September 21st, 2019, 08:25 PM | #1 |
Join Date: Aug 2019 Motorcycle(s): Buell, ninja 250, Sportsters Posts: 8
Ninja 300 clutch on a ninja 250? Swap
I was wondering if anyone has swapped a ninja 250 clutch for a ninja 300 slipper clutch?
September 27th, 2019, 07:27 PM | #2 |
I would like to see that as well.
"It ended up being the loose nut behind the wheel" |
September 28th, 2019, 02:54 AM | #3 |
I recall hearing something about this. Don’t know if it was here or somewhere else. I seem to remember 300 clutch cover was needed due to extra width of additional components.
October 6th, 2019, 03:16 PM | #4 |
Join Date: Feb 2016 Motorcycle(s): ZZR250, VFR800 Posts: 478
Yes it’s been done. Search on here & you will find it. The slipper clutch pack is deeper than the 250’s, so if you use the 250 cover you need to remove the case reinforcements on the inside to make clearance for the clutch depth. A simpler solution is to use a 300 clutch side case as well. I believe they are the same where they meet the engine, simple check method is to buy a 250 & 300 gasket to compare. There is a thread on here that shows pics & differences between the new gen 250 engine & the 300, in full strip down.
I put a new gen clutch in my pregen engine, works great & does away with the death beat of the pregen engine Have fun. |
October 15th, 2019, 05:46 PM | #5 |
Mohawk, could you share some links as I just can't seem to figure out the correct search terms.
October 15th, 2019, 11:48 PM | #6 |
October 16th, 2019, 12:27 PM | #7 |
Thanx!
Swingarm swap from 300 to 250? | Kurgan | 2008 - 2012 Ninja 250R Tech Talk | 17 | August 27th, 2019 07:27 AM |
FS : 2008+ Ninja 250, 2013+ Ninja 300 CRG RC2 Clutch lever | abhijitz | Motorcycle-related | 0 | June 23rd, 2016 11:19 AM |
ninja 250 engine swap | tellmewhy! | General Motorcycling Discussion | 11 | May 25th, 2016 06:38 AM |
250@300 cc swap | Shinigami | 2008 - 2012 Ninja 250R Tech Talk | 21 | May 27th, 2015 12:23 PM |
