Old July 26th, 2019, 07:00 PM   #1
A shocking tale!
I had couple extra rear shocks laying around, so made comparison:
#1 ‘07 EX500 shock 45014-1365, 312mm length, is exact same as #2 '86-87 1st-gen 250 shock with 0.15mm thicker spring. Not significantly stiffer enough for +90lb bike.
#2 ‘86-87 EX250E 1st-gen shock 45014-1339, 312mm. Both this and EX500 shock have rotating-collar preload-adjuster which also makes it easy to replace spring.
#3 ‘88-07 EX250F pre-gen shock 45014-1406, 315mm, smallest wire-diameter softest spring. Non-adjustable in every way.
#4 ‘08-12 EX250J new-gen shock 45014-0234-37S, 320mm, stiffest stock spring, gets 5-way pre-load adjuster
#5 K-tech Razor-R shock, independent preload & length adjustments (set to 320mm). Also separate rebound & compression adjustment knobs
#6 Ohlins shock from GSX-R1000. Adds about 4-lbs extra weight. Not sure it's any better than Razor-R. Lap-times not any different in practice @ Thunderhill today.
Last futzed with by DannoXYZ; September 11th, 2019 at 06:31 PM.
Old July 26th, 2019, 07:14 PM   #2
Snake
Snake's Avatar
I’m not sure which one is the best but I like #5.
Old July 27th, 2019, 10:10 AM   #3
They are shocking! (or would be in motion, at least)
Old July 27th, 2019, 06:13 PM   #4
Snake
Snake's Avatar
So which would you recommend?
Old July 27th, 2019, 06:52 PM   #5
I like K-Tech Razor-R. I had ordered it with specs for my weight and riding style and it needed minimal adjustments on track. Asked for some fine-tuning help from Dave Moss in beginning and he fiddled with it a little and it's been perfect.
I prefer a softer suspension for my riding style, which is not as aggressive as others. I don't toss it into corners or muscle it around.
The Ohlins I had rebuilt last year with lower-weight oil. Even so, I've had to back off low & hi compresion-damping to minimal levels. It was causing some traction issues with skipping off tops of bumps. I'll still need to change to softer spring as this shock was designed for 150-lb heavier bike. It also has hydraulic preload adjuster which I think is kinda gimmicky.
Putting Razor-R back on tonight. Back-end is pretty much perfect with it and I've never lost rear. Even whacking throttle to 100% while leaned over in middle of T2©Thunderhill only pushed front-end. Might try 120 front tyre, but more than likely, I'll downsize 150 rear tyre.
Old January 4th, 2020, 04:43 PM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I just wanted to point out that the EX500 spring has more coils, so it's actually softer than the PreGen spring. The numbers I've seen are 300lb/in compared to 440lb/in.
I don't have the means to measure them precisely, but while I had the springs off, I used the fancy "stand on it and see how much it squishes" method. The EX500 spring is definitely much softer. This is supported by the SV650 shock (with a spring rate similar to the PreGen's) being a very noticeable upgrade that a number of EX500 riders have done.
It doesn't make sense for the heavier EX500 to have a softer spring, but a lot of Kaw's bikes have way-off spring rates. I've seen models with the front and rear sprung for 100lb and 300lb - not at all matched, and neither one near an average rider's weight. I've come to the conclusion that they don't put much thought into their budget bikes' spring rates (or just ignore those calculations when they pick which part they actually put into the bike).
Old January 5th, 2020, 06:40 PM   #7
I wonder if it can also be mistake in converting between units? Imperial vs. metric.
Case in point, I ordered some silk pants from Hong Kong and sent in measurements as centimetres. They assumed it was inches converted it again into centimetres and I ended up with pants that were made for 400-lb giant!!!
Last futzed with by DannoXYZ; January 6th, 2020 at 02:24 AM.
[visordown.com] - Motorcyclist's SHOCKING near miss with LAMBorgini Ninjette Newsbot Motorcycling News 0 May 8th, 2017 03:12 AM
[visordown.com] - Shocking crash caught on helmet camera Ninjette Newsbot Motorcycling News 0 March 9th, 2017 03:50 AM
Most shocking! Girl meets concrete. EthioKnight Videos 23 May 15th, 2012 09:38 AM
[hell for leather] - RideApart 4: a shocking truth Ninjette Newsbot Motorcycling News 0 May 7th, 2012 05:40 PM
[2fiddy.com] - Shocking Ninja 250 Ninjette Newsbot Motorcycling News 0 September 30th, 2008 02:57 PM
