply With Quote
Old July 11th, 2020, 01:46 PM   #21
MauR
MauR's Avatar
Motorcycle(s): 250R
That sounds very interesting!!!! How does it works??
Old July 11th, 2020, 02:34 PM   #22
Check out these forums:
http://budgetlightforum.com/node/58094
https://www.candlepowerforums.com/vb...ots-comparison
http://www.candlepowerforums.com/vb/...=1#post5130843
These guys take pedestrian old flashlights and upgrade them with latest LEDs from Cree to make lightsabre!
Most LED bulbs use multiple crap LED chips in CSP package. Which results in larger-than-filament size and results in fuzzy focus and glare. They are typically only 50-lumens/per watt OTF (not as efficient as incandescent halogen). Genuine Cree xhp70.2 LED is 100lm/w OTF. At equivalent 55w power-consumption, you're looking at 5500-lumens, or more than 2x automotive high-beam lights.
Trick is mounting it into bulb-format. Most of those LED bulbs appear to use ceramic base, while heat-resistant, but doesn't actually conduct heat very well. I'm thinking of mounting to one-sided copper centre support attached to aluminium heatsink base (bottom is wasted in HID projector anyway). In which case, thermal-conductivity will be fast enough to not require those silly little fans they use.
Old July 11th, 2020, 03:06 PM   #23
MauR
MauR's Avatar
Motorcycle(s): 250R
This is great!!!! if you go this way I will be following it. THANKS!!!!
Old July 29th, 2020, 07:36 AM   #24
MauR
MauR's Avatar
Motorcycle(s): 250R
Attached pictures of Low light pattern (2 projectors with HID bulbs)
Old July 29th, 2020, 07:44 AM   #25
arthury
arthury's Avatar
Wow, they are crystal clear and have enough intensity to look like a modern car.
That will most certainly improve the rider's visibility and visibility of the bike's presence.
Old August 3rd, 2020, 04:28 AM   #26
Nice work!
Old August 3rd, 2020, 07:49 AM   #27
Wow, this is great! Did you find some brighter LED bulbs?
Old August 3rd, 2020, 04:41 PM   #28
MauR
MauR's Avatar
Motorcycle(s): 250R
No, nothing yet... those are Generic HIDs and as you said they are brighter than LEDs
I think the way to go with LEDs is fabricate them as you plan to do... but not easy at all...
Old August 3rd, 2020, 07:40 PM   #29
Duh, I need to improve my reading comprehension! Thanks!
Just finished my HID retrofit today CThunder-blue 2008 - 2012 Ninja 250R Farkles 147 May 29th, 2018 05:32 PM
08-12 Ninja 250 headlight and HID retrofit setup cuong-nutz Motorcycle-related 0 July 21st, 2015 08:57 PM
Demon eyes the only real HID retrofit available? passive101 2008 - 2012 Ninja 250R Farkles 26 October 8th, 2013 01:15 PM
HID Projector retrofit completed(Pics) ForceofWill 2008 - 2012 Ninja 250R Farkles 13 August 6th, 2012 11:58 AM
