Old July 25th, 2019, 08:12 PM   #1
Source_1
Motorcycle(s): Kawasaki Ninja 250 (ex250F)
Fixing an aftermarket ignition for ex250f
So i bought this bike for decently cheap because the last owner bought a bunch of stuff for it without getting it to fire off. I think the issue is with the aftermarket ignition system they installed. Iv'e noticed that you need a 100 ohm resistor wired in to the grey wire in the ignition. I just need to know where exactly it needs to be wired in. The wire it'self? or on the panel where the wires separate?
Source_1 is offline   Reply With Quote
Old July 26th, 2019, 12:32 AM   #2
Anywhere between ignition-switch and ECU is fine.
It's like light-switch for ceiling light in kitchen. You can put switch at fuse-box in basement, on kitchen wall, or on ceiling next to light itself. As long as it's between light-bulb and fuse-box, it'll work just fine.
Old July 26th, 2019, 11:45 AM   #3
Source_1
the wire looks like this. with two nodes.
so like just anywhere before the nodes are solders is fine?
Old July 26th, 2019, 02:45 PM   #4
By nodes you mean connectors? Doesn't matter how many connectors there are. Could be 20 or 50-billion. As long as resistor is somewhere on grey wire between igniton switch and ECU (IC ignitor) is what matters
[ IGN-SW ] -------------------------- 100ohm ------------------------------[ ECU ] or
[ IGN-SW ] -----@----@---@-@@- 100ohm --@--@-@-@-@-@- [ ECU ] is same as
[ IGN-SW ] - 100ohm ----@-@-@---@-----@------@---------@-------@- [ ECU ] is same as
[ IGN-SW ] ---@---@--@------@------@------@-----@----@-------@-100ohm- [ ECU ] is same
Last futzed with by DannoXYZ; July 26th, 2019 at 03:56 PM.
Old July 26th, 2019, 02:55 PM   #5
BTW - Welcome to Ninjette!
Old July 26th, 2019, 10:28 PM   #6
Source_1
Ok I think I get it. Thank you very much for the help!
Old July 26th, 2019, 10:49 PM   #7
You're most welcome! What most people do is splice it in somewhere on grey-wire between ign-sw and first connector (big rectanglar one). What year is your bike?
Old July 27th, 2019, 04:07 AM   #8
Source_1
It’s a 2005. Spent ages looking for a cheap bike to learn on.
Old July 29th, 2019, 10:50 AM   #9
Source_1
Just posting an update to anyone who is having this problem. The resistor did the trick, and it now has strong spark.
Old July 29th, 2019, 01:34 PM   #10
Awesome work!
Fixing the common EX250F (pregen) tank leaking problem: Anyone in ATL wanna try w/me? CZroe Motorcycle-related 3 October 15th, 2012 08:02 PM
