Old August 26th, 2019, 04:22 PM   #1
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Raven's Rejuvenation!
Been gone a while, playing a little catch up.
Back in the 250 game with this little baby. Needs a fair amount of TLC but the motor seems solid.
So I'm thinking I'm going cafe on it as the front the front is MIA anyway.
Fist thing on that agenda is the tank. Rusty as f*** inside.
Anyone have any tips for saving a rusty tank? I want to save it if at all possible.
I happily still have the fuel injection kit I picked up for my last pregen.
Well, beyond that would love some ideas for headlights and whatnot as I cafe it out. Im going to be seeing who I can borrow ideas from as a catch up on what's been going on here.
Sorry I'd the pictures are screwy. It's been awhile so I can't remember just yet how to fix them.
Old August 26th, 2019, 05:07 PM   #2
If the rust isn't in danger of making pinholes, you could clean the tank out good and make sure all the gasoline is out, and pour in some Evapo-Rust. It may take a few days of turning the tank to expose all the of surface to the liquid, but it's known to work pretty well without the danger of adding to the removal of steel.
If it does have pinholes and you really want to save it, Caswell's Phenol-Novolac epoxy liner is as good as it gets as far as sticking well and being resistant to today's fuels.
Old August 26th, 2019, 05:27 PM   #3
Motorcycle(s): CB125T EX250F-street Ninja250R-race CBR250R-MC19 CBR250RR-MC22 NSR350R-MC21 VF500F CBR600RR VFR750F
Be careful of tips you'll find on vintage bicycle forums pushing oxalic acid. That stuff has no preference for rust or metal and will remove good steel along with rust!
Naval Jelly (phosphoric acid) and Evapo-rust, which I suspect uses phosphoric acid as well due to grey coating at end, is much better due to eating away only rust and leaving good metal alone.
Old August 26th, 2019, 05:27 PM   #4
LittleRedNinjette
That's actually one of the options my other half was looking at but wasn't sure if it really would work.
Old August 27th, 2019, 07:47 AM   #5
dodgerdad
dodgerdad's Avatar
Looks like there's a patch job on the left side of the tank.
Should be a fun build, keep up posting pics so we can see your progress
Old August 27th, 2019, 08:20 AM   #6
LittleRedNinjette
Yeah, not sure what he was trying to do there. We can fix any holes in it as long as we can get the rust out.
He took the tank to work to see what he can do there.
I definitely will. I'll keep this thread updated as we work on her.
Old August 27th, 2019, 09:32 AM   #7
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja250
Glad to hear from you again!
Old August 27th, 2019, 10:06 AM   #8
LittleRedNinjette
So after trying Walmart toilet bowl cleaner (YouTube remedy that didn't really do much that we could see) and a pressure washing it's looking better in there. Going to try one of the suggested cleaners next.
Old August 27th, 2019, 01:15 PM   #9
Restlessrustler
Motorcycle(s): Buell, ninja 250, Sportsters
Here is the gas cap fix that works well!
Restlessrustler is offline   Reply With Quote
Old August 27th, 2019, 04:37 PM   #10
LittleRedNinjette
Yeah... Someone needed to lay off the JB Weld...
Old August 28th, 2019, 11:54 AM   #11
Yeah, someone tried to fix hole from too-long fairing bolt puncturing tank! There's guide somewhere showing how to drill out spot-welds on plate to fix hole in tank. I just braze all around plate to seal it to tank.
Old August 29th, 2019, 12:28 PM   #12
LittleRedNinjette
so i need to get a list together of thinks i need and would like to do. Looks like the take is good. just got to seal it and check for leaks.
so what next...
any recommendations for the headlight? going to search later. something with integrated signals may be cool.
also needs tires stat! i'll have to post pictures of them later. they bad.
Thinking about trimming or just replacing the front fender with something smaller.
defiantly need a tail chop. got to look for the amber lenses for the left and right of the tail light.
guess i need to make a better list.
Old August 29th, 2019, 12:56 PM   #13
dodgerdad
dodgerdad's Avatar
so what next...
I trimmed my fender then touched up the edges with touch-up paint. In my opinion any streetfighter or cafe should get a fender trim though I think a cafe should stay long but get cut on the sides and have the front/rear rounded off. That's just my 2 cents.
Old August 29th, 2019, 04:31 PM   #14
LittleRedNinjette
That's not bad at all. Could be a idea there.
Old August 29th, 2019, 06:40 PM   #15
I highly recommend Cibie 7" e-code headlight. These 7" lights outperform everything else on market with their wide beam pattern and sharp horizontal cut-off (superior to DOT lights for reducing glare to on-coming traffic's eyes).
https://www.amazon.com/Cibie-082440-...dp/B008DQV88Q/
They also have more classic look with curved lens rather than most other's flat face.
DOT on left, Cibie e-code on right. There is also little upward flare to right to make street signs easier to read.
Old August 30th, 2019, 04:50 PM   #16
VaFish
VaFish's Avatar
MOTM - Jan '16
I've got a ton of pregen parts and set of lime green plastics. Happy to get rid of them cheap. No tank though.
Old August 30th, 2019, 07:32 PM   #17
The label on Evapo-Rust says it contains no acid. Its MSDS says it is a chelator. Now that MSDS don't have to actually say what's in the stuff in question, we have to guess. It's apparently non-toxic, and seems to work pretty well.
Old August 30th, 2019, 08:26 PM   #18
LittleRedNinjette
Shoot me a PM with what you have. May have stuff I haven't even thought about yet. Lol
Or did you have a post in here? I'll have to look again.
Old August 30th, 2019, 08:28 PM   #19
LittleRedNinjette
That one looks good. I do like the classic look a lot. Thanks!
Old September 20th, 2019, 07:28 PM   #20
Restlessrustler
Ecotrons kit "test fit" all seems good, going to permanently place wires, airbox and fuel line. Looking for a airbox rubber band....but shes gonna be a runner!
2006 r6r raven edition - VA Live2ride Motorcycle-related 38 August 27th, 2014 10:51 PM
2006 Ural Raven camaroz1985 Motorcycle-related 12 June 26th, 2013 07:30 AM
updated shots of raven after a wash want1sobad Pictures 9 September 22nd, 2010 12:55 PM
raven's new ass:) want1sobad 2008 - 2012 Ninja 250R Farkles 13 May 19th, 2010 12:07 PM
Loch Raven Snow BlueTyke Off-Topic 0 January 24th, 2009 09:04 PM
remote server monitor
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
