Old September 22nd, 2019, 01:59 PM   #1
dodgerdad
dodgerdad's Avatar
Trouble re-starting
My bike has developed difficulty re-starting after the engine is warmed up. I believe this to be a new issue. After I shut it off, it doesn't want to start whether I try immediately after or let it sit a few minutes. So bad my battery wore down earlier today.
In my "opinion" it seemed to smell rich so I double checked my air-mix and reset them at 2 1/4 turns (they previously were a tiny bit under 3). I pulled the plugs and the right smelled like fuel but looked normal and was not wet. The left did not smell like fuel and looked to be at about the limit of "normal" but definitely well on the lean side.
The bike has less than 600 miles since ducatiman serviced my carbs, new OEM fuel filter, new plugs, new OEM petcock, new OEM air filter, sync and valve adjustment. Runs great but idles subpar (since day one, after I cleaned carbs and after ducatiman serviced them, too) but I've just resolved to ignore it.
I'm a bit puzzled on what to look at next, and when (hot or cold). Any ideas?
Old September 22nd, 2019, 04:05 PM   #2
Have you done tank-vent mod?
Old September 22nd, 2019, 04:38 PM   #3
dodgerdad
dodgerdad's Avatar
I removed the California evap system a while ago which includes removing the little screw to vent the top of the tank. Is that what you mean?
I haven't experienced any vapor lock up or "whooshing" when I open the cap.
Old September 22nd, 2019, 04:55 PM   #4
Have you checked the valves lately?
Have you checked the carb sync?
For now, try opening the throttle as you are cranking.
Old September 22nd, 2019, 06:31 PM   #5
ducatiman
ducatiman's Avatar
I'd urge to disregard the *number* of turns on the pilot screws and instead urge you to set each cylinder (AFTER a ride, bike fully up to temp) by finding its "sweet spot". The required number turns out on each cylinder will differ.
Beware of burns....a very hot, semi-dangerous job for the more experienced. Gloves on, shop rags or towels draped as necessary over crankcase area to temporarily protect and insulate your hands and forearms from heat....work 1 cylinder at a time...turn the pilot screw inward, at a certain point that cylinder will begin to stumble....turn back outwards a bit at a time till the cylinder recovers, then further as necessary to reach its highest RPM....do overs are fully acceptable till you are confidant you've found the "sweet spot"....I think you'll sense and hear it...then and only then...do same to the other side.
A large pedestal type shop fan is very helpful for this type of hot "running in place" procedure.
Pretty sure I posted all this before.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old September 23rd, 2019, 06:06 AM   #6
dodgerdad
dodgerdad's Avatar
Valves & sync were done less than 600 miles ago and was running great.
I've tried to open the throttle when starting, doesn't have much of an effect. It tends to only re-start when the throttle is left alone.
Old September 23rd, 2019, 06:08 AM   #7
dodgerdad
dodgerdad's Avatar
Yeah, that's how I went about setting them initially which left them at about 2.8 turns. Yesterday I closed them then opened them to 2.25 just to give me a baseline and eliminate that as a potential culprit. Just odd that it was running/re-starting fine then went south after such low mileage since being all tuned up.
Old September 23rd, 2019, 06:13 AM   #8
Have you filled-up recently?
How old is the gas in it now?
When things just pop up like that the first thing I think of is a fuel issue.
Old September 23rd, 2019, 06:20 AM   #9
ducatiman
ducatiman's Avatar
^ valid stuff
Custom Carb Service
Old September 23rd, 2019, 07:45 AM   #10
dodgerdad
dodgerdad's Avatar
^ valid stuff
I haven't filled up recently. The gas is just about a month old, is it possible that it went bad so quickly? If so, would it be reasonable that the bike easily starts (cold) and runs great on bad gas but has issues re-starting when warm?
I guess I can dump out the gas, drain the bowls and try again this weekend.
Thanks for helping out guys, really appreciate it.
Old September 23rd, 2019, 08:16 AM   #11
Because the issue popped up out of the blue, I would try that first.
Gas with ethanol goes bad quickly, and can even be bad when purchased.
Easy thing to just check off the list before moving on and taking things apart.
Old September 23rd, 2019, 09:35 AM   #12
dodgerdad
dodgerdad's Avatar
Good point, it's simple enough. I'll give it a shot and check back in here. Thanks.
Old September 26th, 2019, 11:56 AM   #13
dodgerdad
dodgerdad's Avatar
Drained the bowls, emptied out my tank and put in fresh gas. Problem remains the same. Any suggestions? I'm so close to finishing up this project, just a speedometer away.
Old October 3rd, 2019, 04:39 PM   #14
dodgerdad
dodgerdad's Avatar
Question Smoke machine test
I hooked up a smoke machine to the airbox (engine off) and pumped in smoke hoping to find a vacuum leak but no smoke escaped. I repeated the same process with the throttle wide open and no apparent leak.
I repeated the above AFTER the engine was run to full temperature since that's when the re-starting failure happens. I was hoping that maybe something like a clamp, boot or hose is expanding with the heat and creating an air leak. Needless to say, no smoke escaped.
I'm completely stumped.
Old October 3rd, 2019, 09:43 PM   #15
1. Test for vacuum-leak going to and at petcock. You may not be getting fuel because petcock is not opening. When you have hot-start problem, disconnect fuel-hose from carbs and aim into measuring-cup. Crank engine, does petcock flow petrol? You can also measure vacuum in hose going between petcock & carbs. Above certain vacuum number, petcock will open and flow. Below certain vacuum amounts, petcock will not open. Simple if you have numbers to look at.
2. If fuel is getting into carbs, perhaps it's not enough due to vacuum-leaks. These leaks suck in extra air and causes lean difficult-to-fire mixtures.
Smoke test doesn't work because with engine off, it needs to be pressurised to escape from leak. Meaning you have to plug exhausts and seal inlet to pump smoke in under pressure.
One iffy way to test is run engine and squirt carb-cleaner or propane around all intake joints, hoses and clamps. Leak will suck in carb-cleaner and cause change in idle-speed. But it's very subtle and not easy to catch unless you've been shown the shift before.
Best way to find vacuum-leaks is to seal exhaust and intake and pressurise it to 2-3psi with compressor. First, plug exhausts with banana, potatoes, wet-rags, etc. Then use fitting that seals off intake and pressurise with compressor to 2-3psi. For dual-carbs, you can make Y-fitting with two radiator-hoses to use one pressure-inlet.
Then spray soapy water around all joints, hoses and clamps. I found leaks that smoke and propane couldn’t.
Last futzed with by DannoXYZ; October 4th, 2019 at 11:54 AM.
Old October 3rd, 2019, 09:47 PM   #16
I doubt intake vacuum-leaks would be severe enough to cause no-start condition though. Would also cause problem with cold-starts as well if it was that large. More likely it would only cause unstable idling warm or cold.
1. I suspect petcock or its vacuum supply. Need to measure things to rule that out.
2. Also have you tried starting with gas-cap open? Cap vent-mod isn't removing screw, but entirely removing one-way valves inside gas-cap.
3. Test for spark as well when you have hot-start issue.
Last futzed with by DannoXYZ; October 4th, 2019 at 11:55 AM.
Old October 4th, 2019, 05:25 AM   #17
ducatiman
ducatiman's Avatar
As you've had tuning difficulties going on a year now....something has been overlooked, maladjusted.....or something.
@dodgerdad you had posted a running/starting video in a previous thread, can you repost? It was taken after your valve adjust, IIRC. I'd like to hear that again. Or a new one, your choice.
Short of being there, that vid next best thing.
Custom Carb Service
Old October 5th, 2019, 09:03 AM   #18
dodgerdad
dodgerdad's Avatar
The petcock is OEM new and I confirmed fuel is flowing with vacuum, just haven't actually measured the pressure. I'll try restarting with the cap open, simple enough check.
I had already planned to test the coils for spark when hot today. Next step will be to double check valve clearances tomorrow to see if perhaps I left them too tight and they're not opening enough when everything is hot and expanded.
Thanks for your suggestions!
Old October 5th, 2019, 09:07 AM   #19
dodgerdad
dodgerdad's Avatar
I completely agree with you, something has to have been missed. I'll be checking the coils today when the engine is hot to see if perhaps one of them is failing. If not, I plan to check the valve clearances tomorrow, perhaps I left them too tight??
As for the video, I'll record a new one this weekend IF necessary.
Thanks for the input!
Old October 6th, 2019, 02:26 PM   #20
dodgerdad
dodgerdad's Avatar
Progress, dare I say?
I warmed up the engine last night and shut if off then it wouldn't start, as expected. I tried re-starting it after opening up the gas cap (heard no squeal or whoosh) and no change. Then I check for spark and both coils produced a nice strong spark.
I began to strip off a few things off to access the valves in the morning and noticed the left airbox boot was not fully seated at the bottom. Coincidentally this is the same cylinder that appeared to be a bit lean when inspecting the plug. I moved the aibox as far forward as I could (not enough for my satisfaction) and re-seated both airbox boots to the carbs. By then my battery was dead.
I charged up the battery this morning, warmed up the engine and then shut if off. I re-started 3 times in a row so I think that may have been the problem. That leads me to one more question:
What is the carb intake diameter?
I want to replace the airbox boot springs with crew-on hose clamps. my boots have become a bit "loose" and the airbox just isn't sitting fore enough despite wrestling it around. I figure tight screw-on hose camps should satisfy me that there is a solid air-tight seal.
Old October 6th, 2019, 09:41 PM   #21
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
I haven't had any issues with the screw type hose clamps. A little fumbly, screwing it all down, sometimes if you have them too loose. No problems with leaks, or backing off, though.
GAU-8 is offline   Reply With Quote
Old October 6th, 2019, 10:00 PM   #22
Good job on fixing it!!!
But that doesn't really make any sense. Any pre-carb leaks will not affect fuel-metering or AFR. You can start and run the bike with no air-box even. Sure, it may have some mid-range stumbling issues, but it'll still start.
Could there have been leak at rubber manifold in between carb and head? And in process of shoving air-box back on carb, you closed up that other leak as well?
Old October 7th, 2019, 06:28 AM   #23
I separated the battery box from the airbox on my pregen, and now it's easy to get the boots over the carbs, and the springs keep them on fine. Before it was about impossible to keep the boots on correctly.
I did make a couple small brackets to make sure the airbox stays forward against the carbs:
https://www.ninjette.org/forums/show...25#post1257525
Old October 7th, 2019, 07:32 AM   #24
dodgerdad
dodgerdad's Avatar
Your point make sense, I don't know why this caused a non-start problem but prior to this it was re-starting just fine. I had checked the head/carb boot clamps and they were already on there fully tight. I'll shoot some carb cleaner around them to see if it alters the idle and post back. I remember doing this a while back ago and found no issues.
Old October 7th, 2019, 07:34 AM   #25
dodgerdad
dodgerdad's Avatar
Clever bracket mod! I may have to go that route because my airbox sits way too far back.
Trouble starting matt021126 2008 - 2012 Ninja 250R Tech Talk 6 May 12th, 2017 05:26 AM
Trouble starting Wrestler174 1986 - 2007 Ninja 250R Tech Talk 1 June 14th, 2015 06:02 PM
Trouble with starting speed vmlp 1986 - 2007 Ninja 250R Tech Talk 13 May 26th, 2012 09:12 PM
Trouble Starting dlebe250 1986 - 2007 Ninja 250R Tech Talk 7 January 12th, 2011 07:47 AM
trouble starting... n4v1n 2008 - 2012 Ninja 250R Tech Talk 4 August 9th, 2009 03:18 PM
