Old October 18th, 2019, 06:56 PM   #1
NaturalFlavored
Motorcycle(s): 250r
Piston charts??
Is there somewhere where I can find different size Pistons with their measurements??
I know it's a long shot but I'm building a custom engine and I'm sort of new to the custom scene, I have done mods in the past but it's from things already made for the engine.
I'm just looking for a certain size piston.
Stock piston size I'm working with
Piston Diameter: 75mm
Piston Height: 46mm
Compression Height: 22.5mm
Wrist Pin Diameter: 17mm
Wrist Pin Length: 57mm
Or better yet can someone help me with how to search for a specific piston size?
Last futzed with by NaturalFlavored; October 19th, 2019 at 07:43 AM.
NaturalFlavored is offline   Reply With Quote
Old October 19th, 2019, 12:12 AM   #2
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
Piston Diameter: 72mm
Piston Height: 46mm
You also need to know the measurement from the centre of the wrist pin to the top of the piston
Perpetua Culpa Alterna Vagus
59096 is offline   Reply With Quote
Old October 19th, 2019, 12:39 AM   #3
That's compression height = 22,5mm
As for piston sources, I usually peruse Wisco and JE piston catalogues:
http://www.wiseco.com/Powersports/Pistons.aspx
https://www.jepistons.com/Catalogs/P...rts/Index.aspx
Usually you can find something that's matching. If not, you can always fill out form and get pistons made to your exact specs. I usually go to Wossner or Arias for that. Looks like Honda Helix CN250 pistons match your specs.
http://bradsscooters.com/partsstore/...-piston-kit-2/
https://www.partsforscooters.com/180...iston-Kit-72mm
https://www.amazon.com/Piston-Honda-.../dp/B06XQGHFQ7
https://www.ebay.com/itm/HONDA-HELIX...T/372644721467
https://www.ebay.com/c/14031241008
Old October 19th, 2019, 07:44 AM   #4
NaturalFlavored
Motorcycle(s): 250r
Thanks for the info, yeah it's the motor I'm working with. I will browse through those websites and see what I come up with.
Thanks for the help.
Old October 19th, 2019, 11:11 AM   #5
This is very popular engine for buggies and karts since Helix was produced for over 20-years. Typical big-bore kit:
http://www.scootertronics.com/cn250-big-bore-75mm.html
Web Cam has performance grind for it.
Old October 19th, 2019, 05:44 PM   #6
NaturalFlavored
Motorcycle(s): 250r
It is but nobody offers the BBK it's all out of stock now. Which is why I have to make my own.
Old December 24th, 2019, 02:38 AM   #7
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Piston Height: 46mm
From those numbers it sounds like a Honda fireblade 954 or 1000, engine. There are +1,+2 mm pistons for those, or you can look at other Honda to match the wrist pin size. Later CBR1000’s use a larger bore, the limits will be determined by the between cylinder thickness & if nikasil the ability to get them replated.
Old December 24th, 2019, 05:12 PM   #8
NaturalFlavored
Motorcycle(s): 250r
That's pretty damn close! 74.9mm piston 17mm wrist pin, but the clearance was off a little which I can work with. 23.3mm over by .8 which isn't a lot I can get a spacer or see if the shop can help me out with an alternative.
Dyno graphs/charts, who's got 'em? subxero General Motorcycling Discussion 6 December 8th, 2012 08:58 PM
Dyno Charts nickjpass General Motorcycling Discussion 14 October 17th, 2011 03:38 PM
Dyno Charts with jetting and stock exhaust? KURT 2008 - 2012 Ninja 250R Tech Talk 5 February 27th, 2011 10:03 AM
[motorcycledaily.com] - BMW S1000RR on the Dyno: Off the Charts! Ninjette Newsbot Motorcycling News 0 December 16th, 2009 12:30 PM
[sportrider - latest stories] - SportBike Dyno Charts Ninjette Newsbot Motorcycling News 0 June 4th, 2009 02:02 PM
