Old December 1st, 2019, 02:55 PM   #1
danters
Motorcycle(s): '06 Ninja 250
Suggestions for Custom Gauge Cluster
Hey all,
Iím looking for some suggestions for a gauge build with the stock meters for a 2010 250. My girlfriendís bike has a bit of a custom look, and she tossed her gauge cluster after an accident. I have a replacement stock assay but with the look she has, itís too bulky. Iím hoping to pop the gauges out and put them in a custom housing. Does anyone have any suggestions for how to construct that?
The bike looks a little like a cafe racer. I know Blue Collar Bobbers makes a kit that has the custom gauge cluster, but I think theirs is only for the pre-gen bikes, is that right?
Iíve tried looking this up in the forums, but havenít had much luck, so please let me know if this has already been asked.
danters is offline   Reply With Quote
Old December 1st, 2019, 04:26 PM   #2
This is the one I'm going to try next time one of my stock gauges quits:
http://www.dan-moto.com/index.php?ma...roducts_id=129
Old December 1st, 2019, 05:17 PM   #3
Motorcycle(s): CB125T, Ninja250R racer, Ninja250R street bike, EX250F#1, EX250F#2, EX250E, VF500F, CBR600RR
Yes, you can pop out gauges and put into custom housing. Easiest to make face first to hold all gauges in orientation you want. Simplest to do with carbon-fibre panel. Once that’s done, you can figure out sides and back. This is practically no-cost option, $10-15 in supplies.
Next up is Koso clones from Ali, $25-35.
All these require wiring. So if you don’t know how to use multimeter and know how to solder, allocate budget accordingly to hire someone who does.
Old December 1st, 2019, 09:49 PM   #4
Yakaru
The Violet Vixen
Yakaru's Avatar
Motorcycle(s): Perigee ('08 250), Saturn ('13 300), Pearl ('15 300), Zero ('16 S1000RR), Chibi ('17 Z125), Xellos ('18 HP4R)
MOTM - Jun '16
I replaced my 300's dash with a Starlane DaVinci when the original went out, but I think that requires more electronics-based signalling than the 250 does.
"most folks racing this bike get it in a competitive state of being with much less invested than you've already put in Saturn." - Alex
Old December 2nd, 2019, 10:29 AM   #5
danters
Thanks everyone! I am hoping to keep the stock since we have it, but have been looking at the Koso RX-2, since it has a plug and play for the 250 (I'm not positive on which generation though...). I've also looked into the Trail Tech Vapor as an option. Any experiences with those?
What exactly is a Koso clone? I've seen it mentioned a few times, but haven't seen it on Koso's site. Is it just a mimic?
Old December 5th, 2019, 02:15 PM   #6
I've used Trail Tech Vapor on my track 250 for many years now. No issues at all. Also nice to have water-temp along with ambient air-temp reading.
one of these...
https://www.aliexpress.com/item/3278...5c4c2e0e485vm9
No such thing as Koso plug-and-play harness because with it you still need to string new wiring to:
- coolant-temp sensor
- speed-sensor
- power wire
Not sure what remaining plug that connects to factory harness picks up, maybe just ground and tach-trigger?
https://www.partsgiant.com/p268547-k...y-kit?f=111078
Old December 14th, 2019, 12:28 PM   #7
fred smoot
fred smoot's Avatar
Motorcycle(s): 1996 Ducati 900SS/SP 2009 Ninja 250R trackbike
cluster...
I took the stock tachometer out of the original display panel and put it in an aluminum box. Then, using the stock wiring harness, connected them to green for neutral, yellow for oil pressure, and blue for low water to panel bulbs. Added an aftermarket water temperature gauge with on/off switch20191214_131810.jpg. It is all I need to know at the track.
Fred
'09 Ninja 250R track only
"If everything seems under control, you're not going fast enough." -Mario Andretti
fred smoot is offline   Reply With Quote
remote server monitor
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Except where otherwise noted, all site contents are © Copyright 2019 ninjette.org, All rights reserved.
