Old September 16th, 2019, 11:06 PM   #1
AbleOpus
Emergency Braking at higher speeds
So I decided to try some emergency braking going around 70-80kmph. Unlike at lower speeds, my bike destabilizes and wobbles a bit even if I am going straight. Is this suppose to happen? How can I avoid it if possible?
AbleOpus is offline   Reply With Quote
Old September 17th, 2019, 01:45 AM   #2
Make sure you release throttle completely when you brake. A lot of riders inadvertently don’t close throttle, or actually increase throttle under hard braking.
Are you using rear brake? You want to initially grab both. Then gradually let off rear as it gets light while you increase front brake. It could be rear tyre locking up and sliding around that you’re feeling.
Try using only front brake only, is bike more stable? Under maximum deceleration, very little braking force comes from rear tyre due to minimal weight on it. So most braking force comes from front.
One thing to check is rear & front wheel alignment using string test.
Old September 17th, 2019, 05:59 AM   #3
With my 250, and confirmed by the photo above, "very little braking force" is an understatement. Using any rear brake during max braking will do nothing but lock the wheel, reducing steering stability.
Old September 17th, 2019, 08:14 AM   #4
That's always been my theory as well.
In normal conditions with a good front tire, adequate brakes, and practice, there shouldn't be much contact from the rear wheel to get any amount of braking from it. If you are getting any significant braking from the rear during a hard stop you need to be utilizing the front more.
The other factor is mental. Too complicated of a braking procedure will over-tax you in a stressful situation. Sure you can add and subtract rear brake in a parking lot when you are relaxed and practicing, but surprised and under stress it's too much workload IMO.
Keep it simple. Concentrate on modulating the front. That gives the largest benefit.
Others will disagree.
Best thing is to anticipate a potentially dangerous situation and react or remove yourself before emergency action is required.
Old September 17th, 2019, 08:54 AM   #5
Right, and as @AbleOpus is doing, practicing emergency stopping is invaluable.
Old September 17th, 2019, 10:17 AM   #6
jrshooter
Motorcycle(s): ninja 300
at speed and threshhold braking, the rear getting loose is more than likely your bottoming the front out, maybe a little more preload/ compression, the bike will cope better and you will brake even harder and the process will repeat ,
Old September 17th, 2019, 10:22 AM   #7
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Yep, anticipating and avoiding problems will be the best thing. Practicing quick-stops will be the next best thing.
I've locked up the rear a couple of times, just a little. Feels weird but can be somewhat controllable if you know what it's going to do.
Old September 17th, 2019, 12:56 PM   #8
I hadn't thought of that, but with stock front suspension it was very easy to bottom it. For me a pair of Sonic springs cured that.
Old September 17th, 2019, 01:06 PM   #9
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
My bike doesn't have an emergency brake.
0 out of 1 members found this post helpful.
Old September 17th, 2019, 05:53 PM   #10
AbleOpus
The wobble happens whether or not I use the back brake. I will probably figure it out with some more practices. I am trying to program in my mind emergency braking at higher speeds so I can do it well when it is needed.
So far, from what I can tell, pressing the rear brake while emergency braking does not provide much stability or braking power at all. It just introduces the possibility of the rear brake locking up. Just touching it while emergency braking can cause it to lock up on my bike. I feel it is not worth using for emergency braking since it could cause problems when emergency braking is applied in a real-world situation.
Old September 18th, 2019, 02:57 AM   #11
Yup, testing shows really no benefit from rear brake in maximum-deceleration efforts.
Put zip-tie around fork-blade to record maximum travel usage.
When was last time forks were serviced? Oil may have thinned out and needs replacememt.
Old September 18th, 2019, 05:57 AM   #12
A few things that may be causing the instability during hard braking are loose steering head bearings and a worn/scalloped front tire.
Also check the fork travel with a zip tie and service the forks like Danno suggested. If it's totally bottomed I would expect that to have an adverse effect on stability as well.
Old September 18th, 2019, 07:56 AM   #13
Topaz
Topaz's Avatar
Remember to 'hug' the tank hard with your thighs when you brake so you take pressure out of your hands thus having morre control on the braking lever and the handlebar.
Old September 18th, 2019, 08:10 AM   #14
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
There's often a rush to blame something mechanical for any issue, because *of course* the rider can't be doing anything wrong, yeah?
IMHO the most likely cause of wobble is you. Chances are you're pushing back against the deceleration and putting unnecessary input into the bars. The bike is fighting you.
As well it should, because as we all know bikes are smarter than we are. It's our job to get out of the #@$#()@ way and let them do their thing. This is a really common cause of tank slappers. The bike hits a bump that causes a steering deflection and the instinctive response is to put a death grip on the bars. That only makes things worse. Chillax and the bike will sort itself out.
In this case, the deflection is likely caused by you inadvertently steering the bike because you're gripping harder to counteract deceleration forces.
So to avoid this in the first place, use your legs and core (i.e. belly), lock into the tank and don't put all your weight on your hands.
On a separate note about hard braking:
Something really important to understand about threshold braking... first LOAD the tire, then WORK the tire.
Never ever grab a fistful of brake all at once. That can instantly exceed your traction budget. If you brake progressively -- first squeezing moderately then squeezing HARD -- then the tire squishes into the pavement, the contact patch gets larger, and the available traction goes up.
It can all happen very quickly, but the key is to be progressive, not abrupt.
Relevant footage about this starts at about 4:20
Another advantage of load-then-work is that when you load the tire, the chassis settles down and gets stable before you ask a lot of it.
Old September 18th, 2019, 09:59 AM   #15
AbleOpus
Bike status
I recently got the front tire replaced and the bearings were checked during that. They said it was all okay. The bike was not taken care of by the previous owner so the forks might not have been serviced for 19,000km or 9 years. I did the zip tie test. It appears that the forks are bottoming out, but only when I emergency brake. This is normal right? I haven't ridden other motorcycles but the forks do seem a little soft for someone 195lbs. Perhaps I can just swap out the oil to something heavier/thicker.
I managed to mostly eliminate the wobble just with straddling harder and not touching the rear brake. Thew wobble still occurs when I get down to 30 km/h on a slight decline but this may be unavoidable.
Old September 18th, 2019, 12:15 PM   #16
It appears that the forks are bottoming out, but only when I emergency brake. This is normal right?.
It's not unusual for stock suspension, but it's not good. See my post about replacing my front springs above. If it's not severe, you might try a higher fork oil level to increase air pressure in the fork when compressed, but research recommended levels a bit first. There's some information here:
https://faq.ninja250.org/wiki/How_do...he_fork_oil%3F
Old September 18th, 2019, 04:29 PM   #17
jrshooter
, i service fork oil once a season, i bet your way under sprung for your weight, when you bottom out the forks the suspension cant compress anymore and the bike will rotate around the front wheel. but your just chasing fairies untill you get the suspension sorted to your weight and skill. my track bike is down right miserable to ride on the street. its skittish and harsh, you got to strike a balance between the 2.
Old September 18th, 2019, 04:34 PM   #18
AbleOpus
Re
Ok I will look into that thanks.
Old September 18th, 2019, 07:08 PM   #19
As noted - your fork spring rates are most likely way too light for your weight.
Oil isn't going to change that. You need the correct springs with the correct oil at the correct level.
Old September 18th, 2019, 07:14 PM   #20
Well, I don't think @AbleOpus told us his weight. Adjusting oil level per the information in the how-to link I posted certainly can make the front less easy to bottom, and if he's a light person it could be enough to fix the problem.
Old September 19th, 2019, 05:47 AM   #21
I was going by Post #15 where he said -
"... the forks do seem a little soft for someone 195lbs."
The stock springs are going to be way too soft for a 195# rider I'm pretty sure, especially if he does any amount of "sporty" riding. Getting the correct rate for his weight and riding style will make the front much more predictable and confidence-inspiring.
Then there's the rear...
Old September 19th, 2019, 07:06 AM   #22
Right, there it is. Instead of speed reading the thread I should have searched for "lbs".
If I'm correct, he has a 2010 250 though, and I understand that they are spring better than the pregens were. I don't know specifics though.
Old September 19th, 2019, 03:25 PM   #23
Factory new-gen spring-rate is 0.65 kg/mm.
For his weight and current bottoming symptoms, he should use something around 0.80-0.90 kg/mm springs for road-use.
For track, we're looking at 1.00-1.10 kg/mm with slightly lowered front-end.
Old September 24th, 2019, 10:30 AM   #24
AbleOpus
Now that I've read a bit more into it, it does seem like the right approach to replace the springs if I plan on keeping the bike for a long time. Trying to compensate the spring rate with heavy oil, in my case, will slow down the rebound and cause the forks to feel a bit sluggish.
Old September 24th, 2019, 04:55 PM   #25
Yes, heavy oil just increases damping. Adding oil reduces air space and effectively increases spring rate with an air-shock sort of result. You really can fine tune the front suspension by tweaking oil level.
But since you're not a light person, starting with stiffer springs would be the right thing to do. My 0.70kg/mm Sonic Springs (10S-070) were a bit under $100 for the pair, including shipping, a couple years ago.
Old September 24th, 2019, 07:15 PM   #26
AbleOpus
Unfortunately for me, the base price is $105 for the 10S-080, and I am in Canada. So I'm looking at $160 for a pair of springs. Shoot my face. I cannot find cheaper options.
Old November 6th, 2019, 11:04 AM   #27
Misti
Misti's Avatar
Often the wobble is due to gripping the handlebars too tightly under braking and having added pressure on the bars. This can be avoided by gripping the tank with your knees under hard braking (to prevent your body from sliding forward into the tank and also to help keep weight off the bars).
We have a special brake bike at the California Superbike School that allows our students to practice emergency braking. There are outriggers on the bike to prevent it from crashing so the students can practice locking up the front tire, first of all to get a sense of what that feels like and then to learn how to get maximum braking without locking up the front tire (and what to do if they do lock up the front tire.)
What would you say are the proper steps for emergency braking? And what should you do if you get a wobble, or lock up the front or rear tire?
superbikeschool.com
www.motomom.ca
Old November 6th, 2019, 11:25 AM   #28
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
very good information. i like how he explained it too
i have always thought of my bike like an animal, a horse...
you can tell it what to do, but tell it to do something it doesn't like and its going to throw you. I've tried to tell guys i used to ride with, that you could feel what the chassis likes and what it doesn't like. the bike will tell you its not happy, usually before you get thrown, if you only listen to it. at that point they just look at me like i am speaking a foreign language and ask me when i am going to buy a 1000cc bike.
gantt is offline   Reply With Quote
Old November 9th, 2019, 10:06 AM   #29
AbleOpus
I don't know if you saw my more recent reply but I stated that I mostly eliminated the wobble from straddling the bike more. There is still wobble while emergency braking downhill which I can probably correct.
I'd say: 1. Straighten bike and body, 2. Straddle tank hard, 3. Pull front brakes hard (not too rapidly for the first split second though).
Old November 10th, 2019, 07:14 AM   #30
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
One reason I love my little 250 Ninja is the brakes work. Yes most braking is done with the front.
I have a Harley Fatboy. That thing is almost impossible to stop. I have locked up the front brakes more times then I would like to admit to. It does track straight, but will go sideways quick with a lock up of th rear brakes. The next heavy bike I but will have ABS. They work quicker then I can.
Cafe Racer is offline   Reply With Quote
Old November 11th, 2019, 11:23 AM   #31
Panda
not an actual panda
Try gripping the tank with your knees. My guess is you are introducing the wobble because you are decelerating hard and you're weighting the bars as your inertia slides you forward relative to the bike.
Old November 11th, 2019, 11:44 AM   #32
MrAtom
MOTM - July '15
I fudge fingered my phone and hit dislike on accident.
Old November 11th, 2019, 02:16 PM   #33
Misti
Misti's Avatar
By straddling the bike more you mean gripping the tank tighter with your knees right? The reason this was able to help reduce the wobble is because by squeezing the tank with your knees you can then keep the weight off the bars. However, if you are still finding it happening sometimes under hard braking and especially downhill, it means that you are likely still putting some weight on the handlebars. When you go downhill or brake hard, the body tends to slide forward into the tank and can put added pressure on the handlebars. Under hard braking and braking downhill, if you squeeze the tank with both knees and make an effort to keep the arms loose and relaxed, this can usually eliminate the problem.
One other point is about how the brakes are coming on. If the braking isn't progressive (meaning the brakes are squeezed evenly but then pulled even harder right at the end) that too can cause some added pressure on the front or extra body weight to be flung forward. You want to make sure that the brakes are pulled in quickly and firmly but SMOOTH and progressive.
Hopefully that helps!!
Exactly
superbikeschool.com
www.motomom.ca
Old November 12th, 2019, 08:58 PM   #34
AbleOpus
Re
Yes.
My wobbling is largely taken care of, and with a few more trials I should be able to eliminate it.
You have all been helpful.
Old November 26th, 2019, 10:53 AM   #35
Misti
Misti's Avatar
Yes.
superbikeschool.com
www.motomom.ca
Old November 26th, 2019, 02:29 PM   #36
SibSerge
What a great video, thank you!
Motorcycle Emergency Braking With Passenger Motofool Videos 12 August 14th, 2016 08:11 AM
What's Your Emergency Braking Method? akima General Motorcycling Discussion 72 April 25th, 2015 02:04 PM
Practice emergency braking with ABS cadd Riding Skills 3 September 14th, 2014 08:38 PM
Emergency Braking Practice akima General Motorcycling Discussion 29 September 3rd, 2013 12:23 AM
Dies at higher speeds/slowing down from higher speeds TheFranchise216 1986 - 2007 Ninja 250R Tech Talk 67 April 20th, 2012 01:13 PM
