Old October 11th, 2019, 06:22 PM   #1
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Angry Broken Left Foot Peg Frame Mount Point
FML....
The nuts that the rearset screws into broke off the frame. To add insult to injury, the spring for my sidestand also fell off somewhere, and I had to use a stretched cargo net to keep it up. Temporarily zip tied the rear set and drove home in first, while resting my left leg on my sliders.
I don't have a welder... Does anyone have any non welding solutions to fix this, or am I SOL?
Old October 11th, 2019, 10:06 PM   #2
I originally thought this was design flaw with having nuts on thin single outer-layer of frame. Stronger design have threaded tube span width between outer to inner layer of frame (double-shear). However, after seeing couple of wrecks at track with bikes that had strong rearset mounting, hard crash will actually bend frame instead of breaking off those nuts. And next closest spot on frame is swingarm pivot, which was tweaked and distorted by having rearset mounting bend both layers of frame. Ended up costing over $600 to have frame professionally repaired and aligned.
What you can do is drill through to back side of frame and use thin nuts on other side to hold rearsets.
1. remove mounting bolts and broken frame pieces from rearsets
2. line up rearsets in correct position on frame and use pencil/marker through mounting-holes to mark spot on back side of frame
3. remove rearset and drill 8mm hole on back layer of frame (go slowly and don't hit chain or swingarm when it pokes through).
4. get longer mounting bolts for rear-set that sticks out back side 5mm (measure length needed)
5. get thin 5mm thick nuts, or grind regular nuts thinner
6. use blue Loctite and mount rearsets back on with longer bolts and nuts on back side.
Had to do this to teammate's bike after crash at Buttonwillow. Got it up and running before her next race. This is also why I only use folding-pegs on my bike.
Old October 11th, 2019, 10:47 PM   #3
nocturncal
nocturncal's Avatar
@DannoXYZ THANK YOU
I'm gonna stop by Cole hardware tomorrow n get some bolts and nuts. Will update
Prior to this, I was considering getting new pegs, possibly those non folding ones, but after this episode I agree with you on using only foldable pegs on. I'd rather have that be a weak point than transferring all that impact in a crash straight to the frame.
Old October 19th, 2019, 05:56 PM   #4
nocturncal
nocturncal's Avatar
Solution worked beautifully. I'm back in action. Thanks again @DannoXYZ
Old October 21st, 2019, 11:03 AM   #5
Great work!!!
Old October 21st, 2019, 02:24 PM   #6
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
@DannoXYZ well done
Old October 21st, 2019, 05:26 PM   #7
Originally Posted by JohnnyBravo View Post
@DannoXYZ well done
Why thank you!
What is the piece that covers left passenger peg mount point like the exhaust hanger? CZroe 2008 - 2012 Ninja 250R Farkles 4 October 6th, 2009 04:25 PM
